what tool identifies bad caps on live circuit?
Mann-Made Global Warming.
- Dr Seuss
Re: what tool identifies bad caps on live circuit?
There is one exception you can use an ESR meter to measure the ESR of batteries since their ESR goes up as they age. This is especially true of sealed lead acids.
I would qualify a battery as a live circuit of sorts.
But yes the only way to measure live caps is with a scope checking the ripple.
I had a Uniden phone from 03 it's handset was humming like crazy to the point where I could barely hear someone on the line. The wart had a 470uf 16V cap in it ESR measured 7.8 I thought it was kind of high. But before I condemned it I checked the ripple it was so bad it was almost as if I was looking at pulsed DC. The GP replacement cap which I checked before installation later had an ESR of 0.32. The old cap showed no outward signs of failure.
As you can see measuring ESR and if you're unsure about the proper ESR checking ripple can help sniff out most caps.Last edited by Krankshaft; 08-01-2010, 09:19 PM.Elements of the past and the future combining to make something not quite as good as either.Comment
by tony359HI all,
I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because... -
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by eryjusHello,
by rex98HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
The DMI Tool given here are for personal use only.
DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
from it, and that you please credit the author...-
Channel: BIOS Requests ONLY!
by Paxman_SwedeHello!
I have studied the board and...-
- Loading...
