Cleaning Motherboards - ATTN SMOKERS!!
This is a sticky topic.
  • Dan81
    SNES-powered
    • Oct 2013
    • 1866
    #181
    Re: Cleaning Motherboards - ATTN SMOKERS!!
    Had a for parts machine that I thought bringing back to life. Had a ASRock P4VM890, Delta DPS-300PB-2A and a VIA USB2 card.
    I hope NOBODY has to live the hell I had to go through cleaning the PSU. Sweet Jesus Christ, I don't think I had a PSU smell that bad of nicotine and have so much dust.
    I cleaned out the dust now. It still smells a bit (generally when warm) but it's mostly gone.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
    • christinejshaw
      • Jun 2018
      • 13
      How do you clean a PSU?
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16959
        Same way you do a motherboard. Complete disassembly, hot water & simple green, and an air compressor to blow the water out of everything. I've cleaned a lot of them that way.
        Here's a good example of hotwashing some PSU's: https://www.badcaps.net/forum/showpo...1&postcount=16
        I do this all the time with stinky PSU's from houses of smokers. Like anything else electronic, just make sure its dried out good before firing it up. With an air compressor, you can wash, air compressor dry, reassemble, and power them up right away...I do it all the time.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • christinejshaw
          • Jun 2018
          • 13
          I'm a noob. I thought you could get zapped pretty good taking about a psu?
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16959
            If you're a noob, you might not want to try it.....but if the PSU is thoroughly & completely dry, its safe.
            Team : 49813
            Join in!!
            Team Stats
            • christinejshaw
              • Jun 2018
              • 13
              So if I open it up there is no risk of shock?
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16959
                If you remove power, it should discharge everything.
                Team : 49813
                Join in!!
                Team Stats
                • christinejshaw
                  • Jun 2018
                  • 13
                  Awesome! I have a few lying around that I can run tests and clean them. You rock!
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    #189
                    To be on the safe side measure the big capacitors with a volt meter set to DC.
                    Sometimes they don't discharge, either because the discharge resistors are broken or none are installed...
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16959
                      I did say *should* discharge... On old television sets I'd service back in the day, if servicing power supplies, I'd just take a screwdriver and short the leads on those caps, just to make sure they were drained. They'd occasionally create a nice spark!
                      Team : 49813
                      Join in!!
                      Team Stats
                      • christinejshaw
                        • Jun 2018
                        • 13
                        It works perfect. I love this forum. Hat tip to you Top Cat!
                        • tvdad
                          • Nov 2019
                          • 5
                          Lol thats what the inside of my laptop looked like last time i cleaned it
                          • Zane123
                            • England
                            #193
                            Hey I've just joined the forum after reading a few posts. I'm going to clean a motherboard with hot water and simple green. I don't have an air compressor. Can I dry it with a hairdryer? Or is it better if I leave it to air dry?
                            __________________
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              #194
                              __________________
                              I'd use a hair dryer over leaving to air dry.
                                master hoarder
                                • May 2008
                                • 12175
                                #195
                                Doesn't matter, both will work.
                                However, be advised that if you do use a hair dryer, the board could still have moisture/water trapped under the large BGA chips and some connectors, even if it looks dry on the outside. For this reason, I prefer to let my boards air dry. This takes more time, however. If you are looking for a speedier process, first let the board drain for about 30 minutes while placed vertically. After this, hit it with the hair drier until most of the moisture from the board is gone and the board feels warm. Finally, let the board sit for a day or two in a dry, airy place. I, for example, have have forced air heating (and cooling) at my place, so after doing the above, I then place the board sitting vertically above an air vent. Usually within a day, my stuff dries. But I typically let it sit for 2-3 at least.
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16959
                                  I dry them with the air compressor. Wash, dry, and powered back up...all within 10 minutes. Never had an issue!
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                  • ChaosLegionnaire
                                    HC Overclocker
                                    • Jul 2012
                                    • 3266
                                    • Singapore
                                    #197
                                    how about baking the board for an hour at 100°C? this is used to remove moisture to prevent popcorning during reflows. can the same logic and technique be used to just make sure the bga chips are dry underneath before applying power?
                                    • bads214
                                      • Nov 2021
                                      #198
                                      Hello, I can see that a very good job, yes I know the stench is the worst, I had the worst smell too, but I don't know if the same one I bought a used motherboard and it stinked a lot, but I didn't clean it, I threw it away because it was impossible to stand it and I bought a new one
                                      silent is gold.
                                      • lenvane
                                        • Jul 2022
                                        • US
                                        #199
                                        Done this to my lga 1151 board for my 6700k when i spilled soda on it. Best way to clean off sticky gunky residue.
                                        https://låneutensikkerhet.no
                                        • Topcat
                                          The Boss Stooge
                                          • Oct 2003
                                          • 16959
                                          Yes, it works....I done this to LGA socketed boards. You just have to be very careful of the socket. If using an air compressor for the initial dry-out, don't hit the socket with a lot of pressure (use a regulator and turn it way down), or leave the CPU in it during that time.
                                          Team : 49813
                                          Join in!!
                                          Team Stats
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
