Cool & Quiet? Not very
  • bigbeark
    • Jan 2010
    • 661
    I have built up two AMD boxes recently, one the EVGA NF41 (939) and the other an Asus M2A-VM (AM2).
    I put AMD OEM fan/heatsinks on both. Both run cool, but the fan noise is ridiculous. Both fans have a pretty extreme angle on the fan blades.
    I am running Ubuntu 10.10. I looked up Cool 'N Quiet. Wikipedia entry suggests fan speed is determined by onboard thyristor, but both these are running cool as per BIOS CPU temps.
    The EVGA fan is running at 3100, don't know about the ASUS.
    I've gotten spoiled by the Acer Aspire M1640 that I assembled from parts, which runs really quietly.
    Why so much fan noise?
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: Cool & Quiet? Not very
    Small fans make more noise than big ones to achieve the same cooling.
    Is there any fan control in the bios that you can enable, or are you running them full speed all the time?
    A man convinced against his will is of the same opinion still.
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      Odd... every AMD system I've built has been damn near silent. Perhaps the fan control isn't working? Check in the BIOS, like ACS suggested.
      Ludicrous gibs!
      • c_hegge
        • Sep 2009
        • 5219
        I recently built a quad-care phenom system (Skt. AM3). The stock cooler made a rediculous amount of noise. The fan was spinning close to 4000rpm and the idle temp was around 40*C. It got replaced witha CoolerMaster Hyper TX3. It was dead silent and the idle temp was only 30*C
        • toastygoodness
          • Jul 2005
          • 813
          usually on a lot of motherboards the PWM/CoolnQuiet must be turned on. Also, if you bent a fin or somethign on those cheap fans, it will make noise.
          • yyonline
            • Jul 2009
            • 692
            Foxconn fan? AMD uses them on the stock heatsinks sometimes. Fans from Delta, Adda, NMB, Nidec, AVC are usually decently quiet for what they are. They're not quiet fans by any means, but they don't usually make an unacceptable racket for an "off the shelf" computer. Whatever bearings they use in the Foxconn fans are awful though. They're noisy and one day seize up without warning.
            • Krankshaft
              • Jan 2007
              • 2328
              If the fan seems to be running at full speed as others said check the bios. This can also happen if the thermal compound isn't adequately making contact and the CPU temps are getting too high. The mobo will throttle the fan up to cool it down.
              I got the Intel CPU for my current rig on e-bay used just the CPU no heat sink so I never tried the stock cooler. I went with an Arctic Cooling Freezer 7 Pro. It's also compatible with AMD processors it's around 29 bucks and is beyond silent. Most if not all well designed aftermarket coolers will outperform the manufacturers penny pinching stock cooler.
              • delaware74b
                • Apr 2009
                • 628
                I rebuilt my desktop which is in my bedroom. I used the Asus M4A785TD-V EVO board. I have the NZXT Nemesis Elite case (3 120mm case fans). The mobo has only the CPU fan. Stock CPU fan (AMD Athlon II X4 640 Propus 3.0GHz). Quieter than my old setup (Asus A8N-SLI/Athlon64 3400/Asus 9500GT video card). Rear fan runs on the mobo with Quiet&Cool enabled in BIOS. The side and front fans run off my TrashPowerII-550's 'fan only'. System temps are good (below 40C even on prime95).
                It runs 24/7, mainly used as the bedroom TV PVR. It's a shame because the hard drive (640GB Caviar Black SATA 3Gb) is noiser than all 4 fans!
                BTW, I pull the power supply every 6 mo and give it a thorough cleaning and going to recap it next time its out.......
                Stupidity should be a crime, especially for drivers. I have NO patience for them.
                • bigbeark
                  • Jan 2010
                  • 661
                  Thanks for the suggestions. I did look into the BIOS and found that SmartFan is not enabled by default.
                  So I enabled Smart Fan on both motherboard fans.
                  Now the fans speed up and slow down constantly, sounding like a wind whistling around your house on a cold winter night.
                  The stock fan has to go. This is on the 939 EVGA that I am still going to recap.
