J107 Tantalum cap burning inside a USB hub?
  • zman78
    • Jun 2021
    • 18
    I have a USB hub specifically to fit in my car. It stopped working and i saw a burned J107 capacitor (see picture). It looks like it might have briefly caught fire as you can see the plastic under the capacitor deformed. It was hot enough that the other side (outside of the plastic box) also melted a little.
    I'm curious - does anyone know what might cause a cap like this to catch on fire like that? Is it just a random manufacturing defect that can happen to anyone, or was there a design issue with the USB hub?
    Also, does anyone know if these can burn hot enough to actually ignite a fire? I.e., was all that was ever going to happen was the melted case, or was there a possibility of something more serious?
    The hub is plugged into the car 24/7, and likely it burned while unattended. So in case the manufacturer replaces it under warranty I wanted to know if there are any safety concerns with having something like this always plugged in?
  • zman78
    • Jun 2021
    • 18
    Re: J107 Tantelum cap burning inside a USB hub?
    Oops for some reason the photo didnt post in the original, I'm attaching the photo again.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Re: J107 Tantalum cap burning inside a USB hub?
      yes it's possible to get hot enough to catch fire, likely it's due to manufacturer defect whether it's a bad capacitor or an improperly assembled PCB. MLC and tantalum capacitors are known to go up in smoke.
      Whether there's enough stuff around it to fuel the fire is the question whether it goes beyond the device. Most electronics stuff are housed in plastic that's made self extinguishing for this reason.
        • 31051
        100uf 6.3v???
        bastards!!!
        thats under-rated for a tantalum - you really need a 16v part there.
        letter code "C"
        • zman78
          • Jun 2021
          • 18
          Ahhh interesting, so the USB is a 5V power supply, and the J107 is a 6.3 volt cap?
          So do you think there wasn't enough voltage margin for spikes that may have caused this failure?
            • 31051
            exactly.
            you need some headspace with tantalums because overvoltage or reverse-polarity will make them burn.
            • PeteS in CA
              • Aug 2005
              • 3581
              • USA, Unsure of Planet
              Tantalum caps can fail that way. Circa 1997, after a burning tantalum cap led to a large computer center being shut down (and a VERY POed customer!), Sun Microsystems banned tantalum caps from all new designs and required a partial redesign of then-current equipment.
              At another former employer (Brandt Electronics, now defunct I think) I saw several times a burnt tantalum cap damage a DC-DC power module so badly that the module has to be scrapped. There, too, the company designed tantalum caps out of that product line.
              PeteS in CA
                • 31051
                it is rare though,
                apple and sgi used to pack there boards with tants and you never heard of a fire in one.
                • zx8401
                  Phantom Fiddler
                  • Aug 2013
                  • 49
                  Ooow that could have been very nasty :-(
                  Maybe put a switch and fuse in series with the +12v input, so you can turn it off.
                  Im happy it didn't take your car with it :-D
                  • pavithra_uk
                    • Nov 2010
                    • 44
                    Originally posted by stj
                    it is rare though,
                    I once saw macbook air with burnt tant (cpu vcore) anyway not pcb or nearby parts burned
                      • 31051
                      vcore would have been an smd polymer cap
                      the black ones with laser-etched numbers
                      • zman78
                        • Jun 2021
                        • 18
                        The problem is that when it occurred, I wasn't in the car. The car is constantly powering the USB port to record data to a dashcam, so even if there was a switch on it -- most likely the failure happened when I wasn't there to notice it.
                        Hopefully the manufacturer put the appropriate fire-resist/self extinguishing plastic around the USB hub. (Maybe they did since the plastic only melted and didn't fully catch fire).
                        • Flaku_34
                          Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
                          by Flaku_34
                          Introduction:
                          Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
                          04-18-2024, 12:47 PM
                        • stormanimal83
                          Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                          by stormanimal83
                          Hey....
                          Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                          my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                          01-18-2024, 02:15 PM
                        • jczarniak
                          JVC Fire TV or any other Android based firmware
                          by jczarniak
                          Is there available any Android Fire TV ROM backup ( Fire TV Firmware ) which I can download, save on USB stick and then load into the TV ?
                          I have got JVC LT-50CF810 Fire TV with firmware not working properly.
                          Thank you very much for any support.
                          Regards.
                          10-18-2023, 01:43 AM
                        • Eniaro
                          10 Amp switch 15 Amp fuse
                          by Eniaro
                          So, my VEVOR ultrasonic cleaner switch melted.
                          I contacted VEVOR, they sent me a new one after almost a month of back-and-forth messages.
                          Over the past few months, I've also replaced switches on heat presses (from various brands) with similar failures. What caught my attention is that the switches are always rated for 10 amps, but the fuses are always for 15 amps. this mismatch?
                          I've started to second-guess my knowledge. Everything I've researched says exactly what's happening to these switches.
                          This issue hits far too close to home. I'm concerned...
                          12-30-2023, 08:12 PM
                        • ChaosLegionnaire
                          cracked tantalum cap on a video card. safe to apply power without fireworks?
                          by ChaosLegionnaire
                          please refer to the attached pics. is it safe to apply power with that tantalum cap like that without causing fireworks? i dont wanna burn a hole through the pcb as the gpu chip is on the other side.
                          happened to me once before with a shorted mlcc. shorted mlcc on a vrm power phase burned a hole through the pcb power section but thankfully that was nowhere near the gpu chip. but the video card still ended up in the landfill anyway tho as the burn-through was not fixable.
                          so do let me know what u think of the chipped tantalum there. thanks....
                          09-08-2024, 07:05 PM
