Caps With High uF
  • AlbertRoss
    • Jul 2012
    • 181
    Caps With High uF
    I've removed some electrolytic caps from a Hi-Fi power supply which are Asia'x? Two of them both 470uF 10V have a high uF value, one reads 693.6uF ESR- 0.12R and the other one reads 670uF ESR-0.12R?
    I presume caps have a tolerance, either 10 or 20% so even at say 20% they would be still over their uF limit? What effect will these have, will they still work?
    Thanks,
    Albert.
  • R_J
    • Jun 2012
    • 9624
    Re: Caps With High uF
    Usually if the capacity measures higher they are bad.
    • PeteS in CA
      • Aug 2005
      • 3583
      • USA, Unsure of Planet
      IIRC, if a 'lytic cap measures well out of tolerance high that means the aluminum oxide dielectric layer has thinned, increasing the capacitance, but reducing its actual breakdown voltage. The typical tolerance for an electrolytic capacitor is +/-20%, 564uF max for 470uF parts.
      You might be able to re-form these parts, though they're a junker brand not worth the effort except as a learning experience.
      PeteS in CA
      • AlbertRoss
        • Jul 2012
        • 181
        Hi, thanks for your help. I've not seen these Axia'x before and they came out of a Panasonic SA-AKX16 CD Stereo System which is completely dead. Am I correct in saying that if all the other caps were good on this board but I left these 470uF high value caps in place, would that have a serious effect on the unit?
        Albert.
          • 31288
          electrical leakage is BAD, change them or something could get damaged.
          or the caps could heat up and potentially explode or burst open and spew electrolyte and bits of paper all over the place.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8352
            I replace all caps that are not within spec.
              master hoarder
              • May 2008
              • 12175
              +1
              A bad cap is not going to get better over time. Quite the opposite - it will only get worse. So it's indeed better to replace it.
              As long as the cap(s) have proper vent stamps, none of that should happen and the cap should vent "gracefully". But you can never be 100%, of course.
              Fun fact: Sacon FZ caps have their stamps done from the inside the case, which causes them to burst the vent rather violently when they outgas (sounds like a fire cracker going off, really.) Although you won't find then ejecting paper, they often spew electrolyte quite far. I tried it last week with one and it threw electrolyte spray/mist/droplets more than a few cm / inches away.
              I've tried that before with my cap reforming experiments.
              Unfortunately, I haven't seen any caps with high capacitance get healed from this.
              • jayjr1105
                • 281
                I see the same thing with the faulty Nichicon HM caps... Supposed to be 3300uf
                Ryzen 3600x
                16GB Patriot 3600MHz
                MSI B450 Gaming Plus
                MSI Air Boost Vega 56
                Acer 32" 1440P Freesync
                Rosewill Capstone 750W
                Hakko FX-888D Station
                FX-8802 Iron
                MG Chem .8mm 63/37 RA 2.2%
                • clearchris
                  New capacitor technology - high lifetime caps
                  by clearchris
                  I'm getting ready to put in a capacitor order. I generally look for nichicon, panny, kemet, or united chemicon, and I'm noticing that there aren't any 1000 hour caps anymore, and not many 2000 hour caps. Most of the caps are rated around 5000 hours or better. Last time I ordered, 1000 hour caps were pretty much most of them, and the very few 10,000 hour caps had pretty bad specs.
                  So what's the deal, have we made major progress with capacitor reliability in the past few years? Are these high lifetime caps ok to use? It's not that I wouldn't welcome the change, I really would, I'm...
                  03-26-2021, 06:39 PM
                  by momaka
                  03-15-2023, 10:17 PM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • tvguy12012012120
                  by tvguy12012012120
                  02-07-2025, 05:13 PM
                • link626
                  damn. I'm disappointed these high quality caps made my power supply worse
                  by link626
                  I thought my tv power supply was stable. It's been stable for a few weeks since I swapped in nichicon, united cc, panasonic caps to replace the cheap china caps.
                  But today it caused my tv to have a flickering spasm again.
                  what a letdown.
                  I swapped back my backup power board which has cheap china caps, and the tv backlight stopped flickering.
                  Sometimes these high quality caps just don't make things better.
                  09-01-2021, 11:02 AM
