Duron Burnt?
  • doggyfreestart
    • Feb 2006
    • 10
    Duron Burnt?
    Well, I just found an MS-6378 V1.0 on the local recycling centre, with CPU & RAM. It was POSTing, but had 7 pcs bulged Chssi 1500uF 10Vs . I had some Frolyt (German manufacturer) 1500uF 10Vs lying around, so I installed them. Result: No POST. Later I discovered, that these have a rather low ripple rejection, so possibly not suitable for motherboards.
    OK, then I bought Rubycon ZL 1500uF 10Vs. No POST either.
    So where should I look for the error? May I have killed the CPU with the wrong caps? How sensible are the Durons against ESD? (I just had it lying on the desk while soldering.)
    I know it was an idea to put just ther first caps I've found, but it shouldn't kill the CPU, should it?
    Bye:
    Georg
  • davmax
    • Dec 2005
    • 899
    Re: Duron Burnt?
    Do your systen fans start? What if anything happens when power is applied.
    It is possible you created a short circuit when replacing the caps. A short can stop the power supply, it will self protect.
    Did you read the Recapping Procedure and the type of caps in the FAQ section of this forum?
    Re ESD and CPU it depends what cautions you took like a wrist strap. Working of carpeted floors is real risky.
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    Samsung 18x DVD writer
    33 way card reader
    Windows XP Pro SP3
    17" Benq FP737s LCD monitor
    • doggyfreestart
      • Feb 2006
      • 10
      Re: Duron Burnt?
      Fans start OK. Does this signal that the PSU is OK? No sound, no beep, nothing on the screen.
      Some vias were a bit messy, when soldering in, so the procedure in the FAQ couldn't be followed exactly. I soldered these holes with the "tweeze-in" method. But no raw force applied.
      There are no shorts on the caps, I can measure 1.65V on the positive side.
      I used genuine Rubycon ZL caps, the same rating as the Chssis were before.
      I have an ESD-Safe floor in the room I use for soldering, but no wrist strap. I wasn't able to kill anything like this yet, and I'm usually repairing mobile phones.
      It's my second recap, the first went like a breeze... And never had ESD probs before, respectively.
      Could the wrong Frolyt caps have killed the poor Duron?
      • davmax
        • Dec 2005
        • 899
        Re: Duron Burnt?
        So you have fan running and 1.65V on VRM output caps. That sounds like PS is OK.
        It is hard to imagine how the caps would kill CPU. Maybe the wrong impedance charcteristics caused the VRM circuit to oscillate and generate excessive voltage. That is about the only possibility.
        Now you have better caps you need to borrow another CPU if you are sure the supply voltage is 1.65V.
        Wishing you success.
        Nvidia 8500GT 256Mb
        33 way card reader
        Windows XP Pro SP3
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          Re: Duron Burnt?
          I've found that with problems like these, if I just go back and reflow the solder at each of the joints I was working with, the problem is usually solved. Also, check to make sure that none of your soldering work ran over any other traces, or that you burnt any other traces.
          Ludicrous gibs!
          • MD Willington
            • Sep 2004
            • 702
            Re: Duron Burnt?
            RMA test procedure for socket A processor.
            Ya'll think us folk from the country's real funny-like, dontcha?
            The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
            • doggyfreestart
              • Feb 2006
              • 10
              Re: Duron Burnt?
              None of the RMA things apply. The resistance shows some 100 ohms at the beginning, then goes higher. Nice description, by the way.
              I've just tried the CPU in my desktop, and it didn't make any sound, either.
              So the moral of the story is: always use genuine, trusted caps, otherwise it can cost you a CPU/Mobo or both. And you were working for nothing. Sad but true. And now I drink a glass of wine to tribute my first killed Duron.
              • doggyfreestart
                • Feb 2006
                • 10
                Re: Duron Burnt?
                After having the wine, I went to the computer cemetery again - and I've found an Epox K8A3+ MoBo. So I put the CPU inside - nothing to loose - and it started POST-ing, then asked for a floppy because of BIOS checksum error. OK, it's damaged as well - but at least it does something...
