emachine e725 freezes randomly
  • coolcurrent
    • Oct 2010
    • 98
    An emachine e725 less than 1year freezes randomly, mostly when it has booted to desktop, about lest than five minutes later.
    its can be started at safe mode and will work well, but not in normal mode. sometimes, it freezes too even in safe mode.
    The emachine specs
    1.0G Ram
    2.0Ghz Processor
    160GB Hard drive
    when i try to boot from cd, it doesn't recognize the cd. they appear blank.
    when could be cause this? overheat?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: emachine e725 freezes randomly
    That sounds more like a malware problem than a hardware problem.
    Whoever has time to help you will need to know what OS you are using, what anti-virus and anti-malware you have installed, and probably your browser & version.
    Mann-Made Global Warming.
    - Dr Seuss
    • coolcurrent
      • Oct 2010
      • 98
      am using win7 ultimate and using Rising antivirus. browser is firefox. the laptop freezes immediately after showing the desktop
      • coolcurrent
        • Oct 2010
        • 98
        i have scanned for virus, malware , spyware and finally reformatted to be sure its not software related, but the problems still exist
        any ideas what to do next?
        • Dgtech
          E. Technician
          • Apr 2009
          • 1462
          • Steeler
          It's an e machine. What would you expect?
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Yes, find out what the motherboard is and inspect the caps.
            - Dr Seuss
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              SHHH!
              The motherboard might not know it's in an e-machine.
              - Dr Seuss
              • c_hegge
                • Sep 2009
                • 5219
                eMachines = Flea machines
                • coolcurrent
                  • Oct 2010
                  • 98
                  this is not helping me, no need to post if you can't help
                  • acstech
                    GrumpyModerator
                    • Jul 2007
                    • 1432
                    Well, a computer that locks up could be most anything. I'd say a good first step, or what I would do in this case, would be to start taking it apart and looking for problems. Check for bad caps, fans not turning or barely turning, dust clogged heatsinks, etc.
                    A man convinced against his will is of the same opinion still.
                    • coolcurrent
                      • Oct 2010
                      • 98
                      thanks, i'll do that and get back to you tomorow
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        And run memtest.
                        A working TV? How boring!
                        • Dgtech
                          E. Technician
                          • Apr 2009
                          • 1462
                          • Steeler
                          The only reason I made the comment about Emachines is because I have seen problems that I wouldnt beleive I would see - only on emachines. The problem that you have could be anywhere from:
                          Reason # 1. cold solder joints on perriferal slots
                          to
                          Reason # 94. Bad hard drive with errors.
                          to
                          Reason # 122. System was built with barely enough "anything" to run.
                          All other reasons in between apply as well.
                          Sorry if I seemed to put down emachines but there's a reason why they are the cheapest ones to buy. Good luck finding what's wrong. If you do, consider yourself lucky.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            My [vague] point was emachines mobos come from at least half a dozen manufacturers.
                            Some are complete crap but others aren't so bad.
                            - Dr Seuss
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Your 1 year old Acer/eMachine only has 1GB RAM.
                              Win7 is going to run like shit with 1GB RAM.
                              MS says minimum RAM for Win7 32-bit is 1GB and 2GB for 64-bit.
                              What MS says for minimum is always about 1/2 what is needed for a smooth running system.
                              Been like that since Win95 if not before.
                              http://windows.microsoft.com/en-US/w...m-requirements
                              - Dr Seuss
                              • lti
                                • May 2011
                                • 2557
                                That is how all modern prebuilt computers that are reasonably affordable are designed. Computers with 32-bit Windows 7 have 1GB of RAM, and computers with 64-bit Windows have 2GB of RAM. If you want more RAM, you have to pay a ton of money for a computer that is basically a $300 computer with a multi-terabyte hard drive. You could buy a $300 computer and upgrade the RAM and get the same performance as a $600 "media center" computer.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Yeah, they used to sell W98 machines new with 16Mb RAM too.
                                  "reasonably affordable" = cheap, bottom line, just enough to run.
                                  It isn't going to run Win7 smoothly once apps are installed that actually use RAM.
                                  Either get more RAM or get XP.
                                  - Dr Seuss
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    Or you could build the damn thing yourself and get rid of all the "it won't run this it won't run that i can't upgrade it" shit. Win7 x64 runs perfectly fine on 2GB btw.
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Good point, you're right...
                                      And now can you tell us ~why~?
                                      I'll give you a hint.. It explains why saying 1GB for the 32-bit is a crock.
                                      - Dr Seuss
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        32-bit was kept for the ignorant masses.
                                        • grosseader
                                          MSI B450 Gaming Plus Max - freezes randomly
                                          by grosseader
                                          Hello everyone, i got this mobo for long time, now i decided to rearrange some hardware and build a office pc, but 1 week so far, this motherboard drives me crazy.
                                          What is the issue:
                                          PC freezes randomly. While loading win, while installing win, while in windows , and just once did it while in bios.
                                          Hardware:
                                          MSI B450 Gaming Plus Max , MSI A320m A-pro
                                          BIOS : 7B86vHG - latest
                                          CPU: Ryzen 3 1200, 3200G , Ryzen 5 3500x, Ryzen 5 5500
                                          GPU: Vega 7 in 3200g and MSI 1060 6GB
                                          RAM: 2x8 ADATA spectrix 3000 , 2x8 SiliconePower 3200
                                          01-30-2023, 03:24 PM
                                        • pcwhiz24
                                          Lenovo IdeaPad 3 14ADA05 NVME keeps randomly disconnecting
                                          by pcwhiz24
                                          This issue has me stumped! I have this Lenovo IdeaPad and the SSD (NVME) keeps on randomly disconnecting. It'll stop being detected in BIOS randomly and when I turn it off and back on sometimes it'll detect again and boot up just fine...only to crash after a few minutes and either boot again or stop being detected.
                                          Things I tried so far:
                                          - Reset the CMOS by removing battery, held power buttons 60 seconds, all that jazz.
                                          - BIOS is fully updated (had to use CHA341 because I bricked it the first time trying to update it)
                                          - Tried multiple working NVME drives...
                                          04-08-2025, 06:59 PM
                                        • amingpx
                                          hp probook 6555b freezes randomly
                                          by amingpx
                                          hi guys...hp probook 6555b freezes randomly and no key on the keyboard doesnt work..sometimes after 30min somtime after 60min and sometime after 20min..i chech out pads on.the cpu and vga chip..fan is ok...i flash bios..i changed ram..hard...i dont know any more..help me
                                          04-03-2020, 05:38 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • hinisa
                                          Xiaomi router freezes at boot after re-capping
                                          by hinisa
                                          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                          07-08-2023, 05:58 AM
