Firefox 4... How do I restore bookmarks??
  • Maxxarcade
    • Jul 2006
    • 973
    Apparently there is no way to import bookmarks into FF4 from the .Json file that FF3 made? Do I need to install FF3 just to get them copied over?
    I wasn't expecting this to happen... Maybe I need to use the Sync option?
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Firefox 4... How do I restore bookmarks??
    go to my computer, put %appdata% in the address bar, then navigate to Mozilla\Firefox\Profiles\[random letters].default\bookmarkbackups
    put the backed up .json in there and you should be good to go..
    if there are some other .json's in there already, delete them (or move them somewhere else just in case)
    i usually export my firefox bookmarks in HTML form from within firefox. much easier to work with.
    • Maxxarcade
      • Jul 2006
      • 973
      Figured it out... The Ctrl+Shift+B shortcut still works, despite the lack of an "organize bookmarks" menu item... Weird!
      • Hondaman
        Firefox is now SATANIC
        by Hondaman
        Now that I have your attention:
        In the last few days, it looks like Firefox has changed their software terms so they are now evil and WILL sell your data.
        I already use Palemoon for Win7 sometimes. Looks like I'll be switching to librewolf as well, as Youtuber Louis Rossman suggests. Palemoon still supports Win7, but sometimes pages don't work properly. The Google Chrome browser might also still work for Win7.
        I will have no choice but to upgrade my Firefox, so that I can copy dozens of tabs into a document or spreadsheet, or go through the history to...
        03-05-2025, 04:41 PM
      • Flasman90
        Macbook Pro DFU Restore Issues
        by Flasman90
        I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
        - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
        - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
        08-30-2025, 10:27 AM
      • iMuhtaseb
        820-02020 A2338 Restore/Revive Failed
        by iMuhtaseb
        A2338 - Pristine condition.. I took out of the board and inspected it.. nothing.. as if the computer is barely used even.
        Anyway, customer said they tried erasing/formatting it and it got stuck on Apple logo preventing to go further.. I asked them why they tried to erase it from the first place? They said it turned off randomly once.. then they erased it and it worked out for a few days then it shut off again..
        I put the computer in DFU; I downloaded the latest Ventura IPSW and restored it.. during the "Installing.." it restarts then it shows the exclamation...
        09-11-2023, 08:43 AM
      • lab10.haifa
        Macbook Pro A2338 820-02020 Stuck on RESTORE MODE
        by lab10.haifa
        Good day, friends. Got this problem with M1 macbook - it starts, chimes, tries to boot and stuck with a message "support.apple.com/mac/restore"
        It works with DFU mode, but it's cannot be restored. With "revive" function - same problem. Internal restore mode doesn't work, as well as Internet Recovery.
        There is no damage on the motherboard. No short circuits.
        Could it be a NAND problem? (but usually, if NAND is dead - mac simply wouldn't turn on)
        Thanks....
        10-08-2025, 02:55 AM
      • yheriatovych
        A2338 820-02020-A 5V, no screen, unable to revive/restore
        by yheriatovych
        Hi. I need some help troubleshooting the issue (which is a bit odd to my limited experience) with the A2338 Macbook.
        Initial symptoms:
        One day the laptop refused to wake up (as it seemed at first), spinning the fan on full blast, with no picture on the screen.
        Force rebooting didn't help. To check if it boots at all I connected the external display and surprisingly it booted to the system, and I was able to log in to the system.
        However, I noticed that it was in some weird state:
        • The fan was still blasting at full speed. It's blasting even when the system
        01-31-2024, 10:22 AM
