Re: emachine e725 freezes randomly
That's true if you don't use 98Lite!
98Lite removes a bunch of stuff that makes it vulnerable to malware and basically turns Windows 98 into a portable OS with basically only the kernel and app running.
Then afterwards, Windows 98 requires one more tweak with the networking settings, because, yes, it will be slow as heck, there's an issue with the default settings that causes broadband to crawl at 2 Mbit or less!
98Lite will work like a charm on Intel 845 boards and PIII boards!
After I got all the tweaks I needed, including from MSFN, the 98Lite'ed Windows 98 SE on the MSI 845E Max with a Northwood beats even Windows 2000 in benchmarks and is faster overall.
The only time I get errors is when the Northwood temp starts getting too high when I'm Prime95'ing it.
It starts getting finicky at 2.8 Ghz and I need a lot of cold air for Prime95 to pass.
thanks all, i finally gave this up.i just told the person to buy another laptopLeave a comment:
Laptops usually use thermal pads.
Examples:
http://cgi.ebay.com/310238536049
http://cgi.ebay.com/270630084432
http://cgi.ebay.com/190539759573
.Leave a comment:
It's not unrelated.
You don't have enough RAM to run Win7 smoothly particularly after you start adding programs to it.
You have the minimum requirement which just enough for Win7 to run without adding any[or many] other programs to it.
Pretty much any 'resource happy' program [a bulky anti-virus for example] would be enough to cause your system to freeze.
Try running the system from a live CD and see if it freezes with that.
If it doesn't the issue isn't hardware.
.Leave a comment:
It is known as
Thermal Compound
Thermal Grease
Thermal PasteLeave a comment:
i opened the laptop, the paste (whitish) on the processor seems to be dried up, what is it usually called, i need to get it and re-paste first.
the laptop is new and virtually have no dust clogging anywhere. thanksLeave a comment:
.Last edited by PCBONEZ; 06-25-2011, 03:49 PM.Leave a comment:
None of it does sadly a moderator should move those posts out.
as for your machine coolcurrent have you had any issues with this machine in the past like blue screens and resets?
Also go to start Control Panel then Administrative Tools then Event Viewer then windows logs then system and look for any errors regarding disk.Last edited by joshnz; 06-25-2011, 01:00 PM.Leave a comment:
i don't understand, how does all these relates to emachines freezingLeave a comment:
Ever hear of when it works don't fix it?
Good plan when you run a business.
.Leave a comment:
I will avoid getting into such discussions in the future, because they don't change the systems i run in any way and just cause unneeded clutter.Leave a comment:
Yes this 32bit vs. 64bit discussion is interesting. However it is not the purpose of this thread.Leave a comment:
mods could you clean this thread up and put the posts in a 32 vs 64 thread this guy coolcurrent may have already left because of the thread been taken over.Leave a comment:
Now that the train wreck is over....
coolcurrent, any updates?
.Leave a comment:
RD I was specifically talking about device drivers.
Win7 does not support 32-bit drivers at all.
http://www.techsupportalert.com/cont...plications.htm
what "legacy mode" in the cpu does is add the zeroes. but once you start the computer in a mode, it stays in that mode until reboot. so once you start 64, you have to always be 64.
also, since 7 is a hybred kernel, other things besides the OS may interact with drivers and need 64 bit capabilities
also, there may be bits that making 64 bit and using 64 bit instructions improved performance or functionality enough to warrant changing. but so much does not benefit enough to warrant that it rounds off to double . no big enough to make a large impact on memory usage, but enough to mess up drivers.Last edited by ratdude747; 06-25-2011, 03:47 AM.Leave a comment:
Win7 64-bit does not support 32-bit drivers at all.
http://www.techsupportalert.com/cont...plications.htmLast edited by PCBONEZ; 06-25-2011, 03:41 AM.Leave a comment:
Don't bet on it. Using virtual machines eats up a lot of RAM. But at least i don't have to worry 'bout no compatibility issues.
This is true, sans VMWare i can do most of my stuff in 2GB (on my laptops). Though i DO feel the pagefile every once in a while with 2 gigs. 8GB on the main machine and pagefile turned off. I have never seen an "out of memory" message, but i did use up to 7.3GB once. Don't ask me what i was up to.Again, RAM is still cheaper than CPU power.
by grosseaderHello everyone, i got this mobo for long time, now i decided to rearrange some hardware and build a office pc, but 1 week so far, this motherboard drives me crazy.
What is the issue:
PC freezes randomly. While loading win, while installing win, while in windows , and just once did it while in bios.
Hardware:
MSI B450 Gaming Plus Max , MSI A320m A-pro
BIOS : 7B86vHG - latest
CPU: Ryzen 3 1200, 3200G , Ryzen 5 3500x, Ryzen 5 5500
GPU: Vega 7 in 3200g and MSI 1060 6GB
RAM: 2x8 ADATA spectrix 3000 , 2x8 SiliconePower 3200
...01-30-2023, 03:24 PM -
by pcwhiz24This issue has me stumped! I have this Lenovo IdeaPad and the SSD (NVME) keeps on randomly disconnecting. It'll stop being detected in BIOS randomly and when I turn it off and back on sometimes it'll detect again and boot up just fine...only to crash after a few minutes and either boot again or stop being detected.
Things I tried so far:
- Reset the CMOS by removing battery, held power buttons 60 seconds, all that jazz.
- BIOS is fully updated (had to use CHA341 because I bricked it the first time trying to update it)
- Tried multiple working NVME drives... -
by amingpxhi guys...hp probook 6555b freezes randomly and no key on the keyboard doesnt work..sometimes after 30min somtime after 60min and sometime after 20min..i chech out pads on.the cpu and vga chip..fan is ok...i flash bios..i changed ram..hard...i dont know any more..help me
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by hinisaI'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...-
Channel: Troubleshooting & Designing Networks
- Loading...
