Re: 1500uf 6.3v cap substitute
my problem is the replacement cap must not longer than 16mm.
(due to gap between PCB and GPU heatsink) and I can't find the other cap in this size (all I've found are 8x20mm.,10x20mm., or longer).
Ok, I will try to replace them with Nichicon HZ and see if it work.
thankyou.
thankyou.
