Backup/Controller Suggestions
  • NxB
    • Feb 2009
    • 1595
    I fixed an Ultrium 460 and I want to use it to back stuff up. Windows backup is inadequate. I tried Uranium backup but the free version doesn't do tape.
    There has to be some free tape software out there. Windows backup is too crashy and loses tape indexes. When it does you are fubar in terms of reading the tape.
    Also... I found out the deal with the 4si controller. Its a HP-UX controller and its very similar to PERC 2/Si and HP Netraid 3si but its hanging by a tread and waaaay too large. Can anyone suggest a PCI (or compatible PCI-X,) SCSI controller that is cheap and at least U160? By cheap I mean <$20-30 on ebay.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Backup/Controller Suggestions
    http://cgi.ebay.com/HP-LSi20160-HP-U...item45f77603cb
    http://cgi.ebay.com/Dell-Adaptec-U16...item255fa31d36
    The "Dell/Adaptec" ones you see advertised are generally plain ole Adaptec with a Dell PN sticker.
    Very often they go cheaper than if advertised as just Adaptec.
    Same applies to some other Dell/xxxx parts. - Same as xxxx but cheaper.
    Mann-Made Global Warming.
    - Dr Seuss
    • NxB
      • Feb 2009
      • 1595
      I just got an adaptec one for $15 shipped. It had 64 bit drivers, I think that was the decider.
      Is the big connector for expansion or is it older scsi. I have another tape drive with a connector that size.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Specifically, which big connector on what?
        - Dr Seuss
        • NxB
          • Feb 2009
          • 1595
          The one on the back of the adaptec.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            There are a lot of different adaptec cards and you haven't said which one.
            - So, Yes it's for expansion and it -might- be for older SCSI.
            Just look up the card at adaptec.
            - Dr Seuss
            • pfrcom
              Oldbie
              • Jun 2006
              • 1230
              Possibly a connector for external 68 pin cables
              AFAIK the only wide SCSI card that offered a connector for external 50 pin cables was the Diamond Fireport 40
              better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
              • NxB
                • Feb 2009
                • 1595
                The 39160, I'll just look it up.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Awesome looking card!
                  - Dr Seuss
                  • NxB
                    • Feb 2009
                    • 1595
                    Any ideas for backup software?
                    • master3112
                      ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                      by master3112
                      I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                      When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                      10-29-2024, 09:32 PM
                    • Spikeman
                      Dell Precision 3440 support for CPU 11th gen
                      by Spikeman
                      Hi, since both the Dell Precision 3440 and the Precision 3450 have the same chipset W480.
                      I ask you if it is possible to add the correct microcodes for the Precision 3440.
                      I am adding the list of files that I have extracted from the Bios in order to help you understand if it is feasible.
                      Precision_3440_1.31.0.exe_extracted Precision_3450_1.31.0.exe_extracted
                      03-11-2025, 09:54 AM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • ronnygracias
                      Help with freemotion incline trainer with controller comm error
                      by ronnygracias
                      The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
                      11-04-2024, 01:32 PM
                    • corrize
                      Need help to understand the new laptop shematics around PD controller
                      by corrize
                      Hello, I start to repair this sort of board, but I’m lost. Bye the old 2 mosfets + charging chip + 3v-5v…
                      I can’t « read » this board (Asus UX425 but I saw this in others boards).
                      I see :
                      In GREEN : 2 diodes for 2 power USB-C ways (I removed one diode)
                      BLUE : 2 thunderbolt controllers
                      RED : PD controller CYPD (for negociate the voltage with devices plugged in USB-C)
                      Comment : in order to appearence, I see thunderbolt controller « and after » PD controller guess. I guess (I hope) those 2 controllers are in parallele, for separate power and signal
                      Today, 04:30 PM
