I am looking for a DOS based low level format-ing hard drive and SSD drive
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: I am looking for a DOS based low level format-ing hard drive and SSD drive
    We need to make the distinction between low level format and doing housekeeping maintenance. VC servo tracks have a chicken and egg problem if you're trying to rewrite them, and as this truly is at the lowest level, this can't be done on VC disks.
    Fortunately on stepper disks the lowest level does not contain servo data, just sector boundaries, so it's a lot simpler on these older disks.
      • Jul 2011
      • 6057
      Yes I am resuming my old post back to life because I recently realized that I had bought a subscription for Spine Rite 6.0 and I can upgrade to 6.1 which is the newer version of this software
      I have some very old laptop computers that I might want to put back in to service but I need to format the hard drives because these computers were windows 7 originally but on there on went to windows 10 and made them boot very slow and responsive is very slow as well they were decent when they were running windows 7
      But more on that later when I have time to work on them
        • 31158
        wipe the drives by booting a linux live-image.
        then using the DD command to write 0's to the whole drive.
        from a commandline you can type "man dd" for the manual
        or "dd --help" for a bit less to read.
          • 31158
          typed it for you
          dd --help
          Usage: dd [OPERAND]...
          or: dd OPTION
          Copy a file, converting and formatting according to the operands.
          bs=BYTES read and write up to BYTES bytes at a time (default: 512);
          overrides ibs and obs
          cbs=BYTES convert BYTES bytes at a time
          conv=CONVS convert the file as per the comma separated symbol list
          count=N copy only N input blocks
          ibs=BYTES read up to BYTES bytes at a time (default: 512)
          if=FILE read from FILE instead of stdin
          iflag=FLAGS read as per the comma separated symbol list
          obs=BYTES write BYTES bytes at a time (default: 512)
          of=FILE write to FILE instead of stdout
          oflag=FLAGS write as per the comma separated symbol list
          seek=N (or oseek=N) skip N obs-sized output blocks
          skip=N (or iseek=N) skip N ibs-sized input blocks
          status=LEVEL The LEVEL of information to print to stderr;
          'none' suppresses everything but error messages,
          'noxfer' suppresses the final transfer statistics,
          'progress' shows periodic transfer statistics
          N and BYTES may be followed by the following multiplicative suffixes:
          c=1, w=2, b=512, kB=1000, K=1024, MB=1000*1000, M=1024*1024, xM=M,
          GB=1000*1000*1000, G=1024*1024*1024, and so on for T, P, E, Z, Y, R, Q.
          Binary prefixes can be used, too: KiB=K, MiB=M, and so on.
          If N ends in 'B', it counts bytes not blocks.
          Each CONV symbol may be:
          ascii from EBCDIC to ASCII
          ebcdic from ASCII to EBCDIC
          ibm from ASCII to alternate EBCDIC
          block pad newline-terminated records with spaces to cbs-size
          unblock replace trailing spaces in cbs-size records with newline
          lcase change upper case to lower case
          ucase change lower case to upper case
          sparse try to seek rather than write all-NUL output blocks
          swab swap every pair of input bytes
          sync pad every input block with NULs to ibs-size; when used
          with block or unblock, pad with spaces rather than NULs
          excl fail if the output file already exists
          nocreat do not create the output file
          notrunc do not truncate the output file
          noerror continue after read errors
          fdatasync physically write output file data before finishing
          fsync likewise, but also write metadata
          Each FLAG symbol may be:
          append append mode (makes sense only for output; conv=notrunc suggested)
          direct use direct I/O for data
          directory fail unless a directory
          dsync use synchronized I/O for data
          sync likewise, but also for metadata
          fullblock accumulate full blocks of input (iflag only)
          nonblock use non-blocking I/O
          noatime do not update access time
          nocache Request to drop cache. See also oflag=sync
          noctty do not assign controlling terminal from file
          nofollow do not follow symlinks
          Sending a USR1 signal to a running 'dd' process makes it
          print I/O statistics to standard error and then resume copying.
          Options are:
          --help display this help and exit
          --version output version information and exit
          GNU coreutils online help: <https://www.gnu.org/software/coreutils/>
          Full documentation <https://www.gnu.org/software/coreutils/dd>
          or available locally via: info '(coreutils) dd invocation'
          • harp
            • Jun 2022
            • 616
            • Planet Earth
            " You can find much contradictory information regarding this topic. Hard drive manufacturers themselves don't like to talk about it. But generally, hard drives are much more resistant to big magnets than expected. The hard drive coating usually provides a high level of coercivity. This means you would have to bring a very large magnet very close to a hard drive in order to delete files. As long as you don't unscrew the top cover of the hard drive, you won't be able to get close enough. " .................. https://m.youtube.com/watch?v=G3eURKwqbN8
              • 31158
              if you use a degausing method the drive will be fucked.
              they have calibration data and sometimes the firmware stored on the platters.
              • Mattz_GT
                • Jan 2025
                • 19
                • United Kingdom
                #27
                For some drives, there may be a utility from the maker which can verify and spare out bad sectors, Spinrite tries to achieve this, but may not have the same level of access as the maker utility - though TBH, if have bad sectors to deal with, more are likely to turn up.
                If the maker utility offers a zero fill, that might also perform bad sector sparing even if it doesn't specifically say so
                • federalhouse
                  **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                  by federalhouse
                  I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                  **Background:**
                  I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                  **What I've Tried So Far:**
                  1. I accessed
                  08-01-2024, 07:03 PM
                • tmcw
                  PC case - Hard drive rails
                  by tmcw
                  A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
                  So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
                  I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
                  Now, the case is a CiT Gaming Case, and...
                  05-22-2022, 12:04 PM
                • madura2010
                  DAY11AM6E0 hard disk drive and optical disk drive not detected
                  by madura2010
                  Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                  i checked the connectivity of ribbon=good communication with hard and motherboard
                  changed hard disk and checked=3f0 error persist
                  sata power=+5v available
                  Then checked data capacitors=all good
                  Then checked data lines path connectivity to pch=all good
                  reflashed...
                  03-12-2023, 09:09 AM
                • ash91
                  Hp pavilion 15 not detect hard drive
                  by ash91
                  Hello gentelmen .... this is my first post and sorry for my bad english,
                  so my proplem is my laptop keep losing hard drive even if i but the
                  hard disk in the cady (the box that can replace the dvd rom with hard disk)
                  when i turn the laptop on the massage that said no boot media found pop on
                  the hard disk is fine and to be sure i try another hard
                  i also update my bios to the last update
                  the 5 volt is present on the hard connector on the motherboard
                  the dvd rom work fine when i but a windows dvd in it
                  also when i boot from flash...
                  06-07-2023, 01:45 PM
                • karto95
                  Repairing a Seagate hard drive with damaged logic board
                  by karto95
                  I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
                  I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
                  If anyone has any suggestions or experience with this...
                  03-21-2023, 04:05 AM
