Re: Any good references for variable capacitor design?
the caps in am radio's dont move plates, they move mylar film between the plates
Try our *UPDATED* boardview, bios, & schematic search. Over 2.3 million files for download!
Or you can just move them closer/farther apart
(which unfortunately is very nonlinear and capacitance drops very fast as you move farther apart, making frequency even harder to tune.)
The "only" two metal plates have to be very big to get appreciable capacitance and very stiff to make sure they don't touch each other...which becomes a very good antenna for picking up 50/60Hz...
BTW the tiny variable capacitors for full band tuning purposes use non-air dielectric to increase its capacitance in such a small volume...Leave a comment:
I got a var cap off Amazon. Took a couple of months to get it. If you look at electronics suppliers they are available. As I remember the cap was around 365 pf . Don't remember the micro Henries of the coil . But it's easy to find. You can also use a fixed cap and a mid taped coil. I have seen a few videos on YouTube on how to..
PS ,all you really need are 2 metal plates . One fixed the other is movable.Last edited by desert-rat; 07-28-2022, 01:08 PM.Leave a comment:
are we talking actual capacitor design, or tuner/antenna design, makes a difference here...
if you don't have any variable capacitors I'd think you're looking at the former. If you already have a pile of variable capacitors, then the latter is the issue?
I recall this one rat shak radio kit that actually seemed to be a bit better in terms of at least sensitivity, it was a regenerative receiver instead of the usual crystal + amplifier. Selectivity wasn't as good as standard off the shelf receivers, but it was able to pick up stations without the usual ground wire and really long antenna.
Either way if you don't have a variable capacitor at all, it'd be mighty hard to tune, at least the capacitance side. You can still tune the inductor side...Leave a comment:
i remember adding different capacitors to the earth and the antenna for selectivity and sensitivity .Leave a comment:
indeed the main problem is the plates need to be quite rigid and any slop that bends the plates will change the capacitance and cause your frequency to go off.
I think for the most part crystal radios are so nonsensitive and nonselective you're only going to get local stations and you don't even need to be tuned just right, and yes tweaking the inductor is probably easier/more stable. been a while since I played with a crystal set like with the radio shack spring terminal radio kits, but indeed they weren't that great... at least they got the inductor and capacitor just right to tune in the AM 300m band.Leave a comment:
wish i still had the book i used all them years ago .. all simple stuff really . i used to try different windings around a ferrite core and capacitors connected to an external antenna for selectivity and sensitivity .. its been a long time since i played around with simple radios. 50 years and more . or was it cap to copper water pipe ? i must have driven my dad and brother mad with all the wires etc .Leave a comment:
Is it possible for the op to post the project? Maybe scan it and upload it here?Leave a comment:
Old crystal sets are always tuning using the (slide) inductor. I've never seen a homemade variable capacitor. They are treated as a component you buy.
The common value of 365pF is a lot of capacitance to make, you need a multi-ganged rotor and too much mechanical ballyhoo.
Internet Archive - you can look through old radio magazines going back https://archive.org/search.php?query...=TXT&sort=date but I couldn't find a way to filter just old i.e. 1910-1950's. Many old radio magazines showing how to make one, but none have a DIY variable capacitor.
edit: surprised to see some countries taxed people with crystal radios, I think to help cover broadcast costs.
1922 crystal radio kit $4.75 or $84 in today's dollars. Not sure about the difference in wages though.Last edited by redwire; 07-24-2022, 04:52 PM.Leave a comment:
when i was building crystal sets i knew nothing about pf values i just threw them together and they worked fine . i did however know the differences of am and fm tuners though .Leave a comment:
capacitance has always been number of "active plate surfaces" times dielectric constant of air times area divided by distance between plates. Not much to it to make an air capacitor. Note that the plate material is immaterial as long as it conducts electricity. However the capacitance you need is dependent on the rest of the design, most specifically the corresponding inductor coil or antenna coil and what frequency you're trying to tune.
The reason why the old tuning capacitor looks funny is the effort the designers made to make the dial look linear. Making a makeshift capacitor for a homemade radio, this doesn't really matter.Leave a comment:
try searching tuning capacitor on ebay and google .. i see an an abundance of themLeave a comment:
your question will relate to the range of capacitance your after
did you try ebay/aliexpress for a crystal radio kit??
the chinese are really stepping up in a big way with eductational kits since radioshack died.Leave a comment:
I have recently decided to put together a 1930's style crystal radio as a father-son project to get him started in electronics. The lack of availability of now-obsolete variable capacitors is causing a big headache. From what I have seen on the internet, a number of people have resorted to making their own variable capacitors but have not given any details about how they designed them. Does anybody have any old references for the design of variable capacitors which includes details such as plate spacing, plate size, number of plates, best materials to use, etc.Tags: None
by cookAre there good brands for 'run capacitors' or 'start capacitors' that are used on electric motors or heat pump compressors? ... r are the good capacitor brands for electronics (power supplies, laptops, motherboards, etc.) also the good brands for run capacitors?
Yeah I know this might be a novice question, but I just wanted to be sure. I did do a search on the forum but did not see this question asked before.
Thanks-
Channel: General Capacitor Questions & Issues
by joetristanHello,
I’m using a 10 µF, 20 V tantalum capacitor as a decoupling capacitor across a 5 V supply. When I power the circuit, the capacitor burns out.
At first, I assumed the tantalum capacitor was defective and replaced it, but the new one burned out as well when the circuit was powered.
I then replaced the tantalum capacitor with a 10 µF, 63 V electrolytic capacitor. This time, the capacitor did not fail after powering the circuit.
I do not understand why the tantalum capacitor burns up?-
gigabyte x870i aorus pro ice stuck on dram light, ddr5 power good voltage 0 when ram stick installedby Apoco_ lipsI have a gigabyte x870i board I am attempting to repair. I have a working board as well to reference. The board is stuck on the dram light, wont post and I found the power good pin has 0 volts when powered on with a stick of ram installed. With out the ram it is 3.3v. Another weird issue with the board is when trying to use qflash to update the bios, the qflash light blinks for about 15 seconds then turns off for 30-45 seconds and then turns back on solid for about 3 minutes. My working reference board will flash the qflash led for about 15 seconds, turn off for a few seconds then turn back on...
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
I hope these photos make it clear which component I am referring to:
(yes, the soldering is a bit botched from removing the blown one, I know)
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... -
by woodboy971Hello everyone,
I am a beginner in electronic board repair and I am looking for help with an HP motherboard: CM 6050A2892401 MB A01.
Initially, the laptop would not power on. After troubleshooting and taking measurements, I found that a capacitor was shorted, which was preventing the system from starting. I removed this capacitor.
After removing it, the PC now powers on for a few seconds and then shuts down. I believe this behavior is related to the missing capacitor, which is no longer performing its role in the circuit.
My issue is that I cannot identify...3 Photos-
- Loading...
