Is it possible to substitute a female 4-PIn molex for a female 3-PIn molex on any mobo particularly IBM? I know the 3-PIn (black, red, yellow) is all volts\ground but I forgot what the 4th pin purpose was(Commonly with the orange cable as the last on either side of the in-line) Is it manipulated to reduce\increase speed when referring to a fan? Just replacing a couple of 60x20mm assembly fans for a IBM thinkcentre 8183. I'm pretty sure the orange wire is not important. Thanks.
Is it possible...
Re: Is it possible...
If you mean small fan connectors that fourth pin/wire is for PWM control signal for speed control chip integrated into fan itself.
In normal/older three pin fan connector third pin is for RPM signal
http://www.allpinouts.org/index.php/..._Fan_ConnectorComment
Standard 4-pin Molex [type for drives] is Red, Black, Black, Yellow.
+5v, ground, ground, +12v.
Standard 3-pin fan connectors are +12v, ground, tach [not in that order]
Standard 4-pin fan connectors are +12v, ground, tach, PWM [not in that order]
Tach is for RPM monitoring.
PWM is for Speed Control.
But, IBM & HP [and old Dell] tend to have some non-standard pin arrangements mixed in with standard so be careful.
.Mann-Made Global Warming.
- Dr Seuss
So the orange cable was the PWM. Was successful with substituting the Superred 26K1253 with the female 4PIn molex for the female 3PIn molex. Was only able to buy a 4PIn rather then a 3PIn. The 3PIn models are hard to find. I came to the conclusion that PWM is not important unless you want the ability to control the available rpm rate of fans. I did some experimenting on a different IBM mobo and the PWM is not required for normal operation. The PWM is the only cable that is not connected. The rest of the three are connected and the fan is functioning quite well. They both are brand new OEM.they call, they telnet, I hangup, I laugh, I get hiccups and digital breakups.Comment
You posts are confusing because (although molex does make some as well as numerous other 'non-molex' connectors) fan headers are not called molex, they are called IDC.
- Dr Seuss
This specification for the Acer Chromebook Acer Chromebook Spin 311 CP311-3H - (MediaTek 8183, 4GB, 64GB eMMC, 11.6 inch HD Touchscreen Display, Google Chrome OS, Silver) Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook Spin 311 CP311-3H - (MediaTek 8183, 4GB, 64GB eMMC, 11.6 inch HD Touchscreen Display, Google Chrome OS, Silver) boardview and Acer Chromebook Spin 311 CP311-3H - (MediaTek 8183, 4GB, 64GB eMMC, 11.6 inch HD Touchscreen Display, Google Chrome OS,...09-06-2024, 10:20 PM
by coinwizxHi,
Anybody has experience repair PSU burned out due to connect to EVGA molex/sata cables. I know the cable is not compatible (i got them mixed up), but I though i can connect it and use a PSU tested to find out which is the wrong sata/molex cables. As soo as I pluged in the powered molex cable to the PSU tester, the power supply short out, and will not turn on anymore. After the incident, the PSUs (both HX1200 and C850) try to power on and shut itself off immediately. The ATX PSU tester survice the short circult, still working perfectly. Anybody know if it's an easy fix or know which parts... -
Hello Everyone!
I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died....06-28-2025, 02:57 PM -
by mosfetratusWhen i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
Works with battery and charges, but when i shut off i get this problem.
It had liquid spill. Board has no corrosion, keyboard is working, power button... -
by WeelcupHi friends
I have a dell XPS 9530 which had some liquid damage to the usb area. I replaced both the usbc iCs and not I can see 20v on the meter. But it does nothing and the 20v is not passing to charge the battery or turning on the board either.
I suspected the PD controller (usbc controller) but it will need to be flashed if I decide to replace it. I thought that if the usbc controller needs flashing then at least the board should turn on on the battery. I charged the battery externally and attached it to the laptop. Now the 11.8v is actually passed to the board I can... - Loading...
