Any good references for variable capacitor design?
  • Ady2017
    • Dec 2017
    • 50
    I have recently decided to put together a 1930's style crystal radio as a father-son project to get him started in electronics. The lack of availability of now-obsolete variable capacitors is causing a big headache. From what I have seen on the internet, a number of people have resorted to making their own variable capacitors but have not given any details about how they designed them. Does anybody have any old references for the design of variable capacitors which includes details such as plate spacing, plate size, number of plates, best materials to use, etc.
    • 31213
    Re: Any good references for variable capacitor design?
    your question will relate to the range of capacitance your after
    did you try ebay/aliexpress for a crystal radio kit??
    the chinese are really stepping up in a big way with eductational kits since radioshack died.
    • petehall347
      • Jan 2015
      • 4440
      • United Kingdom
      try searching tuning capacitor on ebay and google .. i see an an abundance of them
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        capacitance has always been number of "active plate surfaces" times dielectric constant of air times area divided by distance between plates. Not much to it to make an air capacitor. Note that the plate material is immaterial as long as it conducts electricity. However the capacitance you need is dependent on the rest of the design, most specifically the corresponding inductor coil or antenna coil and what frequency you're trying to tune.
        The reason why the old tuning capacitor looks funny is the effort the designers made to make the dial look linear. Making a makeshift capacitor for a homemade radio, this doesn't really matter.
        • petehall347
          • Jan 2015
          • 4440
          • United Kingdom
          when i was building crystal sets i knew nothing about pf values i just threw them together and they worked fine . i did however know the differences of am and fm tuners though .
          • redwire
            • 3912
            Old crystal sets are always tuning using the (slide) inductor. I've never seen a homemade variable capacitor. They are treated as a component you buy.
            The common value of 365pF is a lot of capacitance to make, you need a multi-ganged rotor and too much mechanical ballyhoo.
            Internet Archive - you can look through old radio magazines going back https://archive.org/search.php?query...=TXT&sort=date but I couldn't find a way to filter just old i.e. 1910-1950's. Many old radio magazines showing how to make one, but none have a DIY variable capacitor.
            edit: surprised to see some countries taxed people with crystal radios, I think to help cover broadcast costs.
            1922 crystal radio kit $4.75 or $84 in today's dollars. Not sure about the difference in wages though.
            • CapLeaker
              Leaking Member
              • 8328
              Is it possible for the op to post the project? Maybe scan it and upload it here?
              • petehall347
                • Jan 2015
                • 4440
                • United Kingdom
                wish i still had the book i used all them years ago .. all simple stuff really . i used to try different windings around a ferrite core and capacitors connected to an external antenna for selectivity and sensitivity .. its been a long time since i played around with simple radios. 50 years and more . or was it cap to copper water pipe ? i must have driven my dad and brother mad with all the wires etc .
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  indeed the main problem is the plates need to be quite rigid and any slop that bends the plates will change the capacitance and cause your frequency to go off.
                  I think for the most part crystal radios are so nonsensitive and nonselective you're only going to get local stations and you don't even need to be tuned just right, and yes tweaking the inductor is probably easier/more stable. been a while since I played with a crystal set like with the radio shack spring terminal radio kits, but indeed they weren't that great... at least they got the inductor and capacitor just right to tune in the AM 300m band.
                  • petehall347
                    • Jan 2015
                    • 4440
                    • United Kingdom
                    i remember adding different capacitors to the earth and the antenna for selectivity and sensitivity .
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      are we talking actual capacitor design, or tuner/antenna design, makes a difference here...
                      if you don't have any variable capacitors I'd think you're looking at the former. If you already have a pile of variable capacitors, then the latter is the issue?
                      I recall this one rat shak radio kit that actually seemed to be a bit better in terms of at least sensitivity, it was a regenerative receiver instead of the usual crystal + amplifier. Selectivity wasn't as good as standard off the shelf receivers, but it was able to pick up stations without the usual ground wire and really long antenna.
                      Either way if you don't have a variable capacitor at all, it'd be mighty hard to tune, at least the capacitance side. You can still tune the inductor side...
                      • desert-rat
                        • Mar 2014
                        • 4103
                        I got a var cap off Amazon. Took a couple of months to get it. If you look at electronics suppliers they are available. As I remember the cap was around 365 pf . Don't remember the micro Henries of the coil . But it's easy to find. You can also use a fixed cap and a mid taped coil. I have seen a few videos on YouTube on how to..
                        PS ,all you really need are 2 metal plates . One fixed the other is movable.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          Or you can just move them closer/farther apart (which unfortunately is very nonlinear and capacitance drops very fast as you move farther apart, making frequency even harder to tune.)
                          The "only" two metal plates have to be very big to get appreciable capacitance and very stiff to make sure they don't touch each other...which becomes a very good antenna for picking up 50/60Hz...
                          BTW the tiny variable capacitors for full band tuning purposes use non-air dielectric to increase its capacitance in such a small volume...
                            • 31213
                            the caps in am radio's dont move plates, they move mylar film between the plates
                            • MORETTIGIAN
                              Capacitor detached from PCB – RTX 2070 Super Founders Edition
                              by MORETTIGIAN
                              Title:
                              Description:
                              During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                              I did not notice it detaching, so I am unsure of its original location on the PCB.
                              Procedure performed:
                              - Removed backplate
                              - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                              - Reapplied thermal compound
                              - Reassembled card
                              Observed behavior after reassembly:
                              - GPU powers on and operates normally under...
                              09-18-2025, 12:14 PM
                            • cook
                              Good brands of run capacitor for house heat hump
                              by cook
                              Are there good brands for 'run capacitors' or 'start capacitors' that are used on electric motors or heat pump compressors? ... r are the good capacitor brands for electronics (power supplies, laptops, motherboards, etc.) also the good brands for run capacitors?
                              Yeah I know this might be a novice question, but I just wanted to be sure. I did do a search on the forum but did not see this question asked before.
                              09-13-2024, 12:53 PM
                            • Prolog
                              RTX 3080 FE Identifying capacitor
                              by Prolog
                              Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                              I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                              I hope these photos make it clear which component I am referring to:
                              (yes, the soldering is a bit botched from removing the blown one, I know)
                              I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                              12-01-2024, 08:27 PM
                            • chth96
                              If I replace with inferior capacitor, Is it No harm to other IC components at all?
                              by chth96
                              I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                              Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                              It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                              So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                              I know that these capacitor will not last as long as nichicon capacitor...
                              12-22-2023, 04:34 AM
                            • Sinnyone
                              Is this capacitor any good???
                              by Sinnyone
                              Hi all. Just checking to make sure if this cap is good bad ugly.
                              I believe it is supposed to be .047 with a 10% tolerance. I just want to make sure Im reading this correctly.
                              44.89nF or .044mF
                              on the schematic, it is c4
                              So, it looks like it is just barely ok. what you guys think please.
                              Thank you...
                              08-28-2023, 11:24 AM
