several beginner questions
  • alegro
    • 33
    I'm new to the forum and to the world of component-level repair. Any info and/or links are much appreciated.
    1. Are there online videos demonstrating de-soldering, soldering, and (especially) cleaning out the holes with a pick?
    2. In an LCD, if its not the capacitors, how do you figure out what the problem is?
    3. Is it possible for a beginner to recap a power supply?
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: several beginner questions
    I was in your place 5 months ago!
    1) Try youtube, I found many videos with soldering tutorials, that helped me do it right.
    3) Yes, if I was able to do it, then everyone can do it :P
    • alegro
      • 33
      goodpsusearch, thanks for the encouragement. In your experience is it usually the capacitors with psu's or does it often involve more complicated troubleshooting?
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        I have a friend who is in the service department of my university. All bad stuff and old ones go to him, and then are stored or sent to recycle. Among others, there are more than 50 psus in big carbon boxes.
        So, I can tell you that a big number of them just needs a recap and then will be up and running, like this and this
        On the other hand, the repair of some others is a bit more complex, like that one. I let that down due to lack of technical knowledge.
        My first power supply recap was a success and is found here
        • etnietering
          • Apr 2009
          • 379
          Welcome to the forum!
          1) In addition to videos, there are plenty of pictoral guides. I don't know if they'd be more or less helpful than a video, but it's something else to consider.
          2) There are zillions of things that can go wrong with LCD panels. There's a whole section here on Computer Monitors. Browsing through there might give you an idea of some of the other things that can go wrong. There are a couple gurus that hang out there that should be able to help you with your problem.
          3) Oh yes. Once you get the hang of soldering and desoldering, it's not too difficult. You'll get the hang of it real quick.
          Good luck with all your recapping adventures! Everybody here is happy to help you if you run into problems.
          • cb92
            • Jul 2008
            • 174
            I'm a noobie too, and I'll tell ya, it's a struggle. I open up this psu in a Compaq that doesn't want to run anymore, and I see a forest of caps! Lord, I start pulling and checking, FINALLY find the bad one. It would be nice to have a way to check them on the board. Anyway, I replace the bad boy, and fire the computer up. About ten seconds later, bang, a cap blows, I put in in backwards after checking it. Luckily nothing else blows. I replace the blown one, and try again, and all is well, the computer boots.
            The bottom line is, get ready for some slow patient work that WILL fix your psu. I have fixed a couple of things, and am quite proud of myself. What was junk is now working. YAY.
            • Radio Fox
              • Jan 2010
              • 281
              Originally posted by goodpsusearch
              ...1) Try youtube, I found many videos with soldering tutorials, that helped me do it right...
              Unfortunately, there are also many on youtube that are absolutely atrocious! Always take note of any critical comments underneath the video to see what others have to say.
              ________________________________________________
              Invisible airwaves crackle with life
              Bright antennae bristle with the energy
              • alegro
                • 33
                Thanks for the info!
                4. Are the pictoral guides on this site or elsewhere?
                5. I have a 20/40 watt Radioshack soldering iron. I practiced on a completely trashed motherboard. At 40watts it 'melted' the pcb, and 20watts wasn't quite hot enough for some joints. So I'm wondering if 30 watts is the sweet spot. I noticed there is a 30watt iron for sale on this site. Has anyone used one of those? Are they beginner-friendly?
                6. Supposing I'm not too good at the motherboard work (especially with my limited equipment) -would it be possible to find one or more people here that would recap some mobos for me in exchange for other recappable mobos and/or other computer parts? I've got more parts than free time. Will I get ripped off mailing someone some boards? From what I've seen this seems like a great community, but people can be wonderful in cyberspace and thieving dueche-bags in the flesh.
                • Krankshaft
                  • Jan 2007
                  • 2328
                  If you want some real videos with a guy who knows how to solder check out these tutorials.
                  http://curiousinventor.com/guides
                  This is the site I went to to see how Chipquik works.
                  That Ratshack special iron that you refer to that I once had wouldn't be good for mobo work.
                  I wouldn't recommend doing mobo work without a regulated soldering station.
                  On mobos a good iron is the difference between removing a cap and removing a cap with the trace still attached.
                  But for working on single layer PCBs like PSUs for example that iron will do fine.
                  • Radio Fox
                    • Jan 2010
                    • 281
                    This is the site I went to to see how Chipquik works...
                    Haven't seen that site before. Looks like there's some interesting tutorials. Wil have a proper read later.
                    • alegro
                      • 33
                      Krankshaft, thanks for the tutorial site link.
                      Will a non-regulated iron work for LCD circuit boards? Is the 30watt iron from this site better than the Radioshack one?
                      • cb92
                        • Jul 2008
                        • 174
                        I use my iron at the 30 watt setting, 20 is too low. I have a huge iron for really big stuff, lke heatsinks. I find my pistol shaped iron to be hateful. Certainly no good for getting into tight places, but it does have power. I just bought a cheap battery iron at Home Depot for less than twenty bucks. The really good ones are expensive. Haven't tried the battery iron, but like the idea. I don't like to have to wait for the iron to heat up, and then just sit there sucking electricity while I'm doing other stuff.
                        Solder suckers are fun, work good once you get used to them. Heat the joint, jam the sucker in real tight and fire away. Don't worry about the tip, they are cheap in the long run. But you gotta have the wick stuff too.
                        I googled the 'cold heat' solder irons, they got slammed in reviews. An iron has to be tinned to work right, and I don't think they tin.
                        • sam67
                          • 256
                          Hi there , welcome ..I am a newbie also lol.
                          I have only really got into electronics when i joined this forum and have already recapped a few monitors,sorted out my speakers with a blown power amp.
