1500uf 6.3v cap substitute
  • daemon123
    • Jun 2010
    • 50
    I belong to a 3rd world country so online order caps is imposible for me. the only option for me is to get new caps from shops or salvage from old motherboards.
    Here is my problem, i have xfx 8600gts video card. two if its caps have blown, FZ79 1500 6.3v. I am not electronic geek, the caps look like polymer but they had the so called stripes on top so it seems like electrolyte. in the market i can only buy cheap electrolyte, but i have salvaged some of these, and need expert advice.
    1. HD Y4 1200 10v (silver, seems like poly but with stripes on top)
    2. LZX 1500uF 6.3v (electrolyte)
    3. 1500uf 6.3v (no name, 11IIITG, and M mark)
    4. EPCOS 1500uf 6.3 volts
    these are all salvaged from old things, please suggest me which ones to use. also i may try to get 1500uf 6v from gx280 mobo will that be good enough for it ?
    Thanks in advance to experts.
  • yyonline
    • Jul 2009
    • 692
    Re: 1500uf 6.3v cap substitute
    1. Could be old Nichicon HD. Some HD do not have the plastic sleeves. Not low enough ESR.
    2. Do you mean LXZ instead of LZX? Could be Chemi-con LXZ. Not low enough ESR.
    3. That's a Panasonic cap. There should be a series on it somewhere. Panasonic usually puts the series on the same line as the temperature rating. For instance:
    +105°C FJ
    This would be Panasonic FJ series. Panasonic FJ and FL would be good enough to use as replacements. Other series are insufficient.
    4. To the best of my knowledge, EPCOS doesn't make capacitors with low enough ESR.
    • daemon123
      • Jun 2010
      • 50
      Thanks yyonline for your reply
      here are some pics, maybe u will get better idea
      i think i need to salvage some more as i only will have 1 of the suggested one, will try to get more caps.
      I can easily get new caps, but they are ultra cheap so they wont last long and they dont have any data sheets or anything, just plain chinese caps.
      also do i need to replace the other caps too or are they good, btw, the card worked fine after the capacitors blasted, and still works but i have taken it out of pc just for safty.
      • yyonline
        • Jul 2009
        • 692
        The Panasonic might work. The others definitely won't. The series info for the Panasonic would be on the other side of the cap, the one that can't be seen in the photos. It will be on the same line as the temp rating.
        I know you said due to your location, it's hard to order decent parts online. However, many sellers will ship internationally. So, I'd imagine that's an option if you are in a location that at least has mail service.
        • daemon123
          • Jun 2010
          • 50
          thanks yyonline for you reply.
          the panasonic one is like this
          +105C FC
          if i order online the shipment will cost me alot, for that money and some more i can buy another card. but as i am always low on budget so i am trying to get this one working again.
          • yyonline
            • Jul 2009
            • 692
            That would be Panasonic FC series. Unfortunately, also not good enough.
            Topcat (site owner) sells Rubycon MCZ, which would be a good replacement:
            https://www.badcaps.net/store/produc...products_id=40
            I don't know what his international shipping rates are, but his domestic shipping isn't bad. Either way, I can't imagine it'd be more than a new card.
            If you do go the replacement route, replace all of the FZ caps. If they haven't failed yet, they may at any time. FZ is that bad. The other caps look to be Chemi-con PSA series, which is solid polymer and very reliable.
            • daemon123
              • Jun 2010
              • 50
              thanks again for your kind reply,
              i guess i have the option to get it online, can i post a link in forum ?
              i am pm'ed it to just in case online links are not allowd, plz let me know whihc one to get from that site
              • daemon123
                • Jun 2010
                • 50
                btw, what if dont get anything else and the above are only things i can put on my card, what will be the worse that can happen ?
                will the card get completly dead ? or the caps will blow soon ?
                • envoid
                  • 26
                  That XFX should have a full warranty to it even if you are the second owner. That is another route you could go. You do have to pay to ship the card in, though.
                  yyonline, do you know what the ESR is on the MCZ series? I can't find a definitive number on Rubbycon's site and wondered if Panasonic's FM series would be ok for the application in case daemon123 really needs to go that route.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    To replace FZ [and last] you need panny FM or better.
                    best choices include: Rubycon MBZ, MCZ,,, Panny FM, FL, FJ,,, Sanyo WG,,,
                    ,,, or Nichicon HM, HN with 2006 or newer date code.
                    The non FZ caps on the vid card are Chemicon polymer, no need to replace.
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      What country?
                      - Dr Seuss
                      • daemon123
                        • Jun 2010
                        • 50
                        Thanks for your reply guys, the country is Pakistan
                        as i said the online purchase is not feasible for me/neither will be sending the card to xfx, the local dealer gave me 1 year warranty only.
