Anyone have a mod for these things or know of a replacement source for the pins?
Those f#@%&*n!! Intel LGA775 push pins..
Re: Those f#@%&*n!! Intel LGA775 push pins..
I know they sell a backplate kit with screws. Look around and you'll find it. Was something like $5 last time i checked.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company. -
I bought some of these:
http://cgi.ebay.com/Mount-Pin-Origin...item3f062ae495
they worked fineComment
Thanks bigbeark i couldnt find any on the bay here. I guess the usual slow boat from China applies?
939 DualCore AMD Opteron, 1800 MHz (9 x 200)
Abit AN8 / Fatal1ty AN8 SLI Series
3072 MB (PC3200 DDR SDRAM)
ATI Radeon HD 4300/4500 Series (1024 MB
Lian LI Aluminium mesh caseComment
https://www.badcaps.net/forum/showthread.php?t=11178
"I think but I am not 100% sure that the clips will work from socket 1156 and 1366 fans as well." -brethin
http://www.arctic.ac/en/p/cooling/spare-parts.html
Happy Hunting!
Toastveritas odium paritComment
The damn stock Intel cooler for my C2D makes my motherboard bend. It would be nice to put a backplate on it.Comment
Didn't Intel have a standard for "built-in" back plates when P4 was new? I remember older cases having standoffs right in the motherboard tray for the cooler to attach to.Comment
Yeah. There was nothing wrong with the socket 478 cooling system (apart from finger damage if you were dumb).
IMO there's something fundamentally wrong with all LGA775 cooling. I put my Scythe Mugen onto a P4 478 and it was quite warm with the processor doing 48C at 3.8GHz. On my E6550 (2.33 @ 3.6) load temps are 70-something celsius but the cooler is COLD. The CPU has been working fine for almost 3 years but still, something doesn't add up here.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
thermal resistance from die to slug.several methods i have seen to remove it.risky though.
IMO there's something fundamentally wrong with all LGA775 cooling. I put my Scythe Mugen onto a P4 478 and it was quite warm with the processor doing 48C at 3.8GHz. On my E6550 (2.33 @ 3.6) load temps are 70-something celsius but the cooler is COLD. The CPU has been working fine for almost 3 years but still, something doesn't add up here.Comment
P4s had integrated heatspreaders too and yet the transfer was much better. I did remove the top of a E2180 once... and it ended up with WORSE temps afterwards.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
I'm running the Mugen-II cooler on 775 and 115x Gigabyte boards.
These come with a very sturdy backplate and work very well.
Note: be sure to check for soldered cap stubs in the bracket field.
One of my GA boards was sticking up too high, so I snipped it down.
VRM cooling is no longer a problem on the newer boards with VRM heat pipes and a cross-flow cooler such as the Mugen-II.
I run mine with a pair of 800 rpm Scythe 120mm fans in push-pull.
This provides max cooling and silent operation.
I am accumulating a collection of push-pin stock coolers.
The ones that come with the quads have a copper core, the others are solid aluminum.
I keep these just in case I have a need for a service part on a stock machine.Comment
i'm using this
http://www.techpowerup.com/75688/Scy...Push-Pins.html
sucks that it seems to have disappeared from all shops..Comment
Got a few sets from this dealer http://cgi.ebay.com/Mount-Pin-Origin...item3f062ae495 very cheap, fast post
i might have to get some myself, as i found out that on my dad's 775 prescott 630, this happened:
the fans were running faster than usual, I assumed it was due to the hot temps in the attic. wrong.
what really was going on was one pin was worn and loose, and all of thermal paste had leaked to the bottom edge of the cpu... replacing the grease fixed the issue, but the pins on that cooler (scythe katina) are rather worn and beat up... i had to replace one stolen from a dud heatsink which i no longer have already.
i might consider 2 screw kits (I have a PDC 775 that i use) to eliminate this retarded designsigpic
(Insert witty quote here)Comment
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by Natob82Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
by ratdude747Got my butt kicked by windows 10 and intel last week.
I have an HDMI switch and splitter setup for an AV rig (church) that I was trying to use the windows 10 half of my Lenovo T440s with. However, the audio will not work; HDMI (displayport) audio doesn't show in device manager and Intel's Control Center shows the external display as not supporting audio. Direct connect it to things and (if memory serves) it does work.
Compounding the issue is that I'm forced to use Lenovo's drivers... as the generic intel ones refuse to install as they detect it's a lenovo system...-
by pkslowkSr. Motherboard Debug Error Code Solution
1 Intel 845 E9 Bios Related Problem
2 Intel 845 D4 CPU Socket Related problem
3 Intel 845 37 Bios Related Problem
4 Intel 845 7C Bios Related Problem
5 Intel 945GCPE 34 Bios Related Problem
6 Gigabyte 845 2 Ram Related Problem
7 IBM Server A6 A7 Ram Mismatch Problem
8 Asus 845 29 CPU Related Problem
9 Lenovo I946 97 C-Mos Jumper related
10 Gigabyte 845 A0 CPU Related Problem
11 Asrock G31M-VS D7 Bios Related Problem
12 Compaq 845 BD-70G B0 CPU Socket Related problem... -
by bbking67I managed to brick my Intel Dq77MK board flashing the bios via usb.
The problem is that the motherboard requires an 8mb and 4mb bin files, but I just have the original bios as supplied by Intel as a single file.
Can anyone supply the bins? or is there a way to extract the bins from the Intel single file?-
- Loading...
