Abit IP35-E with a really hot mosfet
  • yyonline
    • Jul 2009
    • 692
    So I pulled apart one of my test PCs to clean out the dust this weekend.
    When pulling it apart, I noticed some heat discoloration on the back of the PCB. I saw one of the mosfets was running hot, so I figured I would put a heatsink on it and be done with it.
    That was until I realized just how hot it was running. My infrared thermometer puts the temperature of this mosfet at 97°C. This seems really hot, as all the other mosfets on the board are much lower - around 50-60°C. I also don't think it can be good for the Sanyo WG cap right next to it. The placement of the mosfet also makes it difficult to put a heatsink on it, as it can't be too tall due to the video card placement.
    Now, the board works just fine. It's stable, it has good caps, and it's hooked up to a good Seasonic power supply. It's my most used test box, which has a bunch of PCI disk controllers in it. I looked at upgrading it awhile ago, but it's really hard to find things with enough PCI slots these days...or a BIOS that still boots with 3 add-in storage controllers.
    So I'm seeking some advice from the technical gurus. Is the mosfet bad perhaps, if so, would I be seeing stability issues? Any way to test it? Is it supposed to run that hot? Given that I already put it back in the case, I had to steal a photo from Google images. I've highlighted the mosfet location on the board, if that sheds any light on anything.
  • Wizard
    • Mar 2008
    • 2296
    Re: Abit IP35-E with a really hot mosfet
    Read the marking on it and look up on 'net and chances this is not a MOSFET. Rather, it is a linear regulator that reduces initial voltage to lower voltage for point of use supply.
    MOSFET *always* have a inductor coil next to this transistor with capacitor or two. Linear regulator run hot and is a problem if the pad is not on sufficient copper pad as outlined in the datasheet for SMD regulator. Hence the overheating regulator.
    Cheers, Wizard
    • yyonline
      • Jul 2009
      • 692
      Thanks for the info. A quick search found that it is a Fairchild FDD8778, which is described as a 25V N-Channel PowerTrench MOSFET.
      From looking at the board, it definitely looks like it's on a copper plane, and by the looks of it, it's not any smaller than those that other similar components are on.
      I have a total of 6 IP35 based systems, and this part is in all of them, but only runs hot on one of them.
      It heats up to 90°+ after only 2-3 minutes of the system being on. The datasheet says its rated up to 175°C, but I can't imagine that would be good for nearby components that aren't rated that high.
      Any ideas for how I could cool this thing down? Could it be defective? Or not soldered on very well, thus poor heat transfer to the board? (Though wouldn't the dark spot on the back of the board suggest otherwise?) Or something else altogether?
      Thanks again for any advice.
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        stick a heatsinks on all your mosfets...its just a good thing to do
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          When you factor in the junction to case resistance (read the datasheet), the device may actually be operating close to its limits. If you have an oscilloscope check the gate drive waveform, it could be a bad gate resistor giving too little drive to the mosfet and as a result it operates in a high resistance state and heats up a lot more.
          A working TV? How boring!
          • Wizard
            • Mar 2008
            • 2296
            I do not see a coil or inductor next to the MOSFET, so I wondered how they use this as linear regulator or something? Cannot do chopping into capacitors without inductor.
            Cheers, Wizard
            • yyonline
              • Jul 2009
              • 692
              I don't have a scope. Is there anything I can check for without one? Or is this a case of definitely needing the right tool to get the job done?
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                It might be a reg. If that's the case then it doesn't have a reason to get hot so it's still suspicious.
                I've worked a lot of time without one, and when i finally got one it opened new horizons. Pick up a 20MHz or something, you don't need anything too fancy.
                • davidutz
                  • Oct 2014
                  • 3
                  • Romania
                  I have an Abit IP35 MOBO that has discoloration on the pcb near that mosfet you were talking about. The motherboard doesn't displays any image at all, the fans are running and also I get no beep. I changed CPU, RAM and video card but no succes. I also re-wrote the bios chip with a Galep programmer but still no succes.
                  I also bought a pci tester card that isn't showing any error and I checked the voltages from the RAM slots they are 1.8v.
                  I looked for bad caps but it seems they are ok.
                  Could you give me a hint on what to do next...
                  Thank you !
                    • 31303
                    check for cpu voltages.
                    • davidutz
                      • Oct 2014
                      • 3
                      • Romania
                      The CPU voltages are ok !
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        That can be a bad socket, especially LGA 775. Do any of the socket pins look funky?
                        ASRock B550 PG Velocita
                        Ryzen 9 "Vermeer" 5900X
                        Arc A770 16 GB
                        eVGA Supernova G3 750W
                        Alienware AW3423DWF OLED
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          I suspect your motherboard may have a different issue, but nonetheless...
                          First, check resistance between Drain and Source on that hot MOSFET, just to make sure it is not shorted. If not, then change the cap next to it. Even though it may look good, it could be cooked by now, judging by how hot that MOSFET runs.
                          While on the topic, I will mention that I have seen plenty of motherboards with hot-running MOSFETs. For older ASUS and ASUS-built AsRock, it's usually a MOSFET or two around the NB, SB, or RAM area and normally used as linear regulators. The same applies for Foxconn, though it is not as frequent. One example is the Dell OptiPlex GX270 motherboard with its hot-running MOSFET near the AGP slot.
                          And with Intel, it's usually the CPU VRM - either because the copper pads for the MOSFETs are too small and can't dissipate the heat properly or because they have the MOSFETs free-standing on some models (which IMO is just plain stupid).
                          • brethin
                            • Dec 2008
                            • 1907
                            Thank you !
                            When you say PCI tester card I assume you mean PCI Post Card. If so when you turn it on do the codes changes as it tries to boot? What code is displayed after say 3 mins?
                            • Jane
                              How do you test MOSFET in laptops ?
                              by Jane
                              I tried to use this method:
                              Testing an N-channel MOSFET:
                              Step 1: Discharge the Gate (turn off the MOSFET)
                              Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                              Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                              Step 2: Charge the Gate (turn on the MOSFET)
                              Now, place the red probe on the Gate (G) and the black probe on the
                              09-27-2024, 03:31 AM
                            • Nooy
                              VGA MOSfet permanently shorted and loss of MOSfet pad
                              by Nooy
                              Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                              I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                              02-14-2024, 02:26 AM
                            • Tomylee
                              HP 15-fc0007ca Charger Cycling On/Off with Hot MOSFET – Need Component Info
                              by Tomylee
                              I have an HP 15-fc0007ca that works normally, but when I plug in the charger while the laptop is powered on, the charging cycles on and off repeatedly—it starts charging, stops, then starts again.
                              Using a thermal camera, I identified a MOSFET that is overheating, along with a small 2R2 resistor next to it that gets even hotter than the MOSFET.
                              I also hear a “zpzpzpzp” type noise, but the noise is not coming from the same area as the hot MOSFET. I will include a photo with the exact spot where the noise is coming from highlighted.
                              11-26-2025, 12:24 PM
                            • redbaron1007
                              Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                              by redbaron1007
                              I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                              Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                              09-09-2025, 11:10 AM
                            • AppleLover123
                              Asus X712EA 3 volts after the first mosfet
                              by AppleLover123
                              Hey guys,
                              i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                              I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                              Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                              I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                              Now i thought something...
                              12-15-2024, 07:49 AM
