VISTA install problem on an e-Machine laptop...
  • gridleak
    • Oct 2010
    This is my 1st post, so I hope I do this right.
    I'm trying to do a reinstall of VISTA on an e-Machine E620 laptop for a friend. After trying 4 times, I'm still getting stuck at the same spot during the install.
    Here's what I've done so far;
    Format the hard drive, install VISTA from a standard VISTA CD because my friend does not have the recovery disks. I just put in the VISTA product key that's underneath the laptop when I'm prompted.
    All goes well till it does a restart. I get as far as the black screen with the little blue scrolling bar. The screen then turns black for a few seconds, then turns a light blue and I get the following message, "The computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install Windows, click 'OK' to restart the computer and then restart the installation."
    On the 4th attempt, the only thing I did different was start from a DOS floppy from a USB floppy drive. I deleted the primary partition and created a new one before repeating the process I listed above and getting the same results. I've also tried 2 different VISTA discs with the same results.
    A computer tech friend of mine ran a diagnostic check on the hardware as well and nothing showed up.
    Any guidance here would be appreciated.
    Regards and thanks for now, Bob
    Dogs have owners, cats have staff.
    • 31298
    Re: VISTA install problem on an e-Machine laptop...
    fuck vista - that's the first thing.
    use Linux, or use XP or use "7"
    skip vista - it's very bad.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      i do not recommend "fucking" vista. as babies with the vista cd wouldnt look that nice.
      but, i do agree that you should put windows 7 onthere. dont bother with xp nymore, they are slowly phasing it out...
      )windows 7 home preium 64bit oem just costs $99...
      • Wrog
        • Oct 2009
        • 472
        Interesting, "standard" Vista media should not accept an OEM key.. that could be an issue. What I would do is try to slipstream the latest service pack and try again. Use vLite to accomplish this.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Ive always had good luck both with using dell oem keys for dell xp cds multiple times same key, and never had a problem with using dell cds on other pcs (hps and self-builts too!)
          • weirdlookinguy
            • Sep 2007
            • 1638
            Try a different CD. I had an XP CD do that to me once. After a few hours of hair pulling I decided to try a different copy of it. It worked just fine. I also had a flaky optical give me a ton of crap while trying to install FC6 once.
            • Wrog
              • Oct 2009
              • 472
              Yes, you can use an OEM key with OEM media all day long. The issue is using OEM keys with retail media.
              • gridleak
                • Oct 2010
                Hi again,
                weirdlookinguy.... Thanks, but I mentioned in my thread that I tried 2 different VISTA discs and got the same results with both. I also tried them by connecting a DVD-ROM connected to my external USB hard drive case as well and got the same results at the same place. That was in case the internal one might be the issue.
                Wrog.... I have loaded retail discs on OEM equipment before with good results. On the 2 occasions that it would not activate on line, I telephoned the number given and talked to the computer at Microsoft, and re-did the activation that way and it took both times.
                The only thing I figure I have succeeded in so far is increasing my vocabulary.
                Appreciate the input though. Thanks.
                Bob
                • MXM
                  • 430
                  • Unknown
                  hey, welcome to the site... wel i remember i once had a weird issue logging windows too and when i thought i had tried everything i tried installing the hard drive i was having issues with on other motherboard and do everything all over -physically plugging it to another board- and it worked, i remember i didnt even format cause at first boot it worked, i wouldnt mind trying that out given the fact you've tried many things. didnt make much sense to me but it solved my issue. it was also a laptop but i cant remember the brand, and the disc was sata and i installed it on one of many shitty hp sff i have around... and i'd also recommend using other key if it doesnt work again.
                  peace.
                  ps. thanks to the mod who deleted my double post on other thread
                  We don't have a great war in our generation, or a great depression, but we do, we have a great war of the spirit. We have a great revolution against the culture. The great depression is our lives. We have a spiritual depression.
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    if it were a key problem it would reject it right then and there.disk/drive issues more likely.
                    • bgavin
                      • Jan 2007
                      • 1355
                      OP, go to www.memtest.org and download the .ISO for v4.10 memory diagnostics. Burn to CD, boot the CD and run all the tests. Any red errors indicate fatal memory problems which will cause the problems you see.
                      Depending upon what drive is installed in your machine, go find the diagnostics for that make. You can get either floppy or CD based in most cases.
                      Do a full surface scan, not just the quickie.
                      Some packages will allow you to write zeros, ala a kind of low level format to the disk. If the drive has more than 26,000 hours, it has seen more than 3 years continuous use and should be replaced. The various SMART utilities will let you read this counter, or DiskCheckup will do it once you have Windows working.
                      • yyonline
                        • Jul 2009
                        • 692
                        Maybe a driver issue? Try slipstreaming SP2 into your Vista disc, which should update the driver base. Google should have directions on doing that. Alternatively, try disabling all non-essential peripherals in bios setup, running the install, then download updated drivers before re-enabling the peripherals in bios.
                        Is there a BIOS update available for the laptop?
                        Are you using another OEM's Vista CD with the emachines laptop? This wouldn't be a problem as far as the key is concerned, but OEMs often integrate drivers for certain vendor-specific hardware drivers, which can occasionally cause conflicts. Perhaps try a generic OEM disc instead of a vendor-specific OEM disc?
                        • shouri
                          Dell latitude e5490 auto restart
                          by shouri
                          Hi guys, can someone help me?
                          I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
                          Board model is dm70 la-f401p rev:1.0 2017-09-20.
                          At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
                          After a few days test, is seems ok.
                          Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
                          12-10-2024, 09:27 PM
                        • japlytic
                          DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                          by japlytic
                          In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                          Tried (only with keyboard/mouse connected):
                          • BIOS + database update
                          • Using latest Windows 11 image built with official image creation tool
                          • Previous setup version for Windows 11 installer
                          • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                          • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                          • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                          06-19-2025, 04:59 PM
                        • fulepost@outlook.com
                          Samsung "QE" series QE55Q70RATXXC Intermittant restart in "home mode".
                          by fulepost@outlook.com
                          Dear all.
                          I'm a less knowledgable member who would appreciate some guidence.
                          I have a Samsung QE55Q70RATXXC that works perfectly in "shop mode" but in home mode it restarts, Intermittantly.
                          With intermittant I mean the TV can work perfectly for a week and suddenly start to restart. Before the restart it may reach different stages. Sometimes it restarts when the "QLED" start screen shows up and some thimes it restarts after hours, and everything in between.
                          When the restart occurs, the screen blacks out leaving a light area alomng the edges fading...
                          11-09-2025, 07:10 AM
                        • 24gsm
                          MacBook Pro A1708 install macos fail
                          by 24gsm
                          hi to all
                          i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
                          after enter to recovery and format hdd 1to .
                          after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
                          can help please
                          Serial Number: FVFXP0U0HV2J
                          Config Code: HV2J
                          Find My Mac: OFF
                          04-16-2025, 03:57 AM
                        • duwane
                          A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
                          by duwane
                          Hi All.
                          Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
                          The issue:
                          Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
                          10-26-2022, 07:02 AM
