Ceramic capacitor from Samsung monitor 68K 1KV
  • Bartoloni
    • Jul 2018
    • 140
    • Italy
    sorry but this 68K is causing me some confusion... (image uploaded)
    is the K the 10% tollerance?
    is 68K just 68 pico? (i have some 101 replacement 3KV.. maybe i can use those)
  • R_J
    • 9590
    Re: Ceramic capacitor from Samsung monitor 68K 1KV
    It depends on the circuit, but if this is just a snubber cap, 100pf should be ok to replace the 68pf
    The K should be 10% tolerance
    • Bartoloni
      • Jul 2018
      • 140
      • Italy
      i will try
      • MORETTIGIAN
        Capacitor detached from PCB – RTX 2070 Super Founders Edition
        by MORETTIGIAN
        Title:
        Description:
        During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
        I did not notice it detaching, so I am unsure of its original location on the PCB.
        Procedure performed:
        - Removed backplate
        - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
        - Reapplied thermal compound
        - Reassembled card
        Observed behavior after reassembly:
        - GPU powers on and operates normally under...
        09-18-2025, 12:14 PM
        09-07-2024, 05:50 AM
      • chth96
        Is it possible to test small ceramic disc capacitor with analogue meter?
        by chth96
        I read EBOOK of Testing Electronic Component and found that
        "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
        Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
        It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
        Is it really possible to test small ceramic disc capacitor with analogue...
        03-09-2024, 10:03 PM
        by momaka
        03-15-2023, 10:17 PM
      • tony359
        Bipolar capacitor for vintage Apple CRT monitor
        by tony359
        Good day all,
        I have a question about some old monochrome Apple monitors.
        Inside those monitors there is one bipolar capacitor. From the schematics I have it's part of the horizontal linearity circuit.
        A friend replaced a bipolar 4.7uF 25V capacitor with a Nichicon bipolar 4.7uF 25V. The cap popped after about one hour. The new capacitor was much smaller than the original one but that's not a surprise as the original one was from 1980. (I am not sure whether the original was was actually 4uF and was replaced with a 4.7uF?)
        The new capacitor:...
        08-12-2024, 03:27 AM
