emachine e725 freezes randomly
    Re: emachine e725 freezes randomly
    No, I think 64-bit was created for the arrogant minority.
    Enthusiasts are not a majority. They are a vocal minority.
    Less than 1% of computer users world wide will ever -actually- 'need' 64-bit.
    [Baring fabricated 'need' created by planned obsolescence and advertising.]
    And you didn't answer the question.
    Mann-Made Global Warming.
    - Dr Seuss
      "640k oughta be enough for everyone."
      Why 32-bit Windows 7 is quoted to run on 1GB? Because it does run. At what pace, that is not Microsoft's concern.
      A working TV? How boring!
        Originally posted by Th3_uN1Qu3 View Post
        32-bit was kept for the ignorant masses.
        and those running non-x64 cpu's. like:
        laptop: core duo, core solo, atom (mobile variants), pentium m
        desktop: pentium 4 (later non x64 variants)
        with the orignal macbook (pro as well) not making the cut for mac OS 10.7 Lion (core solo/duo is 32 bit, 10.7 requires 64 bit), there are probably currency freaks who would like to run win7 without paying the $$$ for new/used macbook. even the originals i speak of still go for $600 a pop online.
        win 8 may still have a 32 bit version too... with the later 32 bit atoms existing still.
        sigpic
        (Insert witty quote here)
          [Not counting servers, most of which don't need 64-bit either...]
          99% of computer users surf, do office work, maybe play with pics and videos... and not much else.
          - And will NEVER do anything else.
          ALL of that could be done just fine in Win98 or W2K were it not for the WinTel planned obsolescence program.
          ~ Don't support new chips with old OS.
          ~ Stop supporting old OS.
          ~ Force whole world to upgrade due to availability.
          ~ Repeat..
          [Psst... It's fabricated.]
          True, but that wasn't the question.
          Takes 2GB [2x what MS says] to run Win7 32-bit -> well.
          Why is it the same 2GB in the 64-bit?
          - Dr Seuss
            Win98 had a metric ton of bugs. I still have a computer that runs Win98 to this day but that doesn't make me love it any more than i did back when i was a little kid who cried for his daddy whenever he broke his computer. Win98 still sucks for most serious intents and purposes. Heck, it even fails at surfing the 'net nowadays. Win2k had less bugs, but had a fair bunch of usability quirks instead.
            Because it's the same system.
              yeah... since 64 bit always takes double the ram... which cancels the 2/2 microsoft skew...
              rule #1: minimum hardware requirements are a lie 99.99999...% of the time.
              sigpic
                Depends on the server
                We're migrating to Itanium servers, and DBAs want to try having an Oracle database in memory
                Can't do that with a 32-bit memory limit
                better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                  Now somebody will chime in and mention PAE.
                    Is that a *need* -> Not really.
                    And what % of the servers in the world do that?
                    - Dr Seuss
                      Anyone that knows what PAE is good for wouldn't because they'd know it's irrelevant.
                      You haven't answered the question.
                      - Dr Seuss
                        You're the warmest yet but not right unless that first line was sarcasm.
                        - Dr Seuss
                          Since i have no idea what the original question was, i'll just provide my best guess of an answer: Two 32 bit values still take the same memory space as one 64-bit.
                            It takes x-amount of RAM to run a LAN chip, x-amount of RAM to run a Sound chip, x-amount of RAM to run every other chip.
                            Barring sloppy and/or bloated drivers that [x-amount] doesn't change from 32->64 bit.
                            Regardless of the 'bits' if you start with 2GB you have the same amount of RAM left for the user regardless if it's 32 or 64 bit.
                            And: regardless of the 'bits' if you start with 1GB you have the same amount of RAM left for the user regardless if it's 32 or 64 bit.
                            So MS saying 1GB for 32-bit and 2GB for 64-bit is nothing but marketing bull shit.
                            - Dr Seuss
                              The ones where the business using them are constantly demanding faster performance
                                So obviously what they had last year didn't work and they went right out of business.
                                - It's a WANT, not a need.
                                - Dr Seuss
                                  hello?
                                  64 bit by itself ALWAYS takes twice the ram. double the word size since everything is 64 bits, not 32 bits.
                                  64 bits has performance increase, yes, but the fact you are in a 64 bit world means you will use double the ram.
