How to choose a substitute mainboard
  • learnmore
    • Mar 2022
    • 107
    • England
    Hello again Community
    Anyone verse on how you go about choosing a substitute mainboard for your TV repair. Like the chap in the video below sometimes a 1:1 replacement board is too expensive and reballing a mainchip(s) maybe outside of your skillset . In the video the poster states one needs to match the replacement board with the SMPS, T-con (if not built in) and panel (and substitute cabling be also be required).
    I'm very interested in choosing a suitable replacement board for any model or make of TV and the general (or detailed if your willing) step this entails.
    https://www.youtube.com/watch?v=sipFQkx2K_Y
  • Mirenia
    Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
    by Mirenia
    I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
    I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
    In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
    The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
    03-30-2025, 06:47 AM
  • bohaboha
    Help Me Choose the Right MAINBOARD
    by bohaboha
    It applies to Mainboard BN41-02751B-000 for Samsung UE70TU6905
    this is what is on stick : HU10 BN94-18627N P09R
    010233092557 0062 2021023
    1465.4-143/1010
    There are several part on Ebay for 55,65 and 70 TV but the number on the Stick label is not quite correct I am very unsure if they fit or even if they are somehow compatible with my unit. Very very grateful for any help
    01-19-2025, 02:05 PM
  • learnmore
    Help choosing replacement transformer for Levoit 600S SMPS
    by learnmore
    Hello Community,
    I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
    Peace
    LM...
    11-04-2025, 09:35 AM
  • AustinComputerDoctor
    Sharp CC-60LE640U - after mainboard replacement, backlite turns on -- but cannot update firmware / see menu
    by AustinComputerDoctor
    I am looking / wondering if anyone knows where a good firmware download link is for a LC-60LE640U, the sharp support sight says the screen is archived but offers no links.
    I see backlite is active,
    but I cannot get the screen to return back to menus , etc
    This is all after replacing the mainboard...
    any assistance is greatly appreciated.
    03-25-2024, 12:43 PM
  • Ihandyrepair
    Change name on tv after mainboard replacement
    by Ihandyrepair
    HI guys
    just quick question,
    I just fixed a dead Sony 55x800h, I replaced with a 65x800h board
    now works everything seems ok
    except that after factory reset, it will show 65x800h on the name,
    screen is 55 inch now
    I am guessing the size of the tv is programmed on the main board right?
    I could just change the name only
    or any way to flash the chip to make it to be a 55x800h instead?
    thanks...
    07-04-2024, 11:37 PM
