Need help with determining what this component is?
  • blake.s
    • 123
    I need help determining what this component is called? Also, where the best place to purchase them would be?
  • R_J
    • 9583
    Re: Need help with determining what this component is?
    It is a NTC thermistor 10Ω 6a Protection thermistor 20SP 010
    Looks like a Canthern MF73T-1 10/8 Digikey 317-1596-ND would work.
    • blake.s
      • 123
      How would i go about finding these on that same website?? And thanks for the help.
      • R_J
        • 9583
        By "these" I assume you mean the electrolytic capacitors?
        • blake.s
          • 123
          The capacitors... sorry I was not clear on that response.
          • R_J
            • 9583
            This will get you close, https://www.digikey.com/products/en/...=1&pageSize=25
            you will need the diameter, height & lead spacing to get closer
            The originals had a "Ripple Current @ Low Frequency" of 2.04~2.49, so I suspect any of the replacements should be ok
            • blake.s
              • 123
              I was able to order them. Thanks for all the help.
              • PeteS in CA
                • Aug 2005
                • 3581
                • USA, Unsure of Planet
                The thermistor vendor is Uppermost Electronic Industries. Inrush thermistors are sort of like fuses in the sense that they don't blow like that on their own. There must have been a short circuit "downstream" from them.
                PeteS in CA
                • R_J
                  • 9583
                  The one cap does look a bit bulged and that could cause some issues, I would also check the igbt to see if any of the internal components are shorted. this looks like it is a vfd or some sort of speed controller.
                  • nmbb
                    Can not find Model/Value of Thermistor.
                    by nmbb
                    Machine: Autoclave.
                    Brand/Model: SANYO MLS-3780
                    Manual: (Sorry search option not working on this PDF)
                    Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
                    06-02-2022, 05:55 PM
                  • prodigy83
                    MacBook Pro M1 Pro Logic Board 820-02100 Mosfet where to purchase?
                    by prodigy83
                    My reference only: TT10141.
                    Problem: I need to purchase a mosfet chip from board 820-02100 M1 Pro, that is supposed to be Q5820 but according to Digikey, the schematic diagram I sent them, neither are relevant to the actual mosfet specification I sent them. I just basically need to find this mosfet to purchase, I cannot find it anywhere and am hoping someone could point me in the right direction without have to purchase this entire allusive board. Already checked with Digikey, Mouser, Aliexpress, eBay. Any suggestions?
                    Mosfet specs are as follows:
                    Chip markings:...
                    03-12-2024, 01:38 PM
                  • Use2bavolvo
                    Magic chef oven - thermistor ref voltage issue
                    by Use2bavolvo
                    I am having an issue with my wall oven temperature control is ~180f out of spec. The thermistor is measuring correctly but I noticed the ref voltage appears to be off. With the thermistor wires attached it's reading ~3.4vdc with the thermistor disconnected it's around I9.8vdc. my understanding is the temp is read off the resistance from the thermistor which leads me to believe the issue is with the ref voltage.
                    Another observation is the temp setting and readout at lower temps is way off meaning the oven thinks room temp is 300f and bake relay doesn't engage unless temp setting...
                    01-19-2023, 01:32 AM
                  • Quantum IC
                    Sony KDL-40BX450 LCD. Thermistor gets too hot 10 seconds after turning on the TV
                    by Quantum IC
                    Hello every one,
                    This TV came to me with the problem that it was totally dead.
                    The problem was the two MOSFETs and a fuse resistor in the power supply.
                    The original MOSFETs were KF7N50F and I repalced them with SLF65R700S2.
                    The original fuse resistor was 0.1 Ohm 1/2W. I didn't find a similar fuse resistor and I replaced it with 0.1 Ohm 5W ceramic resistor.
                    When I plug the TV the ST-BY LED turns on, when I press the power button on the TV, the ST-BY LED turns off and the TV doesn't turn on until the second time I press the power button is when the TV turns on,...
                    01-14-2022, 12:06 AM
                  • fab13
                    Thermistor exploded in two when turning on ps4 fat
                    by fab13
                    Hi there,
                    I have a fat PS4 with the fuse (5a) of the power supply which blows with each power on and there was a loud snap in the power supply and again the same problem after replacing the fuse.
                    I did not find a short circuit
                    The component that broke in two is an SCK 084 thermistor (See photo)
                    and measured at 11 ohm
                    So far I haven't received a thermistor.
                    Do you think that if I replace the thermistor and the fuse it should go away, because I have the impression that there is a strong current demand as soon as you press...
                    11-05-2022, 06:29 PM
