I have a question about weather or not a laptop computer came with a USB type C charg
    • Jul 2011
    • 6057
    I would like to know if anyone knows if a laptop computer used a USB type C power adapter as its power supply if so what was the brand name and what model number was it I am looking for one that actually still works correctly
    Thank for anyone who knows that can give this information
    The reason I am asking there are EBay sellers that have a battery powered bank that says that it can power up a laptop computer I even have several switching power supplies adapter that have a USB type C male plug on them and I want to make a battery powered pack for remote computer usage or at least this is plan
    • 31140
    Re: I have a question about weather or not a laptop computer came with a USB type C c
    welcome to the world off bulshit that is the USB non-standards
    usb-c is a connector format.
    you need to know about the signaling.
    quickcharge (QC) verses Power Delivery (PD)
    these are the protocols used to raise the voltage and they ARENT compatable with each other.
    BUT WAIT. the fun isnt over.
    there are versions - 2.0 3.0 etc and then you need to know how high the laptop wants to raise the voltage and if the psu supports going that high!
    i stay away from this shit - fuck it all - it's a shitshow.
    it's the road that leads to boxes of psu's and cables just to do a simple task.
      • Jul 2011
      • 6057
      This is the reason I asked the question
      • whatamidoing
        • Aug 2018
        • 13
        • Trieste
        If you're asking about power supplies I've used several HP chargers P/N 671R3AA with just about anything from phones (both qualcomm quick charge and not, including Xiaomis with their weird half proprietary quick charge) to power delivery capable laptops with no issues.
        They're probably one of the few good products that HP currently makes
          • Jul 2011
          • 6057
          Yes I have the HP table USB-C switching power supply’s but my question was was there a laptop computer that used this type of connector to power it and if so what is the model number of this type of computer
          • andrewsawesomr
            • Jun 2022
            • 101
            • United States of America
            Acer Chromebook 314 - CB314-3H-C41F
            Acer CP311-3H-K5WQ
            HP 14a-ne0013dx
            are all computers that can charge via USB-C
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8286
              I use Anker and and Ugreen PSU’s (45w and 60w bricks). Works like a charm. The laptops ASUS and Lenovo will charge on a 45w power supply (normal 60w), but it will let you know that there is a slow charger on the port. Also it does not matter on which usb-c port the PSU gets plugged in. Been doing this for 4 years no problem and 2 years on the laptops no problems. Besides the cables last about 2 years, since they get used a lot. I got them from Amazon.
                • Jul 2011
                • 6057
                How do research for this type of cable Amazon I have not seen what type of cable this is
                Thank you for your information
                  • 31140
                  usb c cables are labelled by their maximum wattage usually
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8286
                    Just go to Amazon and look for “Anker” or “Ugreen”
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5042
                      • US
                      I literally use an apple USB-C charger to charge my LG Gram (45W)
                      • Slimat
                        • Nov 2023
                        • 10
                        To add to the list, I use an HP EliteBook 840 G6 and can confirm that this supports USB-C charging too
                          • Jul 2011
                          • 6057
                          I want to thank everyone who has responded to this post
                          • Gcnewbie
                            • Dec 2023
                            In my experience, anything past 8th gen is much more compatible with USB C charging, before that is quite hit and miss as to what laptops will take it and how much power they will take.
                            Lots of 8th gen and onwards HPs and Dells will accept power via USB C.
                            Most of the machines i've come across will negotiate for 19-20V at 3-5 amps when on and charging. (Obviously the charger must support these configurations)
                            There are power limits also to worry about, a machine that requires a 130W charger for example might not be able to take that much power from a USB C port and will charge, but slowly (even when using a 130W USB C charger).
                            Random note - i have noticed a lot of coil whine in some machines when using usb charging.
                            • RdeveLabs
                              MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                              by RdeveLabs
                              To all the members here...
                              Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                              So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                              05-05-2025, 04:59 AM
                            • iizik
                              P15 Gen 1 (type 20ST, 20SU) Laptop (ThinkPad) - Type 20ST need main and video BIOS
                              by iizik
                              P15 Gen 1 (type 20ST, 20SU) Laptop (ThinkPad) - Type 20ST needs the main BIOS and video. The client says that after the Windows updates there was a firmware update and after that the device makes the sound of music when there is no screen. Moreover, if you turn it on several times then the picture sometimes appears and it works and passes all tests (wonder)
                              and may even reboot normally a couple of times
                              Now he doesn't want it anymore, no matter what I tried
                              It helped to change the video cable a couple of times, I ordered a new cable, it didn't help
                              Of course I checked the...
                              07-17-2024, 09:58 AM
                            • serious_electron
                              Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                              by serious_electron
                              Hello Everyone!
                              I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                              06-28-2025, 02:57 PM
                            • electronx
                              Questions About USB 3.2 Gen 2x2 and USB4 Designs: Type-A vs Type-C, MUX Requirem
                              by electronx
                              I’m currently learning about the USB protocol and designing a project, but I’ve encountered a few questions that I couldn’t find clear answers to. I’d really appreciate your input!
                              1. USB 3.2 Gen 2×2 with SuperSpeed Type-A Connector
                              According to the USB 3.2 specification, it states that USB 3.2 Gen 2×2 can support a SuperSpeed Type-A connector. This raises a question:
                              If we use a SuperSpeed Type-A connector, the system would only utilize 1 lane for data transfer, leaving 1 lane from the host unused. Is this configuration valid,...
                              06-26-2025, 03:27 AM
                            • mazloum
                              laptop ideapad 3-15IML05 Laptop - Type 81WB
                              by mazloum
                              Hi, I have this laptop ideapad 3-15IML05 Laptop - Type 81WB,
                              serial number: PF3DN87L
                              MTM: 81WB010DAX
                              board: GS452/GS552/GS752 NM-C781 Rev:1.0 2019-11-25
                              the problem is it powers up for10 seconds, no fans no picture then powers off, after few seconds it powers on by itself, also no display and then off, i found u4401 burnt , i removed it because i did not find it
                              3v and 5v are both present, 3.3v is present on bios, i reprogrammed bios with no success...
                              01-16-2024, 10:31 AM
