aged capicator truth
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    So, my father says if you use something electronic, and then don't use it for a long time, the capacitors can go bad. I know I did have this time when I bought a precision 360 from goodwill that looked in great condition, and had good caps. But after I loaded windows on it, it refused to boot, I opened it up and the caps had bloated within a period of days, it probably hasn't been powered in months
    is this true? do caps or other components go bad from lack of usage?
  • brethin
    • Dec 2008
    • 1907
    Re: aged capicator truth
    No. Under normal conditions.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      they will lose their "form"
      i have reformed 50+ year old lytics by slowly increasing voltage and limiting current.
        • 31281
        that takes years.
        • Speedgeil
          Clarification on T2 ICloud unlock
          by Speedgeil
          my dear father passed away a year ago, leaving his 2020 Intel Macbook Air (A2179) behind. He also left notes on his passwords, which i tried when i wanted to reset the device. Apparently, i tried too often and i'm now left with a locked device, that only wants internet recovery and nothing else, saying that the password was used too often. I gave Apple a call, explaining the situation, but they refused to help.
          I'm not that much of an Apple guy, but i can do some micro soldering. I read that replacing the T2 chip is an option. Others wrote that replacing...
          02-15-2025, 11:19 AM
          Ghost Battery Gate Opener battery took a crap tonight it refused to close gave me three beeps
          If I remember correctly this indicates a battery failure the other day I had to turn off the power going down the driveway to do something and forgot to turn it back on and the battery went dead but it charged back up and I thought everything was okay but apparently not because now it refuses to close and the battery power light and the line power light goes off when you give it a request to do something I have had so many devices that the battery have gone bad I am sick of it...
          12-02-2024, 07:31 PM
        • 225xtrap
          can anyone help me find schematics or boardview for MM1500KFD (down4sound amp)
          by 225xtrap
          i have searched nearly everywhere, and asked the company directly and they refused. i have negative 14.5 volts coming out the speaker out. they refused to RMA cause i am out of warranty. which is of course their right to do so, but unfortunately due to family circumstances i was unable to use it until now and it was DOA straight out of the box. i was hoping they would take pity on me but they don't care. you can't even download the user manual from them its crazy. i intend to fix this myself but i think it might be helpful if i had a schematic. as always any help is greatly appreciated....
          08-19-2025, 01:07 PM
        • GTAVC16
          Alienware 18, Nvidia GTX 880m presumably shorted
          by GTAVC16
          Hi guys!
          I'm in need of some support so I can try to fix my laptop/gpu.
          While I am a cerified automotive mechatronic, I have only basic understanding of electronics repair and identification.
          I'd like to identify the issue and replace the specific component myself to learn about electronics and expand my skills a bit.
          No better time than now, when my laptop, Alienware 18 from 2013, shut down when playing and refused to start again.
          I know about electric diagnostics in and about cars, but I've never dabbled with electronics.
          However, I know...
          08-20-2023, 05:39 AM
        • Jasonexe
          Clevo P150SM not posting
          by Jasonexe
          I got a Clevo P150SM laptop that recently stopped working with the following specifications:
          i7-4710MQ
          2x8GB DDR3
          GTX 980M 8GB MXM
          250GB Sata SSD
          Right before it stopped working it actually posted but froze when it was loading up windows. After i shutdown the laptop, it refused to post again. The laptop would power on without showing any display, the fans would go full speed after a few seconds of powering on and would shut itself down shortly after.
          I tried the following things:
          Using different ram sticks
          Removed...
          11-05-2025, 05:41 AM
