Clevo P150SM not posting
  • Jasonexe
    • Apr 2023
    • 70
    I got a Clevo P150SM laptop that recently stopped working with the following specifications:
    i7-4710MQ
    2x8GB DDR3
    GTX 980M 8GB MXM
    250GB Sata SSD
    Right before it stopped working it actually posted but froze when it was loading up windows. After i shutdown the laptop, it refused to post again. The laptop would power on without showing any display, the fans would go full speed after a few seconds of powering on and would shut itself down shortly after.
    I tried the following things:
    Using different ram sticks
    Removed the MXM module
    Removed the Sata SSD
    CMOS Reset
    Reflashed Bios and EC with a programmer
    Re-apply thermal paste but same result
    I decided to check the cpu vcore rail while powering the laptop on and vcore was 1.7v which seems high to me, hope someone can confirm if this is normal or not. I measured resistance on vcore and reads around 16 ohms. I tried powering on the laptop while using a thermal camera and noticed the cpu gets warm on one specific side only (right side). The rest of the die does not heat up at all. I'm suspecting my cpu died.
    Anyone experienced something similar ?
  • barry101
    Apple 820-3662 VCore shorted to ground.
    by barry101
    Hi, Would appreciate some help.
    I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
    Get charger light but no fan spin or chime. No liquid damage.
    Found PPBUS and VCORE both shorted to ground. Other rails were ok.
    Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
    With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
    Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
    06-24-2025, 07:34 AM
  • Günter Schuch
    searching for Schematics & Boardview for Clevo P641HK1
    by Günter Schuch
    hallo leute ich habe ein problem mit meinem laptop der marke Schenker XMG P407 und zwar ist mir anscheinend der Grafikchip gtx 1050ti der direkt auf dem motherboard verlötet ist kaputt gegangen sie ist im Gerätemanager nicht mehr aufgelistet. deshalb hoffe ich hier unterlagen für das gerät zu finden. soweit ich herausgefunden habe wird die Platine die bei der firma Schenker verbaut wird von Clevo gefertigt und zwar mit der bezeichnung "Clevo P641HK1" ich hoffe auf eure hilfe und bedanke mich.
    Hello folks I have a problem with my laptop of the Schenker XMG P407 brand...
    05-14-2025, 06:34 AM
  • Francisco.s
    CPU vcore missing in HP workstation Z2 Mini 4G
    by Francisco.s
    Hi, have a HP workstation Z2 Mini 4G for repair with CPU vcore missing.
    The resistance at the output of CPU vcore coils, is less than one ohm so I think CPU could be damaged, but no mosfet are damaged.
    It mounts an i7 8th gen, and have only i5 7th gen for test, but I think it is not compatible.
    Without CPU in the socket there is no short, but there is no vcore voltag, and it emits a beep like no detecting ram.
    The controller chip for cpu vcore is a MP2949A, and has no enable voltage at pin 37.
    I wonder which circuit generates this enable...
    04-22-2024, 12:35 PM
  • mikzs
    Rx580 8gb sapphire nitro+ turn off vcore randomly
    by mikzs
    Hello, this is my first post, English is not my native language but I hope you understand me. I recently got a 580 that didn't turn on the typical short mosfet, as I didn't know exactly which one was short, I unsoldered them until I got the bad one out, I was able to remove the short and identify the bad mosfet, the gpu gives video again! but it has a problem that completely turns off vcore at random times or if I try to put a load on the gpu vcore drops to 0 I don't have much idea why because I don't know much about sapphire, any advice on where I could start looking or what problem it could...
    11-06-2023, 12:28 PM
    Axioo NEON MNW / Clevo W760S / Clevo W765S Laptop Schematic
    Axioo NEON MNW / Clevo W760S / Clevo W765S Laptop Schematic...
    10-04-2024, 03:59 AM
