Do bad capacitors stink?
  • 66DarkMatter99
    • Aug 2021
    • 8
    So I just built a new desktop computer and when I play some games I hear a slight electrical squeal noise for a minute while the game loads then the sound goes away. I noticed this sound over the last couple days only right now its followed by an odd dullish, headache inducing smell. This isnt the first time I've smelt this smell from a computer and I'm curious if this is actually a symptom of a bad or blown cap. I haven't inspected yet but soon will. Any thoughts on this?
    • 31287
    Re: Do bad capacitors stink?
    leaking caps smell like cat piss,
    look inside your psu
    • PeteS in CA
      • Aug 2005
      • 3583
      • USA, Unsure of Planet
      I’ve had caps new in the sealed bag smell like rotting fish. They were samples I was supposed to evaluate, but the stench made that unnecessary.
      PeteS in CA
      • 66DarkMatter99
        • Aug 2021
        • 8
        thanks for the clarification guys, cheers.
          master hoarder
          • May 2008
          • 12175
          Yes, bad (leaked / vented) electrolytic capacitors can (and usually do) stink... and at least not in any good way I can think of. It's not like "burned/toasty electronics" type of smell, though. More organic.
          As to the relation of that and the new desktop PC you build... I doubt you'd be having new caps leaking/venting this soon, even if they are cheapo brands... but I guess it is still possible. Without knowing more details about the hardware (particularly PSU brand, model, and production date) and age of the hardware (if motherboard or GPU is anything from the last 5-8 years or so, chances are it uses solid polymer capacitors, and those won't leak or vent, so they won't smell... unless they failed - which you would notice because they would produce a ton of smoke and/or short-circuit), I can't tell you more if that's what you're experiencing or not... but probably not, unless you're running a really cheap no-name PSU. With those, you never know what kind of surprises could be inside.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8711
            Just pulled some Chemicon SXFs. The electrolyte is puddled all over the PCB. Nasty stink as well!
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Check for spiders and webs on the motherboard and cards. Same with earwigs and house centipedes. (house centipedes are usually only seen in downtown areas)
              I have yet to see a house centipede at the current house, as I'm outside of downtown Springfield, but still in Springfield. On Main St. in Springfield, OTOH, I regularly saw them.
              But the dreaded earwigs are a common sight, right when I hoped that I wouldn't even see those tiny bastards! I'm outside of downtown enough to have earwig issues.
              Earwigs are the bugs that are associated with wetter-than-normal weather. (like the years 2006 and 2011 in New England)
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • redwire
                • Dec 2010
                • 3912
                I came home to electrolytic capacitor stink for months, then it went away, then it came back. Gutted all my equipment to find it and eventually it was the ZyXEL DSL modem supplied by my ISP.
                Inside is two huge 3,300uF caps and one had popped, so I exchanged it for a newer modem.
                On another occasion it was an LED nightlight that popped a capacitor and made that dreaded stink.
                For a new PC build, they off-gas all kinds of stink for a month or so. The power supply is the worst, fiberglass resins, glue curing etc.
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  For some reason, I like the smell of fresh motherboards! Especially the Asus Sabertooth 990FX R 2.0 that I got in summer, 2015. It's funny and punny how I literally like the smell of fresh motherboards during the morning!
                  Noticed that scent, when I was opening the motherboard package! (and afterwards)
                  It's not like fried electronics, which the smell of that, if believed to be from my PC, would make me panic!
                  Arc A770 16 GB
                  • dragon3x
                    by dragon3x
                    power on.
                    Here are some examples :
                    switching supply area).
                    than 6.3 V.)
                    03-21-2025, 02:46 PM
                  • slybunda
                    AA and AAA battery charger capacitors?
                    by slybunda
                    hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                    it has inside:
                    2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                    2 x 470uf 16v LZ105c branded as G.Luxon
                    not heard of these brands are they any good?
                    iv attached photos of the charger and the board inside for an idea on the type of...
                    12-24-2023, 04:41 AM
                    After all of...
                    07-13-2024, 08:14 PM
                  • Cama
                    Solar Inverter - SMH-II - 2 missing capacitors
                    by Cama
                    I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                    My model is : EASUN SMH-II 7 KW
                    Mother Board : P/N 18947-002401250250
                    Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                    Thank you...
                    09-12-2025, 02:50 AM
                  • Ady2017
                    Are there any datasheets available for Elna RJG capacitors?
                    by Ady2017
                    I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                    05-25-2025, 02:19 PM
