Wanting To Try Something With Extra Capacitors for my original xbox
  • bulkchart32
    • Oct 2020
    • 32
    i have a shipment of capacitors arriving friday. i'm wanting to try an experiment where i fill all the cap spots(instead of just the 3 spots) in front of the processors with 3300uf caps to see if the extra power being available to the gpu/cpu help the xbox's performance. my question is, is there any chance that this will damage the xbox? also, has anyone ever tried this before?
    • 31028
    Re: Wanting To Try Something With Extra Capacitors for my original xbox
    it should work, but dont expect more speed.
    • bulkchart32
      • Oct 2020
      • 32
      so it won't hurt the xbox in any way?
      • Curious.George
        • Nov 2011
        • 2305
        • Unknown
        That depends on the characteristics of the power supply. Adding caps will make the circuit look like a lower impedance as power is applied. It's likely that the power supply will tolerate the increased load -- but, the suppl(ies) may come up slower than they should. Predicting the consequences of that are likely beyond a casual observer's capability.
        [chips have constraints on how power is applied and removed]
          • 31028
          it's a vrm output
          • bulkchart32
            • Oct 2020
            • 32
            it's a vrm output
            so the vrm sends it's current through those caps?
              • 31028
              the vrm is a low voltage high current psu for the processor core - those 3/5caps smooth it.
              • brethin
                • Dec 2008
                • 1907
                Changing Capacitors will not make your xbox more powerful, give it up already you have been told serveral times in many threads.
                • jayjr1105
                  • 281
                  Didn't you post this on reddit as well? It's pointless. More capacitors != faster system.
                  What capacitors did you buy?
                  Also, those capacitors aren't "fun" to replace without a de-solder pump. You will be happy when you have finished with the first 3.
                  BTW, I used 3900uf caps (x3) and no visual difference whatsoever at nearly 12000uf total.
                  Ryzen 3600x
                  16GB Patriot 3600MHz
                  MSI B450 Gaming Plus
                  MSI Air Boost Vega 56
                  Acer 32" 1440P Freesync
                  Rosewill Capstone 750W
                  Hakko FX-888D Station
                  FX-8802 Iron
                  MG Chem .8mm 63/37 RA 2.2%
                  • bulkchart32
                    • Oct 2020
                    • 32
                    yes i did post it on reddit. i've changed a several caps in xbox's before. i'm well aware of what a pain it can be. and i do have a solder sucker.
                    • bulkchart32
                      • Oct 2020
                      • 32
                      it's a vrm output
                      this is not about changing them, this is about wanting to add more so that it will get more power to the chips. i'd have 5 caps instead of just 3 to deliver power to the chips. that's be like having 5 wires delivering power instead of 3.
                      • jayjr1105
                        • 281
                        Solder sucker and solder vacuum are not the same thing. $200 price difference there. You are not making sense. Just change caps if they are bad and that's it. Populating two extra caps for the heck of it is a waste of time and 2 capacitors.
                        Ryzen 3600x
                        FX-8802 Iron
                          • 31028
                          it doesnt work that way - ever.
                          the chip draws the power it needs and if there isnt enough it will glitch and crash.
                          which does not happen because the circuit was designed to support that cpu.
                          • PeteS in CA
                            • Aug 2005
                            • 3581
                            • USA, Unsure of Planet
                            Increasing the capacitance will not improve anything. OTOH, you are messing with a carefully designed network that probably has capacitors of multiple types, values, impedance characteristics, and locations. You could probably get away with some amount of changes, but you will get no benefit and will risk screwing up the VRM's loop stability and/or the network's transient load response.
                            PeteS in CA
                            • OriginalDaggers
                              XBox 360 All Polymer Capacitors
                              by OriginalDaggers
                              As the title says, Xbox 360 Polymer Capacitors, replacing all on a Kronos 1 revision board.
                              I went over a thread here (Xbox 360 with blown caps) and gather some extremely useful knowledge!
                              If I have things right, I can replace them TO
                              x9 : 1500uF 16V 10x20mm
                              TO: 470uF Nichicon FPCAP R7
                              x2 : 820uF 6.3V 8x12mm
                              TO: 2.5V 820uF Nichicon FPCAP R5
                              On this revision, there are other 820uF polymer capacitors for GPU/CPU - I'll be replacing those anyway with the above FPCAP R5
                              What's a good replacement for the smaller...
                              This can be anything from game consoles to arcade games to anything else that doesn't really fit into any of the above categories. When starting a new thread, please put the make AND model of your device in the thread title. Also be VERY descriptive of your issue, that way you'll get the best answer possible!
                              02-20-2024, 12:49 PM
                            • ohren
                              Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                              by ohren
                              Hello!
                              I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                              Measured voltages with no load:
                              After rectifier diodes
                              12V: 6.17 V
                              5V: 5.67 V
                              Secondary transformer pins AC measurement (really don't know if this says anything)
                              12V: 2-2.5 V
                              5V: 1.04 V
                              I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                              03-18-2023, 10:33 AM
                            • tccyo22
                              Xbox One Original missing 12v enable signal
                              by tccyo22
                              Hi there, I have an Xbox One original in which I have all the 1.8v, 3.3v and 5.0v standby power rails present, however my 12v rail is not turning on and the enable signal PSU_V12P0_EN from the SMC to turn the power supply on is missing. There is high resistance on this line so it's not shorted directly to ground which leaves me with not many options.
                              Was looking at a schematic and see the enable is created by the SMC. I have 3.3v on SMC_RST_N_IN but I'm a little stuck on where to look next. Is it likely that the SMC has gone bad or am I missing something else (it's my first time with...
                              08-14-2023, 06:06 AM
                            • bulkchart32
                              does anyone have a schemtaic for what circuit each cap is in on the original xbox?
                              by bulkchart32
                              i have a 1.1v and i am having issues with faint wavy lines on the screen that i am trying to make perfect so it will be my main xbox.. also have some 1.0v's that are doing it but to a lesser degree. i really don't want to do a full board recap, especially don't want to have to replace those smds, so i want to find which specific caps that filter the video signal. i have already replaced several caps and messed up one of them that caused a dead short(has been repaired). so i really don't want to just do all the caps. plus, those 1.1v boards have a lot of them. i'd really like to just focus on the...
                              05-16-2025, 07:33 PM
                            • NatoPotato
                              Original Xbox Power Supply Repair - FTPS-0002
                              by NatoPotato
                              Hey there friends!
                              I have an original Xbox power supply, model FTPS-0002, that isn't showing any signs of life. I have never really done power supply repairs before but I'm eager to learn so I am hoping someone can help me diagnose this.
                              The issue is that I get no 3.3VSR standby voltage which in turn leads to no 5v or 12v. A couple things I have noticed in my initial inspection.
                              Resistor 25 and 29 are both reading OL, Capacitor 17 and 20 seem to be leaking as seen in the photos.
                              So far I have confirmed that 240v, main fuse and the 400v cap is...
                              09-04-2023, 06:45 AM
