Easiest to recap?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Easiest to recap?
    which items are the easiest to replace the capacitors? i dont mean troublehooting; im not counting the repair of ther components (ie transistors) or anything else going wrong...
    17
    Computer Power Supplies
    0%
    9
    Computer Motherboards
    0%
    1
    Video Cards + Other Add-In cards
    0%
    6
    LCD or Plasma TVs, or LCD PC monitors
    0%
    0
    Other (explain)
    0%
    1
  • c_hegge
    • Sep 2009
    • 5219
    Re: Easiest to recap?
    PSUs. They are hardest to damage the PCB on
    • everell
      • Jan 2009
      • 1514
      Definitely a Bestec power supply
      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
      • japlytic
        • Oct 2005
        • 2086
        Also set-top boxes/DVD players etc., especially if the power supply board is separate.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          ive never seen a dvd player with bad caps. even thuough i did pop open a no-name generic junky one that didnt work and it did have crapxons but they didnt look bloated-but it wasnt worth trying to fix seeing that there plenty more better-quality working ones...
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            i would have said PSU but some of the lower end ones have easy to burn off traces. add in cards tend to have less caps ... they do not have evil ground planes either.
            sigpic
            (Insert witty quote here)
            • MXM
              • 430
              • Unknown
              wel computer PSU i agree is harder to mess up the pcb, but some of em are kinda hard to access or sometimes i have to remove like other componentes in order to reach the caps... as for computer mobos i've had certain issues with em hahaha i think some models/brands are a little hard to desolder specially... so my vote goes to other devices that might include some LCD
              jm2c
              peace.
              We don't have a great war in our generation, or a great depression, but we do, we have a great war of the spirit. We have a great revolution against the culture. The great depression is our lives. We have a spiritual depression.
              • acstech
                GrumpyModerator
                • Jul 2007
                • 1432
                I'm going to go video / add-in cards here. PSU's, you have to fight the wires, heat up giant gobs of solder to desolder the old ones, battle glue, etc. Some PSU's go easy and some are a giant pain.
                Video cards, you might have to remove the heatsink and run the soldering iron a bit hotter. There's no case to take apart, other than the computer case to remove the card. There are no wires to fight. There's no glue to hold things together or obscure the rating on the capacitor so you don't know what replacement to get. I think when you consider the whole job, the video / add in card is easier.
                A man convinced against his will is of the same opinion still.
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  um-you basically mostly copied my post what i wrote, and you have ads in your signature. um m getting too suspicious of you being a sly scammer. but i think you put enough time and effort into making your account here you may not be.
                  if you are not don't be offended. welcome to badcaps forums!
                  if you are, go the fuck away
                    ASUS P5GC-MX motherboard recap
                    by momaka
                    Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                    This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                    So here is what the motherboard looked like with its original caps:
                    CPU VRM area up close…...
                    01-27-2021, 11:59 PM
                  • Francesc V.
                    Onkyo A8200 - Not the right voltages in some transistors
                    by Francesc V.
                    Hi:
                    I am trying to repair this amplifier that I've bought as faulty. I've found some transistors damaged, the ones where I am drawing a red circle.
                    With the final transistors not yet installed (the expensive ones), I've started to measure some voltages:
                    Where I am supposed to have 1.12V (base Q524/Q523) I am reading -42V..................both channels don't seem ok.
                    Where I am supposed to have -1.12V (base Q526/Q525) I am reading -44V..................both channels don't seem ok.
                    I removed and tested Q514,Q516 & Q513,Q515 but the analyzer...
                    04-19-2025, 07:17 AM
                  • redbaron1007
                    Sundown SFB-8000D What are these transistors?
                    by redbaron1007
                    I had a Sundown SFB-8000D amp come into the shop yesterday that wasn't giving any output. The guy who brought it in said he bought it off some crack head on Facebook marketplace for a good price, but bought it knowing it was broken. Apparently the original owner was cutting out the transistors to the right of the ones pictured whenever one would blow and take the output out. Best I can figure he also cut the legs on the S5 and S6 ic's as well and soldered them back together.
                    My problem is Sundown decided in the factory to remove the original markings on the IC's and now I can't figure...
                    11-12-2023, 07:30 PM
                  • Bob Wong
                    MSI Crosshair 15 A11UEK. Need help with Transistors!!!
                    by Bob Wong
                    Welcome badcaps, repairing a Crosshair 15, in need of transistor specifics. Received a broken laptop that's was perfect for repair, threw away the looser transistors in a haste... Should and could have salvaged them.
                    In any case, I will be posting all my discoveries to this forum as a thanks in advance. Thanks in advance lol.
                    P.S. If anyone is familiar with such things, as in, If anyone knows that MSI uses one or one of a few types of transistors when marked with a number please let me know how I can find more specifics before I start throwing hail marys.
                    03-15-2025, 02:02 PM
                    no-name Radeon 9600 XT recap and cooler
                    by momaka
                    I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                    This one was actually suggested to me by ChaosLegionnaire....
                    11-06-2020, 07:54 PM
