Laptop batteries
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Laptop batteries
    If they are legit Dell batteries it doesn't matter where you get them.
    China is probably where Dell batteries are made anyway.
    OTOH, greater chance of counterfeits from China.
    Mann-Made Global Warming.
    - Dr Seuss
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      we got a dell charger from china in bulk (PA-10)
      one customer bought it back 80% melted. almost caught on fire
      • stevo1210
        • Oct 2006
        • 4156
        the battery in it now (the dead one) is also made in china. zzz
        • stevo1210
          • Oct 2006
          • 4156
          Ok so I bought a genuine Dell battery off the net and I have verified it's a genuine, not a fake one. It works great and it lasts for 2 hours or more which it is supposed to do... but the battery meter is screwed up for some reason. Right now, 1 hour and 40 minutes in and it's on 0 percent battery life... it's been on 0 percent for the last 20 minutes by the least but there's still lots of juice in the battery.
          What's going on here?
          Not really in the mood to send this battery back to the USA either, soo much postage costs and effort.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            run it till the laptop shuts down and recharge.
            • stevo1210
              • Oct 2006
              • 4156
              Ok, I've done exactly what you said... hopefully it will solve the problem. What causes this anyway?
              It actually lasted for nearly an hour after "0%" battery life came up LOL.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                #27
                Battery management chip needs to get calibrated
                • HTR-Informatique
                  Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                  by HTR-Informatique
                  YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                  I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                  On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                  I also changed the screen because the PC fell and the screen was broken.
                  I changed the battery with a new and original battery.
                  I also had corrosion/oxidation on the...
                  02-09-2025, 06:51 AM
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                  12-31-2023, 06:04 AM
                • tomodachi
                  Dell Precision 5510 " Not a Dell Battery"
                  by tomodachi
                  Hi
                  Dell Precision 5510
                  Mobo code : LA-C361P
                  This one came in for battery replacement but without original battery, so original battery and charging history is unknown.
                  The customer said he bought the computer several years ago second-hand and was told that there was no battery inside but that he could purchase one if he wanted.
                  So we ordered a geniune battery for customer, plugged it in
                  RTC battery was also dead and it was also replaced. First boot up brought up warning message;
                  Funny thing is Service Tag is already set.
                  And...
                  11-07-2024, 06:08 AM
                • lawrenceptrini
                  Battery not charging - Dell Inspiron 3593 FD155 LA-JO81P (REV 1.0) (A00)
                  by lawrenceptrini
                  Hi Guys,
                  I am seeking some assistance with a Dell Inspiron 3593 FD155 LA-J081P (REV 1.0) (A00) laptop
                  The laptop is working fine with the adapter plugged in and also with a charged battery.
                  Problem is that the laptop is not charging the battery. The battery is recognized in the bios but the
                  ac adapter is listed as 'Not Installed'. So for instance, when a charged battery from another source
                  loses its charge, it stays on 0%.
                  Measurements taken
                  Charging IC (ISL95522HRZ) 32 pins
                  Voltage to ground with ac adapter only plugged in:
                  1)...
                  08-26-2024, 06:45 PM