                  I'll try the Asus board next, but it's compromised by the X300 integrated graphics that don't play nicely with Linux.
                  • kikkoman
                    • Jul 2007
                    • 691
                    speedfan!
                    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
                    • delaware74b
                      • Apr 2009
                      • 628
                      I'm planning to disable the onboard Radeon graphics and reusing the 9500GT card once I recap the TP-II. The 9500GT uses a large 90mm fan (it barely fits on the card, but the fan is stock along with the flower-shaped copper heatsink).
                      • dood
                        Deputy dood
                        • Mar 2004
                        • 2462
                        Odd... maybe I'm just not very sensitive to fan noise. I hear the Dell small formfactor machines rev up and down constantly, but never any AMD system I've built. Maybe it's different now... the last machine I put together was about 3 years ago.
                        Ludicrous gibs!
                        • bigbeark
                          • Jan 2010
                          • 661
                          So today I put a PCI-E card in the Asus, overriding the ATI x300 OB video.
                          The noise went way down. I guess the constant video errors the x300 was logging was stressing the board. So this one is now usable!
                          The EVGA I will put aside til I recap it. I suspect the SACONS are causing the cycling fan speeds
                          • honigmann
                            Dell 5591 overheating in memtest86+ but cool running Linux Mint - What causes this?
                            by honigmann
                            This machine comes with the i7-8850H, no internal drive and no battery installed, the bottom cover removed, an original Dell power supply is used. I just installed 8GB RAM, ran memtest86+ and noticed a power draw of about 40-50W. Accordingly within minutes the temperature went up to just below 100 degrees with the fan spinning wildly. Same thing when I enter the BIOS (1.20.0), around 40W power draw.
                            Next thing I tried was an install stick with Linux Mint on it. Initially I am also at around 40W but with idle desktop (Xfce) it draws just 6,5W. Is this a BIOS issue? Version 1.34 is...
                            09-23-2024, 08:51 AM
                          • FALKLAN
                            Running Line Voltage and Integrating LED Pods - Automotive
                            by FALKLAN
                            Howdy everyone! I hope all is well where ever you are!
                            I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                            I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                            02-05-2025, 12:30 AM
                          • coinwizx
                            Corsair HX1200 connected w EVGA molex cable, 12V pin back feeded to 5V. Anybody has experience in this damages repair?
                            by coinwizx
                            The power supply is 2020 Corsair HX1200 modular power supply.
                            Cause of damage: I connected EVGA molex cable to the Sata port and test it with a ATX tester. Since the pin out on the EVGA is wrong, result in the 12V pin shorted to the 5V pin, in the 12V back-feeded to the 5v port.
                            Damage: Power supply shorted out, shut off itself internally, damaged the 5v or 3v rail or the monitoring circuitry. The self protection circuit shut off the power supply when power up because it detected some abnormal/defect. I waited a few minutes, let it self reset then try to re power up....
                            09-15-2025, 12:46 PM
                          • coinwizx
                            NZXT C850 connected w EVGA molex cable, 12V pin back feeded to 5V. Anybody has experience in this damages repair?
                            by coinwizx
                            The power supply is 2024 newest version of NZXT C850 modular power supply.
                            Damage: Power supply shorted out, shut off itself internally, damaged the 5v or 3v rail or the monitoring circuitry. The self protection circuit shut off the power supply when power up because it detected some abnormal/defect. I waited a few minutes, let it self reset then...
                            09-15-2025, 12:44 PM
                          • dumblejd
                            rtx 2080 GPU capped at 60 degree
                            by dumblejd
                            My friend has a evga rtx 2080 super, and with liquid cool backplate. I installed for him. 4 month ago it runs good, and recently idk if he played with msi afterburner or not, the gpu slow it's core frequency when it's over 60 degree. I reset setting in msi afterburner, still the same.
                            here is a video of it running stress test, the usage is always 100% for sure, but core frenquency drop to 300mhz (should be over 1600mhz normally), when it hit 60 degree.
                            https://imgur.com/a/gLMfJid
                            at very beginning of stress test, the frequecy can reach 1600+, but as...
                            12-11-2022, 11:17 PM
