SDLFNCAR-960G-1HA2 SanDisk SSD Passwords
  • mikay786
    • Aug 2014
    • 765
    Ive got a bunch of these SDLFNCAR-960G-1HA2 ssds which unfortunately seemed to be password locked. Cant format or do anything with them.
    When connected to PC via a usb adapter is detected but not initialised and cant to anything with it.
    When connected to a laptop via sata just comes up with a HDD
    password screen, with the option to go to a master password screen.
    Cant enter bios as goes straight to password screen.
    Can anything be done with these?
    • 31316
    Re: SDLFNCAR-960G-1HA2 SanDisk SSD Passwords
    search.
    you can issue an ATA reset command that will wipe the drive.
    • mikay786
      • Aug 2014
      • 765
      Originally posted by stj
      search.
      any links struggling here!
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Google for "Secure Erase"
        It is a command part of the ATA specification and all modern drives should support it.
        The easiest way is usually to use the manufacturers (of the drive) tools to perform it.
        • mikay786
          • Aug 2014
          • 765
          Have been able to boot connected as a second drive via sata to my PC but drive isnt showing up in bios, windows etc unlike laptop which would just go straight to password.
          tried sandisk dashboard which isnt picking up drive at all via sata. is seing something via USB but no options available and no model number.
          tried AOMEI which is picking up drive and lets me get to the stage of secure erasing but then says your drive is protected by a password before prompting me to enter it.
          Not getting anywhere with this, any other suggestions?
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Do you have a Lenovo laptop?
            If so try this utility: https://support.lenovo.com/us/en/dow...drive-thinkpad
            • mikay786
              • Aug 2014
              • 765
              ill have one knocking about somewhere, but i assume will behave like the other laptop i used as in will boot straight into the password screen.
              will give it a go though will let you know.
              • mikay786
                • Aug 2014
                • 765
                no luck using a T450, same issue password screen.
                Tried hot swapping with another HDD but would fail when it realised is a different drive.
                Tried Linux hdparm (never used linux before)
                could read the drive and its status, which is locked, not frozen and supports secure erase.
                Keep getting GD I/O errors. Tried loads of different commands and variations but no luck.
                Tried Victoria HDD software, which showed security as locked, max.
                So frustrating
                • pfrcom
                  Oldbie
                  • Jun 2006
                  • 1230
                  https://www.badcaps.net/forum/showpo...49&postcount=2
                  better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                  • jiroy
                    • Jun 2016
                    • 2416
                    • Lebanon
                    If "Parted" do not work , you have to start thinking which program was used to lock it .. There are many programs for locking devices , and some of them are so powerful , that virtually , nothing can unlock them without a password .
                    Even if there's a general password for a specific program , you won't be able to define which program it is ..
                    • mikay786
                      • Aug 2014
                      • 765
                      Out of a server as were all mounted in caddy’s. From a it recycler friend of kine
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        Try following this guide, it has worked for me in the past:
                        https://archive.kernel.org/oldwiki/a...ure_Erase.html
                        • mikay786
                          • Aug 2014
                          • 765
                          Does using Linux off a live usb make a difference to the procedure?
                          I’ve read a few times the target drive needs to be unmounted?
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            Yes it might, some live distros will automatically mount all drives it finds.
                            But you can just unmount it first, then there should be no issue...
                            • mikay786
                              • Aug 2014
                              • 765
                              Doesn’t let me unmount just gives error. I’ll try installing Linux fully onto ssd and try again.
                              • jiroy
                                • Jun 2016
                                • 2416
                                • Lebanon
                                Been browsing some hundreds of programs DVDs and CDs for some projects i'm deep into , and this program got my attention while at it .. It's called USB Lock AP 1.0 (YES, my version is old but anyway) . Its capabilities are amazing in locking different devices .. The problem yet remains as supposedly there are lot of similar ones ..
                                https://usb-lock-ap.software.informer.com/
                                • Ryan.man
                                  by Ryan.man
                                  02-04-2025, 12:23 PM
                                • reformatt
                                  by reformatt
                                  07-31-2025, 08:37 PM
                                • Nopslide
                                  HP Omen 15-dh0052nf power-on & bios password
                                  by Nopslide
                                  Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                  My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                  Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                  04-01-2024, 04:27 PM
                                • smic717394
                                  by smic717394
                                  07-25-2024, 10:16 AM
                                • outsider
                                  Panasonic FZ-G1 MK5 - BIOS password returning
                                  by outsider
                                  Hello
                                  I removed the BIOS password thanks to the help of one of the friends of this forum.
                                  https://www.badcaps.net/forum/troubl...61#post3637661
                                  The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                  06-17-2025, 12:51 AM
