Is it possible...
  • backtrack
    • Nov 2010
    • 38
    Is it possible...
    Is it possible to substitute a female 4-PIn molex for a female 3-PIn molex on any mobo particularly IBM? I know the 3-PIn (black, red, yellow) is all volts\ground but I forgot what the 4th pin purpose was(Commonly with the orange cable as the last on either side of the in-line) Is it manipulated to reduce\increase speed when referring to a fan? Just replacing a couple of 60x20mm assembly fans for a IBM thinkcentre 8183. I'm pretty sure the orange wire is not important. Thanks.
    they call, they telnet, I hangup, I laugh, I get hiccups and digital breakups.
  • seanc
    • Nov 2008
    • 1319
    Re: Is it possible...
    Well orange generally denotes 3.3v, I'm sure it does something...
    • EsaT
      • 12
      If you mean small fan connectors that fourth pin/wire is for PWM control signal for speed control chip integrated into fan itself.
      In normal/older three pin fan connector third pin is for RPM signal
      http://www.allpinouts.org/index.php/..._Fan_Connector
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Standard 4-pin Molex [type for drives] is Red, Black, Black, Yellow.
        +5v, ground, ground, +12v.
        Standard 3-pin fan connectors are +12v, ground, tach [not in that order]
        Standard 4-pin fan connectors are +12v, ground, tach, PWM [not in that order]
        Tach is for RPM monitoring.
        PWM is for Speed Control.
        But, IBM & HP [and old Dell] tend to have some non-standard pin arrangements mixed in with standard so be careful.
        Mann-Made Global Warming.
        - Dr Seuss
        • backtrack
          • Nov 2010
          • 38
          So the orange cable was the PWM. Was successful with substituting the Superred 26K1253 with the female 4PIn molex for the female 3PIn molex. Was only able to buy a 4PIn rather then a 3PIn. The 3PIn models are hard to find. I came to the conclusion that PWM is not important unless you want the ability to control the available rpm rate of fans. I did some experimenting on a different IBM mobo and the PWM is not required for normal operation. The PWM is the only cable that is not connected. The rest of the three are connected and the fan is functioning quite well. They both are brand new OEM.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            You posts are confusing because (although molex does make some as well as numerous other 'non-molex' connectors) fan headers are not called molex, they are called IDC.
            - Dr Seuss
