Mac G5 2.5 ghz waterblocks
  • starky52jmas1125
    • Sep 2010
    • 6
    I'm looking for a waterblock for my Powermac G5 cooling unit. Seems I was a little too beastly and broke one of the hose connections. Can anyone help?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Mac G5 2.5 ghz waterblocks
    look around... there is a thread in this forum about that... pentium broke the refill valve off of his block.
    you can have someone TIG weld the connection back on. iirc that is what pentium did.
    sigpic
    (Insert witty quote here)
    • starky52jmas1125
      • Sep 2010
      • 6
      The water block is actually the component the sits on top of the processor. The top end is made of plastic.
      • pentium
        • Mar 2006
        • 2778
        I broke off the stupid filler nozzle which is a lot different than the barbed ports on the waterblocks. Rule of thumb is that when you wanna replace the hoses, cut them off. Don't pull. Also, refilling these waterblocks are a pain in the ass. I had to rig mine up to an external power source so I could get all the air out of the loop.
        Find Nedry!
        Check the Vending machines!!
        <----Computer says I need more beer.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          if it is plastic, then you could epoxy it?
          sigpic
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16959
            JB weld works wonders on these kinds of things......but with any liquid cooling in a computer, pressure test it and MAKE SURE there's no leaks!
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              oh the uses of jb weld... from thermal adhesive to waterblocks...
              sigpic
              • starky52jmas1125
                • Sep 2010
                • 6
                Thanks for the tips.
                I actually found a one part epoxy at Ace Hardware called Plastic Surgery made by Surehold. It worked great.
                thanks again, this is a great forum!
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  Topcat! Your doin' it again!
                  "there's no leaks"
                  Bad kitty!
                  Since there's=there is
                  -is- is singular
                  -and- is plural
                  So it would be:
                  THERE ARE NO LEAKS!!!
                  ps i asked my mom,and my english teacher they agreed with me!
                  Lol
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    OMFG we have a grammar cop now!
                    "there's no leaks"
                    Bad kitty!
                    -is- is singular
                    -and- is plural
                    So it would be:
                    Lol
                    • smason
                      • 1652
                      YOU'RE doing it again.
                      Fail. Back to English class for you.
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16959
                        As for pointing out grammar errors, find something useful to do...and not waste space in my database with this crap. On top of that, QUIT HORKING PEOPLE'S THREADS WITH THIS JUNK!
                        Team : 49813
                        Join in!!
                        Team Stats
                        • weirdlookinguy
                          • Sep 2007
                          • 1638
                          "there's no leaks"
                          Bad kitty!
                          -is- is singular
                          -and- is plural
                          So it would be:
                          Lol
                          Are you FUCKING kidding me?! You show up in every goddamn thread spewing incoherent txt-speak bullshit, and then you bash the owner?
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            Alright then. Bye
                            • nerdmafia
                              Broke off RTC Coin battery pin on HP EliteBook 840 G1 - Operating Systems do not load or install
                              by nerdmafia
                              Hi first question posting here, but no need to go easy on me!
                              I have an HP EliteBook 840 G1 non touchscreen. The symptoms are that: Repairing or reinstalling windows freezes no matter how i try it. Live Ubuntu that works on any other computer also freezes while trying to load it. The RAM sticks and the harddrive work fine in other computers. I broke off the connector by accident, CN4750 and was using the laptop for a while with no coin battery. According to this schematic I found on here, which I THINK is the correct schematic, pins 2, 3, and 4 should short to ground, and they do....
                              05-21-2025, 09:39 AM
                            • powermacenjoyer
                              Powermac G5 late 2005 power supply troubleshooting
                              by powermacenjoyer
                              Note to mods: please remove the first thread i posted. It had crappy title. Hopefully this will make some powermac expert look at it more likely
                              So i bought PowerMac G5, which worked for around an hour. Then i decided to partially strip it down and re-paste CPU, after which it still worked. However just after i added DDR2 memory into it and connected it to 220v, the mac made a loud pop noise, diagnostic leds on the front side of motherboard shortly blinked and since then, the power mac has no signs of life at all
                              PSU is API4fS13. There is no visibly broken component...
                              09-03-2022, 06:09 AM
                            • Snownomow
                              Shock when touching power supply case (ACBel API1PC36 from PowerMac G4 MDD)
                              by Snownomow
                              Hello!
                              I recently successfully repaired two Apple PowerMac G4 MDD power supplies by swapping out bad caps, per excellent info found in various threads on this forum - yay!
                              I was doing testing on one of them, the ACBel API1PC36, with it's case open and had it setup outside of the PowerMac resting on the table with it's power connected to the system (power was also connected to a couple SCSI HDD drives, for a bit extra load). It was working fine, I shut down the system but did not unplug the PS from the power strip (and power strip was left on) so power was going into...
                              07-30-2020, 02:20 PM
                            • 5mall5nail5
                              Help identifying connector for ASUS 4090 Strix RGB LED connector
                              by 5mall5nail5
                              Hi All -
                              I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
                              Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
                              05-04-2025, 07:47 AM
                            • trex66
                              Craftsman 82345 Multimeter broke!
                              by trex66
                              My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                              03-04-2025, 04:26 PM
