Need advice on suitable replacements for CF-EG65 mobo
  • cortexia
    • Mar 2010
    • 6
    I woud like to replace the current caps on this motherboard (currently Chocon) with better quality ones. I seem to have access to a wide range of Nichicon at good prices. Could someone please help me in the selection, I am new to all this tech stuff and want to make a good choice. Ideally, I would like to replace all the caps with the same brand... the current caps are as follows:
    7 X 6.3v 1500uF - short (Have Rubycon ZL)
    8 X 6.3V 2700uF - tall (Panasonic eeufcoj272s)
    4 X 16v 1000uF - short (Rubycon yxf)
    Please notice the types I have writen in brackets next to each item. These are either what I have, or what the one local supplier is offering. Of course, I would rather replace all of them with either Rubycon, or Nichicon.
    Any help / advice in this regard would be greatly appreciated ;-)
  • cortexia
    • Mar 2010
    • 6
    Re: Need advice on suitable replacements for CF-EG65 mobo
    The motherboard is in a FIC ICE Cube VL67... I would really like to save this unit (if possible)
    • kaniki
      • 514
      having all the same brand and type of cap on the board would be nice, but not necessary. as long as they are a good brand and type and are low esr, then any will work. The important thing to do is if there are multiple in a certain area/row, then it is best to use all the same type/size/brand. you can see the list of good and bad brands by looking at the good and bad caps listing. also make sure that the size that you buy will fit on the board.
      Example, if you have a row of 4 "8 mm" wide caps all next to each other, then it is best to say with the 8mm because the extra size around may make it so that there is not enough room to fit all of them in place on that row.
      also, if you have a question, please try to have all available info about what you are doing before asking. You have the number needed, and have short or tall, but the same cap may come in 2 different sizes around, but with about the same height. look around and do a search about the type that you want to use here and you can usually find your answer to if it is a good or bad cap..
      • cortexia
        • Mar 2010
        • 6
        Thanks for your repsonse.. my apologies for not supplying the full details...
        7 X 6.3v 1500uF - (Replaced with Rubycon ZL... no size, or clearance issues)
        8 X 6.3V 2700uF - 10mm(D) / 25mm(H)
        3 X 16v 1000uF - 10mm(D) / 16mm(H)
        • lmcancu
          • Oct 2009
          • 158
          Get the ESR and ripple specs for the Chocon caps you currently have on the board (do a google search), and make sure that the ones you are replacing them have equal or better values
          • cortexia
            • Mar 2010
            • 6
            Thanks for the responses guys. I have replaced the caps and the board is working great.... it seems though that the PSU is somewhat toast as well :-( Gonna see if I can get a replacement, as it is very tight to replace the caps in there (nearly ALL the caps are TEAPO).
            • Wasmachinemann
              • Jun 2010
              Did you done it?
              Also disguised kick
              • cortexia
                • Mar 2010
                • 6
                I have fixed the motherboard and the PC does post, but there seem to be issues with the front ports. Thatis, when the front port PCB is plugged into the motherboard, the PC doesnt post. It may be that there a few caps on there I can replace. I am still trying to source suitable replacements as there is a bit of a space problem.
                Once again, thanks for all the responses guys - really apreciate all the help and advice ;-)
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  busted usb ports shorted?
                  • cortexia
                    • Mar 2010
                    • 6
                    Not too sure... but I suppose that if I replace the caps in question, and the problem persists, then I will just use the PC without the front ports connected. I also want to check the motherboard for stability - the last time I had it on, I think it might have rebooted a few times on it's own - but that could have been due to an unstable/faulty hard drive.
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      did you check the picofuse for the front ports? with a multimeter? it could be blown and somehow the board is sensing it when the ports are plugged in... they also might indicate if the 5v+ is shorted... although the data pins could be shorted without tripping the fuse...
                      sigpic
                      (Insert witty quote here)
                      • mockingbird
                        • Dec 2008
                        • 5488
                        It's funny because I extracted Rubycon ZL, YXG and Nichicon HD from some old (But never used) A7V motherboards. Curious that Asus would use these on motherboards back in the day because these are not as low ESR as MBZ, MCZ, or HN/HM.
                        Oh well. Maybe there was no benefit of ultra-low ESR for early Socket A platforms. In fact some of the motherboards were only two-layered (Made the extraction easier).
                        Oh by the way, does anyone know if '01 datecode Nichicon HD have the same problems as the HN/HM did? I want to use the aforementioned caps in PSUs.
                        • Scenic
                          o.O
                          • Sep 2007
                          • 2642
                          Nichicon HD's are usually OK. never seen any of those blown like HM/HN's yet
                          edit: BTW.. which ones are older anyways? the sleeved HD's or the sleeveless ones with everything written on the top?! o_O
                          • прямо
                            Help me decide which MOSFETs are suitable replacements
                            by прямо
                            Friends,
                            I need help. I'm having a bit of difficulty in deciding what would be the compatible replacement for these MagnaChip N-Channel Trench MOSFETs on a VRM circuit because they seem to have a much faster switching times compared to most N-Channel Trench MOSFETs out there that have the same (more or less) current rating and Rds(on)
                            MDD1502 (high side), 48.5A 7.8mOhm
                            MDD1501 (low side, 2 in parallel), 67A 5.6mOhm
                            VGS is 10V High side drain is 12V. Low side drain is from PWM controller (Richtek RT8120A) phase output 1V.
                            Here are the ones...
                            02-01-2024, 09:06 PM
                          • qwerki
                            Advice for replacements for some Rubycons in a Dell Precision 670
                            by qwerki
                            Hello, I was hoping some of you kind souls could give me some advice.
                            I have a couple of old motherboards I'd like to have a go at repairing. They come from Dell Precision 670s, and the caps have gone bad.
                            Ultimately, I intend on getting rid of them, but it's a fun project to practise my (de)soldering on, so I want to see if I can resurrect them, even if only temporarily. I'd also like to check if there's anything on the onboard RAID array I missed backing up (I don't think there is, but you never know).
                            It's the VRM caps that visibly leaked, so I removed...
                            06-20-2021, 07:20 AM
                          • ChaosLegionnaire
                            by ChaosLegionnaire
                            09-13-2022, 09:02 AM
                          • Ady2017
                            SMD fuse soldering advice please
                            by Ady2017
                            Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
                            11-07-2025, 12:03 PM
                          • Cerberuska
                            Mobo MSI B550-A PRO password popup
                            by Cerberuska
                            Hello guys,
                            I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
                            BIOS I updated to last one.
                            any suggestions?
                            And same thing for two different 5600G, and yes, MoBo supposed to support it.
                            Thank you...
                            11-10-2024, 01:23 PM
