4700uF 6.3v and 3300uF 16v in a 10mm Diameter
  • pfrcom
    replied
    Re: 4700uF 6.3v and 3300uF 16v in a 10mm Diameter
    https://www.badcaps.net/forum/member.php?u=15285
    He's in Prague
  • Paar
    replied
    I'm currently in a need of 4700uF 10mm caps and noticed that Rubycon ZLQ series is suitable for this. Mouser has them and Digikey too but the postage price is crazy, at least for an individual person like me who just wants to repair single PSU. Are there any other sources I could use?
  • Topcat
    replied
    Originally posted by mockingbird
    I'm still in touch with Joe on occasion.
    Not sure how I missed this one...but I'm glad to hear that! The way he just 'vanished' had me worried that his government just 'disappeared' him, I'm told is a common thing over there. Give him my regards next time you're in touch with him.
    replied
    Originally posted by pc7fan
    reducing to 3300u low-Z caps shouldn't be an issue whatsoever, plus that may reduce the risk of oscillations and will roughly match in ripple current ratings.
    For PSUs, reducing capacitance while also reducing the ESR actually increases the risk of oscillation... but in most cases (it does vary a bit with designs) you have to get silly with the ESR reduction to cause that. Off top of my head, only Sirtec -made PSUs will start to oscillate badly if you use lower ESR caps than what they had (and in some cases, some of their designs oscillate at low and high loads by default.)
    But by far and large, reducing capacitance (drastically - as in half or less) is much worse and more likely to cause oscillations than anything else.
    On the other hand, increasing the ESR simply decreases ripple filtering. Again, you have to go silly with increasing the ESR to cause oscillations... and as long as you use the same capacity caps as the originals, there won't be a chance for the ESR to be so high as to cause oscillation. So because of that, you could technically use GP caps in any PSU. Of course, they may not last long and the ripple output may be higher... but again, it depends on the PSU design.
    SMG is a fine choice, but remember that estimated lifetime doubles each 10 degrees Celcius less. KMG then should technically have double the lifetime than SMG at 4000 hours at 85C, if other factors are the same. KMG is the high-temperature variant of SMG.
    Exactly.
    So it comes down to application, really.
    SME does indeed have higher rated ripple current, though, as mockingbird pointed out. Thus, at 120 Hz rectified DC applications (such as the output of line-connected transformers), it should technically be able to take more abuse than KMG.
    On the other hand, in applications where you don't really expect a lot of ripple current but just need a GP filter (such as 3.3V, 5V, and 12V rail on the PCI slots, USB connectors, and Firewire I/O on motherboards), KMG may be a better choice than SMG, simply due to the higher temperature rating. This is why on the Xbox 360, Hann-Star used KMG (or Nichicon VZ) for the 16V, 100 uF caps instead of 85C series. Those Xbox 360 consoles can get pretty toasty inside. That said, I have not seen any of those KMG or VZ small caps fail inside them. So I think KMG is an OK series.
    BTW, KMG and SMG are the successors (and lead-free versions, if I'm not mistaken) of KME and SME series, respectively.
  • mockingbird
    replied
    I disagree with this characterization. I think SMG uses better materials than KMG. I believe they do better in the long term (at standard temperatures that is).
    The reason for my logic is that SMG has a higher ripple rating per given size. For example, for 12.5 x 20, KMG is rated at 920mA and SMG is rated at 1295mA.
    I think as a whole KMG is better than Nichicon VR or VZ (decent series but with a finite lifetime), but still not as reliable as SMG. When I'm looking for caps to replace old 1970s BEG (butyl ethylene glycol) capacitors in equipment, I go to SMG. I think SMG could perform well for many decades, while I wouldn't trust KMG for more than 10 years.
  • pc7fan
    replied
    I think SMG is overall superior to KMG for general purpose applications. True, SMG is 85c and KMG is 105c, but IIRC, SMG is 2000h @ 85c while KMG is 1000h @ 105c. I use SMG in wall warts where I replace what is usually an old, crusty 80s Taiwanese cap.
  • mockingbird
    replied
  • pc7fan
    replied
    They used KMG for a reason, those aren't areas that require high ripple current, thus 105° GP caps deem appropriate for decoupling. I have also seen good 10mm 16/3300 and 6.3/4700 Fuhjyyu TN that indeed tested around 3300 and 4700 respectively in old SP Antecs and Apevias. Since Fuhjyyu TN are general purpose, reducing to 3300u low-Z caps shouldn't be an issue whatsoever, plus that may reduce the risk of oscillations and will roughly match in ripple current ratings.
    replied
    Yea I would also not use KMG in a modern PSU, General Purpose caps do not belong there.
    I think it just depends on the topology a little bit.
    Even if it's a new PSU, if it uses an oldschool half-bridge design (which I know a lot of older CWT-built Antecs did), chances are you could probably get away with KMG or other GP 105C caps, simply because the switching frequency will likely be relatively low. Of course, there is a little bit more to it than that. (For example, the PSU transformer ratios can be designed to output higher voltage pulses with narrower width to get more "oomph" out of the switching transistors. This will put higher stress on the output caps and inductors. So that's one example where even a relatively low switching frequency PSU may benefit from low ESR caps. But even in those cases, GP caps with enough capacitance and adequate ripple current rating for the circuit should still handle the stress OK.)
  • RJARRRPCGP
    replied
    I'm still in touch with Joe on occasion. You can still reach him through the Chinese apps. Last I spoke with him he said he could still get Samxon but I think I decided to go with local alternatives at the time instead.
    Yea Behemot's RS are legit and newer stock than Joe's. He did a custom order on them as well a while back. I used them in a Socket370 VRM high last week along with some NOS Nichicon HZ for the VRM low.
