Where can I find a ZLH in stock?
  • ZuluLima
    • 35
    • U.S.A.
    I'm looking for a Rubycon ZLH 16v 2200uF. Anyone know who has these in stock. I tried Farnell, Mouser, Digikey, ect..... and 3/4 the world. Maybe someone knows something I don't.
  • amp
    • 6
    Re: Where can I find a ZLH in stock?
    From the sound of it ZLH are more targeted to the audiophiles? I could only find the 25v version. If its motherboard then i suggest the one for sale on this site.
    • sofTest
      • Aug 2008
      • 361
      https://www1.elfa.se/elfa3~ex_en/b2b...hop=ELFA_EX-EN
      Be a mensch
      • ZuluLima
        • 35
        • U.S.A.
        I guess the ZLH series are meant for extremly long life and slightly lower specs than the ZL series. I found a guy in Hong Kong who has the 12.5mm ZLG (like trying to find a needle in a haystack). These are much better than the 16v 2200uF 12.5mm ZL I needed to replace. $6 with shipping shure beats $50?? from Elfa for two caps.
        • Toasty
          • Jul 2007
          • 4171
          Caution: Fakes abound. Get pictures of the items' top, bung, and sleeve and post them here before you spend your money. Do it on a credit card in case you have a problem.
          Panasonic FM's are rated at 7000 hrs vs. ZLH at 10,000 hrs.
          Otherwise, FM's are better-
          ZLH: 2480ma / 17mΩ
          FM: 3190ma / 15 mΩ
          veritas odium parit
          • totalselfreliance
            • May 2010
            You might wanna try craigslist. Might take a bit of work but i have found alot of good stuff on there and reasonably priced.
            You will also have to worry less about counterfeits as well. But then Toastys recommendations wouldn't go astray - credit cards the way to go.
              by Vesko356
              08-11-2023, 03:27 AM
            • RetroComputingGrotto
              Need Help Identifying A Diode
              by RetroComputingGrotto
              I have an MSI 3PA1 monitor on my bench that wont power on. I have tested the 2 (what I believe to be Schottky Diodes) and both are shorted in both directions (a common faulty from what I can see on Google) but I'm not certain what the markings on the Diodes mean so I need some help in identifying which ones to order from Mouser please?
              I've done a search for 101C 5100C and all I can find are datasheets for 5100C which say they are 20-100V 5A Schottky Diodes but I'm not 100% sure if this is correct or not and what significance the 101C is.
              We...
              09-22-2025, 06:47 AM
            • DynaxSC
              by DynaxSC
              06-14-2024, 03:49 PM
            • em132
              Okay to use 6.3V caps on 3.3V line of PC PSU?
              by em132
              I'm currently in the process of re-capping a NOS (new old stock) Sparkle ATX-400PN (from the late-2000s), which was chock-full of Teapos and CapXons . Am looking to put a yummy mix of NCCs, Panos and Rubys in their place.
              Here's the problem I ran into: The 3.3V rail is filtered by a single 4,700uF/10V Teapo... The problem? This thing is only 10mm wide, and a wider (12mm) cap will not fit! I've searched the "big three" shops (Mouser, Digikey, Newark/Farnell) and all the 4,700uF/10V I found were at least 12mm wide. The closests matches I could...
              05-30-2023, 03:41 PM
            • danielgerman681
              ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
              by danielgerman681
              Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
              08-27-2025, 01:17 PM