                Now I'm confused: I've tried that shitty CPU in 2 known good MoBos, set to 100 MHz FSB, 1.65 Vcore & reset CMOS, and no sign of life. But to display anything on the screen, the CPU has to be alive, hasn't? Pls help me out, I'm feeling stupid.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  Re: Duron Burnt?
                  when they die they usually die completely and stay dead..
                  make sure there is no thermal compound (esp silver) on the core bypass caps and l bridges.
                  overuse of compound can cause trouble and can even foul the socket.
                  • davmax
                    • Dec 2005
                    • 899
                    Re: Duron Burnt?
                    No need to feel stupid. There can be so many contributing factors, these are very complex systems. All you can do is work systematically noting what does and does not work. Always make sure all system voltages are correct.
                    Nvidia 8500GT 256Mb
                    33 way card reader
                    Windows XP Pro SP3
                    • electomech-fixer
                      First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                      by electomech-fixer
                      I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                      I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                      09-15-2025, 01:42 AM
                    • dicky96
                      Zotac GTX 260 burnt component - can anyone identify?
                      by dicky96
                      Hi guys
                      This Zotac GTX 260 had a high side MOFET on one Vcore VRM phase short circuit Drain to Gate (Not short Drain to Source)
                      This has burnt out the drive IC L3E (ADP3110A) and also an SOT-23 device very close to the driver IC. According to the PCB markings 'Dxxx' this is likely to be a diode.
                      Basically the VRM has 4 phases, two powered from one 6 way connector and two powered from the other 6 way
                      I would assume each pair of phases are basically identical, the burnt out phase has SOT-23 devices WW1 plus the burnt one.
                      The good phase...
                      12-01-2021, 01:02 PM
                    • swimllamaswim
                      Precision 5550 LA-J191P No Power, Burnt ISL9538
                      by swimllamaswim
                      I picked up this Precision 5550 to fix up recently, and found that the ISL9538 chip was burnt on pin 14 (CSIN). The two left side Type C ports negotiate at 20v, and the right side one only negotiates at 5v. I also found the EMI protection diode, DT35, was burnt on that side. I pulled the ISL9538 off, checked for any other obvious shorts, repaired the pad, and put a new one on. Now, I still do not get power, and there is a rapid clicking sound from somewhere on the board that I can't pinpoint.
                      Here are the voltages measured at that chip:
                      To note, DCIN at Pin 17 is low,...
                      09-21-2025, 12:26 PM
                    • mferna14
                      Apple MacBook Pro A2338 820-02773-A AON Rail burnt
                      by mferna14
                      Hi Dear Friend., I am working on a Apple MacBook Pro A2338 820-02773-A. The history was that the AON Rail on the Trackpad connector JT400 was burnt. After I removed the burnt connector, I tested with the meter & no shorts. Connected the USB C power & all booted fine, no problems at all. I soldered a New TP connector put in the old trackpad with a brand new Flex cable. The laptop beeped in the start but no display. I removed the connector & the display was fine again. USED a known good Trackpad & a Flex cable, even with this still the same problem. I checked the connector whether...
                      06-25-2025, 11:26 AM
                    • nobbnobb1
                      Bose Acoustimass 10 IV Subwoofer No Sound. Help with burnt component identification?
                      by nobbnobb1
                      I picked up this used Bose Acoustimass 10 IV speaker system. Speakers seem to work fine, but the subwoofer does not make any noise. So I took apart the unit and found some obviously failed (burnt) components:
                      - 1x 3.14 A @ 250V main circuit fuse
                      - 1x bridge rectifier GBU601. there's actually two of these on the board, one is obviously burnt and the other does not seem to have any anomalies like shorts. However I figure may as well replace both.
                      - 2x diode. This is tricky because the only markings I see on it are: "617 402". No current rating or anything else....
                      11-16-2024, 09:56 PM