                                  doesn't matter how bloated the drivers and whatever are. double is double. what you are saying makes no sense. a 0 still takes up memory. the only way what you said would work would be if you ran out of memory, in that case, you are hitting the page file either way, but 64 bit will hit it a LOT more.
                                  if 64 bit let you write code that was over twice as small (using 64 bit instructions), then it would use the same or less... but taking something and doing a direct conversion will always double the required memory.
                                  the microsoft bit was discussed in the posts before this.
                                  sigpic
                                    But a good programmer could put more instructions in one 'word'.
                                    By your theory 2GB/32-bit = 4GB/64-bit because of the # of 'words' in the code.
                                    If that's true a 32-bit system with 2GB RAM will perform the same as a 64-bit system with 4Gb RAM.
                                    Is that what you're saying?
                                    So, spending twice the $ on RAM to use 64-bit nets zero performance gain?
                                    Are you paying attention Th3_uN1Qu3? - Because I think RD has a point..
                                    To flip it.
                                    A 64-bit system w/4GB will have memory performance approx 1/2 as good as a 32-bit system with 4Gb.
                                    - Because the 32-bit system can hold more 'words' in RAM.
                                    - Dr Seuss
                                      hello?
                                      I'm not sure you are aware of it, but you can still directly address 32, 16, and even 8 bit registers on a 64 bit CPU. You use as many bits as you need. Just because a variable CAN be 64 bits in length, it doesn't mean that it WILL be. Look up some x86 ASM and you will understand.
                                      @ PCBONEZ: If ratdude747 was right on this one then there would have been no reason to progress past the original 8088 (8 bits) and 8086 (16 bits). Heck, maybe we should be all browsing the internet on PICs and ATMELs. Look, they even got 16 and 32 bit ones. Besides, i didn't buy my RAM to have it sitting idle. And it's a fact that x64 runs better on 2GB and up than 32-bit. And we have already agreed that 1GB is not enough to run Windows 7. So, the point is?
                                        If that's true a 32-bit system with 4GB RAM will perform the same as a 64-bit system with 8Gb RAM.
                                        edit for unique- unused bits become zeroes, see below
                                        it will use the same % of memory.
                                        do you program? from my understading in my DE class in high school, the word size has more to do with additional instructions and value sizes. perhaps my knowedge is skewed, but you cannot exactly cram more instructions into a word, you just have more words you can use.
                                        example:
                                        say you could only write words 4 letters (bits) long. ok, you can curse all you want but you are limited to that specific list of words no longer than 4 letters. any unused places in a word are nulled out by a "0". in a way this is a 4 bit system.
                                        the instruction set is like a dictionary here (defining what means what, so we know 0dog = domesticated canine that eats its own poo).... so you could say things like:
                                        00I like food
                                        0you 0are nice
                                        debt 00is 0gay
                                        but then you want longer words and more words. so we go to an 8 letter system.
                                        since we want to use the same words a s before (old words still mean the same thing) and just ADD to it, it will be like using x86-64. itanium would be like changing and re-defining all of the words, so "00000dog" now = feline that poos in a box of sand and says LOL in a lot of pictures (a cat).
                                        the above would be :
                                        0000000i 0000like 0000food
                                        00000you 00000are 0000nice
                                        0000debt 000000is 00000gay
                                        but we now can say things like:
                                        0000000i 0000love 000000my joystick
                                        00topcat 00000has 0000nice vehicles
                                        if you ignore the spaces, the old 4-word things become double the length:
                                        000ilikefood
                                        0000000i0000like0000food
                                        0you0arenice
                                        00000you00000are0000nice
                                        debt00is0gay
                                        0000debt000000is00000gay
                                        and if the space needed is equivalent to memory, then moving to 64 bit doubles the memory, but you can say more things which in some cases allow using fewer words (in stead of 00up0anddown , you say diagonal). however, with the complexity of an operating system, adding 4 zeros to everything is a lot faster and easier to manage (fixing bugs) then optimizing by using the new words 100% of the time.
                                        0000000i0000hope0000this000clears00things0000000up
                                        (i looked it up, x86-64's legacy mode works like this)
                                        sigpic
                                          "But a good programmer could put more instructions in one 'word'." = "you can say more things which in some cases allow using fewer words"
                                          Which validates what I said here..
                                          https://www.badcaps.net/forum/showpo...1&postcount=33
                                          - Dr Seuss
