what tool identifies bad caps on live circuit?
  • speg_head
    • Jun 2010
    can anyone recommend a not-so-expensive tool that will show me if a capacitor is bad? I have a bunch of Dell GX 620s that do not POST, and replacing the caps that clearly looked bad was not enough (some work now though). I think the tool is called a ESR meter or something, but I guess I just need some clarification on what and how to use.. thanks
  • retiredcaps
    • Apr 2010
    • 9271
    Re: what tool identifies bad caps on live circuit?
    ESR meters cost anywhere between $40 and $70 (my guess).
    You can search these forums for reviews of ESR meters and how people like them.
    --- begin sig file ---
    --- end sig file ---
      • 31281
      not on a live circuit.
      only a scope will help there.
      • MXM
        • 430
        • Unknown
        i think he meant the scope and as far as i know those are waaaay too expensive.
        at least thats what they used to tell me at school haha probably just to keep our hands off of em
        We don't have a great war in our generation, or a great depression, but we do, we have a great war of the spirit. We have a great revolution against the culture. The great depression is our lives. We have a spiritual depression.
          • 31281
          well new, they are expensive.
          however, with the collapse of industry in the west, there are shitloads on ebay and the surplus market for very little now.
          the same goes for lots of other pro tools.
          • speg_head
            • Jun 2010
            Well i was just under the impression that the ESR worked On a live circuit lol thanks for clearing it up though. Ill go check them out cuz ~$50 is definitely doable for me.
            Edit: so what should i be looking for when using the esr meter that will tell me that a cap is going bad?
              • 31281
              there is a rough value a good cap will show,
              if it's higher then the cap is bad, if it's lower it may be shorted inside.
              • severach
                • Aug 2007
                • 1055
                Using an ESR meter in a live circuit may damage the meter. Perhaps you are looking for an ESR meter that reads capacitors in circuit without pulling. All the popular meters do. Some caps are unreadable in circuit due to nearby components.
                sig files are for morons
                • brethin
                  • Dec 2008
                  • 1907
                  Testing caps in a live circuit is a bad idea.
                  Testing caps in a dead circuit (without removing them) will not tell you 100% if they are bad.
                  To fully test a cap you need to remove it from the circuit and test the ESR and capacitance (2 tests and yes one can be good and the other can be bad).
                  A good ESR meter will test both.
                  A good multimeter will test capacitance (if it has that function).
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Using an ESR meter in a -live- circuit -WILL- damage the meter.
                    In SOME CASES you can use an ESR meter for 'in circuit checks'.
                    [Which means a de-energized circuit with no components removed.]
                    - BUT - If there are any caps in parallel with the cap under test then checking with an ESR meter still requires removing the cap from the circuit.
                    GX620 in SFF and USFF are known for blowing some of the the 4mm and 5mm caps in addition to the typical cap problems. [They get too hot.]
                    https://www.badcaps.net/forum/showthread.php?t=6055
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • kiddznet
                      • Jul 2010
                      • 176
                      Do caps leak clear looking gunk like silicon?Seen plenty of the brown stuff but opened a power supply today and there was this stuff.Replaced main power caps and one domed 1000uf 16v job that were leaking
                      Tests and runs fine.
                      939 DualCore AMD Opteron, 1800 MHz (9 x 200)
                      Abit AN8 / Fatal1ty AN8 SLI Series
                      3072 MB (PC3200 DDR SDRAM)
                      ATI Radeon HD 4300/4500 Series (1024 MB
                      Lian LI Aluminium mesh case
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Probably was silicon.
                        They use it to hold parts in place for machine soldering.
                        Clear silicon is a little unusual. Usually see white/beige/brown.
                        - Dr Seuss
                        • brethin
                          • Dec 2008
                          • 1907
                          Asking this question in this thread = no no.
                          Open a new tread for questions unrelated to the topic or you will most likely get no help.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Probably true, however,,,
                            When they gave you the badge did they issue a pistol that shoots used Fuhjyyu too?
                            - Dr Seuss
                            • kiddznet
                              • Jul 2010
                              • 176
                              I would delete the post but I cant find the edit button?
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Don't worry about it.
                                The edit button goes *poof* after a few minutes.
                                - Dr Seuss
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  a few being 10 minutes...
                                  clear goop is not unusual, it is essentially hot glue used by some companies instead of silicone. I have seen it in deer made units... powmax crap as well.
                                  what brand were the ones you opened up?
                                  sigpic
                                  (Insert witty quote here)
                                    • 31281
                                    depends, if it's wet then it's fresh electrolyte.
                                    • kiddznet
                                      • Jul 2010
                                      • 176
                                      The unit with the goop was a CODEGEN 300W
                                      Maybe a tool for detecting bad caps could be the "MK 8 Eyeball?"
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        sounds like the power supply could be a junker, codegen tents to make over hyped gutless wonders... some pics if you could get them would be nice...
                                        sigpic
                                        • tony359
                                          Best tool to place electrolytic SMD caps on a board
                                          by tony359
                                          HI all,
                                          I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
                                          When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
                                          The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because...
                                          01-28-2024, 06:23 AM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • eryjus
                                          by eryjus
                                          05-10-2023, 11:21 AM
                                        • rex98
                                          HP DMI Tool
                                          by rex98
                                          HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                                          DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                                          The DMI Tool given here are for personal use only.
                                          DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                                          You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                                          from it, and that you please credit the author...
                                          07-02-2025, 05:51 AM
                                        • Paxman_Swede
                                          by Paxman_Swede
                                          Hello!
                                          01-14-2025, 09:51 AM
