Computer Shuts Down and won't restart with out unplugging.
  • Adam Zonker
    • Dec 2005
    I have an Enermax 351 p-ve. and an Asus Cusl-2 motherboard. Pentium 111 933 .Not overclocked.
    It will just randomly shut off as if I did pull the plug. And it will not start untill the plug is pulled and left for a while. Or I shut off the power supply using its switch and leave it off for a while, usually half an hour. I can leave it off over night when the room temp is 50 F. and it will not start in the morning unless I have "pulled the plug" .
    Any ideas as to the cause?
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Computer Shuts Down and won't restart with out unplugging.
    Sounds like a PSU problem, most likely.
    Ludicrous gibs!
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Yea, I had a real cheap L&C PSU do exactly that...
      And also a Nexus PSU with the same behaviour, both due to bad caps and problem solved by swapping them out...
      • PeteS in CA
        • Aug 2005
        • 3583
        • USA, Unsure of Planet
        I can think of two protection mechanisms that can cause this kind of latching into an off state. The first is over voltage protection. If one of the main O/Ps - +3.3V, +5V, or +12V - go out of regulation high, the OVP circuit shuts down the P/S and latches it off. Usually cycling AC power for a minute or so will reset the latch. Crap caps could allow the ripple amplitude to exceed the OVP threshold. The other possibility is over temperature protection. OTP would also latch the P/S off. Likely cause of OTP trip would be a bad fan, dust compromising the effectiveness of the heatsink, or a fan speed control circuit that doesn't increase the fan speed as the temperature rises. Given the half hour necessary to reset the P/S, I'd guess that the problem is OTP if the P/S is the problem.
        PeteS in CA
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          just had an enermax psu here with intermittant shutdown.
          had a bad fan and crap caps.had 2v p-p on +5
          • Newbie2
            • Sep 2005
            • 885
            Got some pics?
            I wanna see.
            My gaming PC:
            AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
            ASUS M4A77TD AMD 770 AM3 Motherboard
            PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
            G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
            TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
            WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
            ASUS Xonar DG 5.1 Channel PCI sound card
            Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
            Antec Three Hundred Mid-Tower Case
            Microsoft Windows 10 Pro 64-bit
            Microsoft Windows 7 Ultimate SP1 64-bit
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              Originally posted by Newbie2
              Got some pics?
              I wanna see.
              already fixed and gone.
              got a better one to post later though.stay tuned!
              • Adam Zonker
                • Dec 2005
                Gentlemen
                Thankyou all for your fast responses.
                I pulled out the PS and opened it up. Blew out the dust and I could see TWO BAD CAPS, one large one and one Small one. Both were domed (bulged) and had what looked like rust on top.
                The power supply never felt hot when I touched it after it would shut off.
                I went out and bought a new Enermax Liberty 500 watt 130$ Canadian.
                More than I need for this computer, but I am thinking about repairing the old power supply and putting it back in, saving the new one for a new computer I hope to build in the new year.
                With the new PS installed it booted fast, no hangups as before.
                Okay so I have a soldering gun, do I dare try to replace the caps on my own? What am I looking at for skill level?
                Thank you ever so much for the fast help.
                Ps: My computer started giveing me the shutdowns last Feb. When I took it in to have the PS tested at the store I bought it from, the guy just pluged in a tester and said the PS was good. So I spent almost a year checking out the Bios, memory, fans, off on switches, heatsink/thermal compuound, motherboard and on and on.
                When my 12 year old son gets home tonight and I tell him I fixed the computer, he will just roll his eyes and say ya dad just like everytime before.
                HE HE . I think I did this time though.
                Adam Zonker
                Southern Alberta Canada
                20F clear skys
                • Newbie2
                  • Sep 2005
                  • 885
                  I'm guessing those two failed caps are made by PCE-TUR, a bad cap manufacturer.
                  What is the wattage of that soldering gun? We normally use soldering irons here but maybe that soldering gun can do the job, but we recommend 60-watts as the wattage for the soldering iron or maybe soldering gun.
                  Can you please post the capacitance and voltage of the two bad caps? That information will be useful.
                  Last edited by willawake; 12-31-2005, 05:17 AM. Reason: long quote of post #8 removed
                  My gaming PC:
                  • Adam Zonker
                    • Dec 2005
                    Newbie2
                    Your guess is right they are PCE TUR
                    Here is what it says on the Caps.
                    The small one:
                    105 C
                    0003
                    PCE TUR
                    1000 UF
                    10V
                    VENT
                    The large one:
                    105c
                    0002
                    3300UF
                    10V
                    VENT
                    The soldering gun I have is A Weller
                    60A 120V 2.5
                    • SarcasticOP
                      iPad Pro 12.9 (6th Gen) screen shuts off after unplugging device
                      by SarcasticOP
                      Greetings,
                      I have an iPad Pro 12.9" 6th gen tablet that had a screen replaced about 10 months ago at a repair shop and last week the screen went blank during use. The device was still on, notifications played sound for example. I have replaced the screen twice, both screens are working until I unplug it, at which point I can see that screen is on but is all black. If I press the power button, the backlight goes off, and when I press it again, the image appears for half a second and then the screen goes back to being black but on. This issue is not present at all when the iPad...
                      10-24-2024, 11:55 AM
                    • shouri
                      Dell latitude e5490 auto restart
                      by shouri
                      Hi guys, can someone help me?
                      I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
                      Board model is dm70 la-f401p rev:1.0 2017-09-20.
                      At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
                      After a few days test, is seems ok.
                      Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
                      12-10-2024, 09:27 PM
                    • pfrcom
                      Asus P8Z68-V/Gen3, after saving UEFI settings, shuts down, doesn't restart
                      by pfrcom
                      I've tried all BIOSes available to download, most recently first release version 0301, using an i3-2100
                      For each try, after externally reprogramming its Winbond 25Q64BV (DIP8) with TL866IIplus
                      Always same outcome - after Save & Exit, board shuts down and doesn't restart
                      If I press onboard Power button, it'll start up then shut down again
                      After jumpering CMOS Clear, it'll start to UEFI settings then repeat same behaviour
                      It's had a new CR2032 fitted
                      Closer examination found a second flash IC, a soldered...
                      07-29-2021, 02:46 AM
                    • fulepost@outlook.com
                      Samsung "QE" series QE55Q70RATXXC Intermittant restart in "home mode".
                      by fulepost@outlook.com
                      Dear all.
                      I'm a less knowledgable member who would appreciate some guidence.
                      I have a Samsung QE55Q70RATXXC that works perfectly in "shop mode" but in home mode it restarts, Intermittantly.
                      With intermittant I mean the TV can work perfectly for a week and suddenly start to restart. Before the restart it may reach different stages. Sometimes it restarts when the "QLED" start screen shows up and some thimes it restarts after hours, and everything in between.
                      When the restart occurs, the screen blacks out leaving a light area alomng the edges fading...
                      11-09-2025, 07:10 AM
                    • huzo
                      HP Omen shuts down when loading OS
                      by huzo
                      The model is 15ec-1061nm
                      Board number is DAG3EDMB8D0​
                      SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                      10-29-2024, 12:05 AM
