aged capicator truth
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    So, my father says if you use something electronic, and then don't use it for a long time, the capacitors can go bad. I know I did have this time when I bought a precision 360 from goodwill that looked in great condition, and had good caps. But after I loaded windows on it, it refused to boot, I opened it up and the caps had bloated within a period of days, it probably hasn't been powered in months
    is this true? do caps or other components go bad from lack of usage?
  • brethin
    • Dec 2008
    • 1907
    Re: aged capicator truth
    No. Under normal conditions.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      they will lose their "form"
      i have reformed 50+ year old lytics by slowly increasing voltage and limiting current.
        • 31017
        that takes years.
        • Speedgeil
          Clarification on T2 ICloud unlock
          by Speedgeil
          my dear father passed away a year ago, leaving his 2020 Intel Macbook Air (A2179) behind. He also left notes on his passwords, which i tried when i wanted to reset the device. Apparently, i tried too often and i'm now left with a locked device, that only wants internet recovery and nothing else, saying that the password was used too often. I gave Apple a call, explaining the situation, but they refused to help.
          I'm not that much of an Apple guy, but i can do some micro soldering. I read that replacing the T2 chip is an option. Others wrote that replacing...
          02-15-2025, 11:19 AM
          Ghost Battery Gate Opener battery took a crap tonight it refused to close gave me three beeps
          by sam_sam_sam
          If I remember correctly this indicates a battery failure the other day I had to turn off the power going down the driveway to do something and forgot to turn it back on and the battery went dead but it charged back up and I thought everything was okay but apparently not because now it refuses to close and the battery power light and the line power light goes off when you give it a request to do something I have had so many devices that the battery have gone bad I am sick of it...
          12-02-2024, 07:31 PM
        • GTAVC16
          Alienware 18, Nvidia GTX 880m presumably shorted
          by GTAVC16
          Hi guys!
          I'm in need of some support so I can try to fix my laptop/gpu.
          While I am a cerified automotive mechatronic, I have only basic understanding of electronics repair and identification.
          I'd like to identify the issue and replace the specific component myself to learn about electronics and expand my skills a bit.
          No better time than now, when my laptop, Alienware 18 from 2013, shut down when playing and refused to start again.
          I know about electric diagnostics in and about cars, but I've never dabbled with electronics.
          However, I know...
          08-20-2023, 05:39 AM
        • K212
          Samsung QE65Q700TATXXC is not starting
          by K212
          my Samsung QE65Q700TATXXC has stopped working recently. It worked fine during the morning, and when trying to start it later the same day it just refused to start.
          The standby LED is working, but nothing happens when pushing the power button, other then the LED blinking once. No picture, no sound, no chime, no relay click. I tried a cold start, and other recommended fixes from Samsung. Nothing worked. Then i even tried to reflash the firmware, but nothing happened, not even flashing of the standby led etc.
          I contacted Samsung support who said it is most...
          07-31-2025, 12:45 PM
        • Soumana Sanou
          “HP ProBook 11 G2 BIOS password reset request – Need SMC.bin
          by Soumana Sanou
          Hello,😇😇😇
          I need help unlocking the BIOS password on my HP ProBook 11 G2 laptop.
          🔧 Model: HP ProBook 11 G2
          📦 Serial Number: 8CG72478MY
          🆔 UUID: 6F5ED686-5532-11E7-A2E2-911C6404E011
          🔒 BIOS Status: Locked with password
          The laptop is no longer under warranty and HP refused to help me.
          I’m looking for a custom SMC.bin file.
          I don't have a CH341A programmer, so it's difficult for me to provide a BIOS file.
          Thanks a lot for your help!🙏🙏🙏...
          06-17-2025, 04:04 PM