                          Now i don't know anything like these guys on here but it is all learn-able .I have done alot of reading and asking questions and i am slowly progressing.Never done electronics until i came on here and i am really enjoying the learning experience.
                          I did my reading up on soldering and bought some good e books on testing components which has helped me alot .Also been and bought some test equipment like ESR meter analogue multimeter as well as a digital one and new solder station and just got hold of the atlas DCA meter . Just waiting to get some more cash for a ring tester.
                          This electronics stuff soon gets you hooked lol.
                          Best
                          Sam
                          • larrymoencurly
                            • Oct 2004
                            • 960
                            For single sided circuit boards, 20W is enough for small leads that go into small copper pads, 30W is good for almost everything except big wires, like the #18 or #16 ones for PSU cables that go into large copper areas, which are better handled with 40-45W. For plated-through holes in double-sided boards, 30-40W is generally enough, but big wires can need 50W. The iron tip matters -- thin and cone shaped is worse than fat and flat, and a clean tip can transfer heat a lot better than a dirty one (wipe frequently with damp paper towel or with curly brass, stainless, or copper hair, not a damp sponge).
                            • kc8adu
                              • Nov 2003
                              • 8832
                              • U.S.A!
                              the solder suckers are to be avoided due to their tendancy to drop solder crumbs which may short qfp and bga parts.and the coldheat irons are trash.esp for work on boards having sensitive parts.contact things just right and send 6v into a fragile chip.they are a resistance heater which connects via the lead or pad you are soldering.full supply voltage across the gap in the tip.
                              • alegro
                                • 33
                                Thanks for the info everyone.
                                Any comments on post #8, question 6? Do people here do that sort of thing? Is it worth it after the shipping costs? The boards I have are mostly Pentium 4, and Athlon XP.
                                  • 31213
                                  8-6 is hard to answer unless you put your location in your profile.
                                  (unless you want the postage to cost more than a new board!)
                                  • alegro
                                    • 33
                                    profile updated. Thanks for pointing that out stj.
                                    • alegro
                                      • 33
                                      If I decide to stick with repairing LCDs, power supplies etc (due to my limited equipment and limited skill) -would it be possible to find one or more people here that would recap some mobos for me in exchange for other recappable mobos and/or other computer parts?
                                      I've got more parts than free time. Will I get ripped off mailing boards to someone? Is this commonly done among the badcaps forum members?
                                      Also will it be worth it after the shipping costs? I'm in the continental US. The boards are mostly P4 and Athlon XP. They've all been properly stored, -either in a pc or in a static safe bag inside a box. I'd say 95-100% of them probably just need new caps. They have buldging and/or crooked caps, (as opposed to oozing caps, and burnt boards, etc.)
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        any of those p4 or athlon boards have isa?
                                        i might work something out with you if they do.
                                        • ck84
                                          Beginner and the rework station, have questions
                                          by ck84
                                          hi Guys
                                          a few days ago my first rework station (LY IR8500) arrived and now i have some questions before i try my first attempt on any scrap board.
                                          I connected the station to the PC to see if the software works.
                                          then I read out all the profiles from the controller.
                                          The problem I have now is to assign the individual profiles which profile is for what, I hope someone could help me a little.
                                          or are there finished profiles somewhere?
                                          and what software would you recommend only from LY BGA
                                          unfortunately it is very...
                                          08-26-2020, 06:34 AM
                                        • cook
                                          Beginner questions about unstable voltage in laptop
                                          by cook
                                          I am diagnosing an HP netbook (model 110-3735DX) that has a 19 volt external power supply/charger like most laptops have. I get 19 volts from the power supply/charger when it is not connected to the computer.
                                          The system board has been completely removed and there is no RAM in it and the battery is not connected.
                                          When I read the voltage at the power supply connector on the system board, I get a reading that changes quickly with these values; .9, 1.3, 3.4, and it basically loops like this. The voltages are usually no less than .9 and nothing usually over 3.5. I do...
                                          04-12-2020, 06:52 AM
                                        • Mess
                                          Motherboard diagnostic beginner advice
                                          by Mess
                                          To save you some time: the most important bits are in bold.
                                          Some further examples/explanations or to the side & in grey - you can probs skip them if it's TLDR for you. Sorry, I've got ADHD & tend to over-explain stuff - just like I'm doing right now 😅 Briefness is for poets not me 🙈
                                          Please help!! 🎶I'm just a girl in a world that wants to scam me out of lots of money for any tech stuff/repairs 🎵 Seriously tho, I'm poor&I can't afford to get laptop diagnosis, especially if it ends up needing a new motherboard. Where I live, all the tech shops are run by very...
                                          09-12-2024, 07:02 PM
                                        • studdy05
                                          Bricked HP Probook 450 G7 Bios questions
                                          by studdy05
                                          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                          Ive got...
                                          07-08-2025, 09:24 PM
                                        • electronx
                                          Questions About USB 3.2 Gen 2x2 and USB4 Designs: Type-A vs Type-C, MUX Requirem
                                          by electronx
                                          I’m currently learning about the USB protocol and designing a project, but I’ve encountered a few questions that I couldn’t find clear answers to. I’d really appreciate your input!
                                          1. USB 3.2 Gen 2×2 with SuperSpeed Type-A Connector
                                          According to the USB 3.2 specification, it states that USB 3.2 Gen 2×2 can support a SuperSpeed Type-A connector. This raises a question:
                                          If we use a SuperSpeed Type-A connector, the system would only utilize 1 lane for data transfer, leaving 1 lane from the host unused. Is this configuration valid,...
                                          06-26-2025, 03:27 AM