    NOS?=Of course NOS, FTW!
  • mockingbird
    replied
    Originally posted by Topcat
    I thought RS's were discontinued....I haven't been able to get them since Joe Lo (bigpope) went MIA. I do like the specs of the KZN better for sure though.
  • Topcat
    replied
  • mockingbird
    replied
    Our forum member Behemot sells custom made UCC KZN 16V 3300uF capacitors which are 10mm and quite tall and I highy recommend them.
    He sells them through his Bonanaza store, or through his website.
    He also carries Samxon RS in 16V 3300uF, but their spec is not as impressive as KZN. You're already familiar with those.
    Originally posted by kaboom
    Has it ever been established that the fudgies were in fact their stated values when new? Remember, we're only seeing these antecs after failure or when in for recapping.
    Yes, they were in fact 4700uF. Don't bother trying to find 10mm 6.3V 4700uF caps. Just use 3300uF caps there.
  • Topcat
    replied
    I just dissected a Zippy / emacs (model R2W-6500) for another project I'm working on, there's quite a few KMG's in it. It's probably circa 2010 (it was running a 5400 series Xeon system). It's a high-time PSU, its a redundant server supply, working fine. Most the ones in the secondary are KZE and KY. The reason for the dissection was I'm repuropsing it for something less demanding and wanted to quiet the fans down. They're 8500RPM feeding off the +12v rail. Much quieter feeding from the +5v instead!
  • Per Hansson
    replied
    Anything with a high switching frequency I mean, it was designed for low ESR capacitors.
  • Topcat
    replied
    This PSU has to be a good 15yrs old....I don't think it would qualify as 'modern'...
  • Per Hansson
    replied
    replied
    I also never knew there was a KMG 3300uF 16v 10mm X 40mm that wasn't a special order. I love learning things!!
    Interesting, I also didn't know that KMG series have a 16V, 3300 uF in 10 mm dia. cap. Then again, I also tend to ignore them quite often on Digikey and Mouser, simply because they are GP series (hence, technically not good enough for PSU.) On the other hand, since you'll be replacing Fuhjyyus that aren't really that much better rated than GP caps, this probably might not matter much.
    Wouldn't surprise me if the stupidpowers' "4700uf" on the sleeve were one or two standard values lower.
    It's possible.
    But I find Fuhjyyu caps tend to be accurate about the capacitance on their label... when they are not failed, of course.
    And in that regard, it seems that Fuhjyyu just uses crap quality materials, which makes their caps very unreliable (unable to withstand heat stress and also breaking down in use over time.) However, of the many many F-u caps that failed, a select few do seem to survive... and IME, or at least from what I have in my salvage bin, those have been OK, surprisingly - even after using them for many years in various temp recap projects. Unlike Teapo SEK and SC series, at least these don't bloat by themselves when sitting on the shelf. With Teapo, I always have to reform them and check them on the cap meter... and even then that guarantees nothing. Then there's CapXon and Ltec I don't trust those even for a temp recap. Non-stressful breadboard projects is as far as I take them.
    By the way, anyone remember the 1650 uF -rated Fuhjyyu?
    https://www.badcaps.net/forum/showth...highlight=1650
    Maybe I should list it on eBay as "vintage rare special cap with warm musical sound"
  • kaboom
    replied
    Keep in mind oxide thickness reduction will increase capacitance.
    Charge say, a 16v cap from 16-20v thru a 1k-10k resistor til cap voltage equals supply voltage. Then measure the capacitance- oxide may be closer to original thickness.
    Yes, there's other factors involved here, not the least of which is the fact they're "f-yoos," but it's an attempt to go back to at least one "known". Such craps and their oxide thickness reduction will give a false-high capacitance when tested.
    Which you know already...
  • lti
    replied
    Most of the unusually small caps I've seen measured low, but still (barely) within tolerance. I did see a few that measured extremely close to the rated capacitance, like a 2200uF 25V 13x20mm that measured almost exactly 2200uF.
  • ssl6
    MSI K7T266 Pro (Ver. 1.0)
    by ssl6
    Hey Everyone,
    Long time lurker, but I think this is my first time posting.
    Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
    I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
    11-09-2023, 01:00 PM
  • CWEastwood
    Antec Smart Power SL300S capacitor replacement.
    by CWEastwood
    I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
    The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
    I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
    Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
    03-25-2023, 12:18 PM
  • Oldschool297
    RELAND SUN 6.3v 3300uf Low or High ESR?
    by Oldschool297
    I found these, i would only like to try them on a board to see if it post. It don't post at the moment, i guess there are 9 6.3v 3300uf that can be broken. Is these low or high esr? I did not find info on the web.
    https://www.amazon.de/-/en/10-Capaci...s%2C469&sr=8-1
    08-14-2023, 04:32 AM
  • quickname
    Cyberpower 1500AVR UPS repair
    by quickname
    I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
    Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
    I decided to verify that the batteries were...
    11-12-2023, 09:57 AM
  • competition
    Replacing capacitors in Evga PSU
    by competition
    I have Evga G2 1300w and I want to replace all the electrolytic capacitors because PSU is already 12+ years old and I want to give it more life before any capacitor does damage. There are no blown capacitors, but I want to protect myself by replacing them with new ones as a precaution. And now comes the main problem. I have 5 pieces of Bulk (I think they are KZE) 16v3300uf with dimensions 10/35/5, but I can't find them in that size, only 12.5/35/5.I have one KY 16v1000uf 8.5/19/3.5, one KY 16v220uf I think it is 6/13/3.5 but it is in holes of pitch 5 I have 4 pieces of KZE 16v2200uf with dimensions...
    11-14-2025, 11:12 AM