                        i will try to find some good series caps in used parts. i have also bought some new caps but dont know if they are fakes, so am posting pics of them, plz comment, also i can slit open them if u want.
                        these are labeled like this
                        1. blue one (ELNA 6.3v 2200uF (M)) RE3 CE85c 0135 (p)
                        2. black one ( 1500uf 6.3v) +105c FL (M) 45IVRZ
                        the bungs look good but the printing is fading on them so posted pics from u guys to confirm if they are fakes
                        • yyonline
                          • Jul 2009
                          • 692
                          Those are Panasonic FL series. Those should work. If you ask me, they do not appear to be fakes.
                          • c_hegge
                            • Sep 2009
                            • 5219
                            I agree with yyonline. Go with the panny FL. They look authentic to me as well.
                            • daemon123
                              • Jun 2010
                              • 50
                              If i open them up can i find out if they are real. I can split open alot of them as they are dirt cheap. please let me knwo if u want me to do something to them, as they dont cost much, i can manage like 3 dozens of them, no big deal for me.
                              Also if they are fake, what will be the worse that can happen ? will they short and get my card or will they blow open like the old ones did ?
                              • c_hegge
                                • Sep 2009
                                • 5219
                                If they are fake, the worst thing will happen is that it will end up like the cap in my avatar. Where did you get them from? If you got them from a reputable place, then they are probably OK. Splitting them open wouldn't tell me much about them, since all electrolytics are the same inside (other than this):
                                (https://www.badcaps.net/forum/showthread.php?t=556)
                                • Scenic
                                  o.O
                                  • Sep 2007
                                  • 2642
                                  the black caps (Panasonic FL) in post #12 would be the best option out of all of these caps you posted IMO
                                  replace the 2 blown sacon FZ's with them. the other caps are real solid polymer caps and should not cause any issues.
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    I agree.
                                    The FL look legit and would be a good replacement for FZ.
                                    - Dr Seuss
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      NEVER replace the bulging ones only. Replace ALL sacon FZ, busted or not, since they are guaranteed to fail later.
                                      • Scenic
                                        o.O
                                        • Sep 2007
                                        • 2642
                                        ^ uhm.. there are only 2 sacons.. and both of them popped..
                                        • Petros_Z
                                          Led stripes for Toshiba TV 32W1433DG
                                          by Petros_Z
                                          Hello, I have the TV of the title and it has problem with the led stripes. The code of the stripes is VES315WNDA-01. Also on the chassis there is a code "Model VES315WNDS-01". Searching for spare parts I found that there are led stripes for each of those codes. I don't know if someone had changed them before. Based on what code should I order the spare parts? From led stripes or chassis?
                                          Thanks in advance and sorry for my bad English.
                                          04-02-2024, 02:59 AM
                                        • kotel studios
                                          Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                                          by kotel studios
                                          Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                                          In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                                          08-06-2025, 02:07 AM
                                        • halen
                                          Hisense H55U7B vertical stripes
                                          by halen
                                          I have Hisense H55U7B TV with no picture, only big vertical stripes. I did several tests and I'm not sure, where is problem.
                                          1. Connected tcon to 12V, white, red, green, blue, black picture visible in cycle on full LCD without error
                                          2. Connected only left side of LCD to tcon, big stripes
                                          3. Connected only right side of tcon, visible normal picture on the right. Working as expected.
                                          Where could be problem?
                                          Tcon RSAG7.820.7932/ROH
                                          Main board RSAG7.820.8698/ROH
                                          Jan
                                          06-18-2025, 03:58 AM
                                        • korsar86
                                          Sharp LC-65CUG8052E stripes on the display
                                          by korsar86
                                          Hey, everybody.I'm asking for your help. Brought this TV in to replace the backlight. After replacing the backlight there are such stripes (see photo).
                                          The glass is not broken, decoders are intact, everything was done very carefully and in antistatic gloves. The experience of disassembling such diagonals is great. I do not understand what is the reason for such stripes that appear a couple seconds after turning on.
                                          Loops rewired, wiped them with alcohol, the connectors are clean. Who by experience can tell me why this happened? Perhaps at the reception did not notice when shining the...
                                          04-23-2024, 12:29 AM
                                        • learnmore
                                          How to choose a substitute mainboard
                                          by learnmore
                                          Hello again Community
                                          Anyone verse on how you go about choosing a substitute mainboard for your TV repair. Like the chap in the video below sometimes a 1:1 replacement board is too expensive and reballing a mainchip(s) maybe outside of your skillset . In the video the poster states one needs to match the replacement board with the SMPS, T-con (if not built in) and panel (and substitute cabling be also be required).
                                          I'm very interested in choosing a suitable replacement board for any model or make of TV and the general (or detailed if your willing) step this entails....
                                          03-23-2024, 02:55 AM
