Anyone have a mod for these things or know of a replacement source for the pins?
Those f#@%&*n!! Intel LGA775 push pins..
Re: Those f#@%&*n!! Intel LGA775 push pins..
I know they sell a backplate kit with screws. Look around and you'll find it. Was something like $5 last time i checked.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company. -
I bought some of these:
http://cgi.ebay.com/Mount-Pin-Origin...item3f062ae495
they worked fineComment
Thanks bigbeark i couldnt find any on the bay here. I guess the usual slow boat from China applies?
939 DualCore AMD Opteron, 1800 MHz (9 x 200)
Abit AN8 / Fatal1ty AN8 SLI Series
3072 MB (PC3200 DDR SDRAM)
ATI Radeon HD 4300/4500 Series (1024 MB
Lian LI Aluminium mesh caseComment
https://www.badcaps.net/forum/showthread.php?t=11178
"I think but I am not 100% sure that the clips will work from socket 1156 and 1366 fans as well." -brethin
http://www.arctic.ac/en/p/cooling/spare-parts.html
Happy Hunting!
Toastveritas odium paritComment
The damn stock Intel cooler for my C2D makes my motherboard bend. It would be nice to put a backplate on it.Comment
Didn't Intel have a standard for "built-in" back plates when P4 was new? I remember older cases having standoffs right in the motherboard tray for the cooler to attach to.Comment
Yeah. There was nothing wrong with the socket 478 cooling system (apart from finger damage if you were dumb).
IMO there's something fundamentally wrong with all LGA775 cooling. I put my Scythe Mugen onto a P4 478 and it was quite warm with the processor doing 48C at 3.8GHz. On my E6550 (2.33 @ 3.6) load temps are 70-something celsius but the cooler is COLD. The CPU has been working fine for almost 3 years but still, something doesn't add up here.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
thermal resistance from die to slug.several methods i have seen to remove it.risky though.
IMO there's something fundamentally wrong with all LGA775 cooling. I put my Scythe Mugen onto a P4 478 and it was quite warm with the processor doing 48C at 3.8GHz. On my E6550 (2.33 @ 3.6) load temps are 70-something celsius but the cooler is COLD. The CPU has been working fine for almost 3 years but still, something doesn't add up here.Comment
P4s had integrated heatspreaders too and yet the transfer was much better. I did remove the top of a E2180 once... and it ended up with WORSE temps afterwards.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
I'm running the Mugen-II cooler on 775 and 115x Gigabyte boards.
These come with a very sturdy backplate and work very well.
Note: be sure to check for soldered cap stubs in the bracket field.
One of my GA boards was sticking up too high, so I snipped it down.
VRM cooling is no longer a problem on the newer boards with VRM heat pipes and a cross-flow cooler such as the Mugen-II.
I run mine with a pair of 800 rpm Scythe 120mm fans in push-pull.
This provides max cooling and silent operation.
I am accumulating a collection of push-pin stock coolers.
The ones that come with the quads have a copper core, the others are solid aluminum.
I keep these just in case I have a need for a service part on a stock machine.Comment
i'm using this
http://www.techpowerup.com/75688/Scy...Push-Pins.html
sucks that it seems to have disappeared from all shops..Comment
Got a few sets from this dealer http://cgi.ebay.com/Mount-Pin-Origin...item3f062ae495 very cheap, fast post
i might have to get some myself, as i found out that on my dad's 775 prescott 630, this happened:
the fans were running faster than usual, I assumed it was due to the hot temps in the attic. wrong.
what really was going on was one pin was worn and loose, and all of thermal paste had leaked to the bottom edge of the cpu... replacing the grease fixed the issue, but the pins on that cooler (scythe katina) are rather worn and beat up... i had to replace one stolen from a dud heatsink which i no longer have already.
i might consider 2 screw kits (I have a PDC 775 that i use) to eliminate this retarded designsigpic
(Insert witty quote here)Comment
This specification for the HP ProDesk DESKTOP BUNDEL (P5K01EA+M1N98AT) ProDesk 400 MT Intel Core i3-6100 + E232 monitor can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk DESKTOP BUNDEL (P5K01EA+M1N98AT) ProDesk 400 MT Intel Core i3-6100 + E232 monitor boardview and ProDesk DESKTOP BUNDEL (P5K01EA+M1N98AT) ProDesk 400 MT Intel Core i3-6100 + E232 monitor schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...09-12-2024, 03:28 PM
This specification for the HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC boardview and Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will...09-12-2024, 03:36 PM
This specification for the HP xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation boardview and xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-12-2024, 03:36 PM
This specification for the HP xw8600 Intel Xeon Quad Core 5450 3.00GHz 2GB/500GB No Graphics DVD+/-RW WVST Bus Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the xw8600 Intel Xeon Quad Core 5450 3.00GHz 2GB/500GB No Graphics DVD+/-RW WVST Bus Workstation boardview and xw8600 Intel Xeon Quad Core 5450 3.00GHz 2GB/500GB No Graphics DVD+/-RW WVST Bus Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-12-2024, 03:36 PM
- Loading...
