Tumble Dryer start capacitor
  • pintglass
    • Jul 2019
    • 79
    • United Kingdom
    Hi
    I've just had to replace a belt on our tumble dryer which had snapped.
    Upon testing the dryer the motor will not start by itself but will happily run if i push the drum to begin with, which lead me to test the start capacitor.
    The capacitor rating is 9 uf 450v ac +/- 5%, testing capacitance with my multimeter gives me a reading of 8.5 uf which is just under the lower end of its tolerance.
    Would this small amount be significant enough for it to not be capable of getting the motor running?
    • Jul 2011
    • 6040
    Re: Tumble Dryer start capacitor
    Some of these motors have a switch that at low speed start winding with the capacitor and when it gets up to speed it takes this winding out and goes to high speed winding
    This switch sometimes hangs up and does not switch back to the low speed or the low speed winding it open
    If this motor one of these switches take some brake cleaner with the dryer unplugged from the wall and clean the springs for the switch and then oil it fan motor oil in other words 5 weight machine oil
    Make sure that the spring switch works freely
    • pintglass
      • Jul 2019
      • 79
      • United Kingdom
      The motor does have a third wire going to it will this be for the switch?
      • redwire
        • 3910
        What make and model is the dryer?
        You likely have a run capacitor and a start switch. But that's more than three wires...
        • pintglass
          • Jul 2019
          • 79
          • United Kingdom
          I've attached a few images of the motor.
          Sorry just realised the start capacitor is not installed, that obviously connects to the red and black wires that are hanging down.
          • R_J
            • 9551
            Can you here a relay click when you push the start button?
            • pintglass
              • Jul 2019
              • 79
              • United Kingdom
              Yes it does make a clicking sound, but motor won't run unless i push the drum first then it runs fine.
                • 31066
                meter the windings - probably o.k. but worth checking
                • pintglass
                  • Jul 2019
                  • 79
                  • United Kingdom
                  Sorry I've never tested motors before.
                  Do you mean check voltage on them, is the motor housing my ground reference.
                  • R_J
                    • 9551
                    Do you have a meter? if you do, check the a/c voltage between white and red wires, you should have full mains, then check the voltage between white and black while pushing the start button, if you have voltage when you press the start button, check for an open motor winding, if there is no voltage, you could have a bad connection on the relay or plug wiring coming from the control panel.
                    If you want to check the motor resistance, check between white and red and white and black, it should be low resistance
                    • pintglass
                      • Jul 2019
                      • 79
                      • United Kingdom
                      I have put the capacitor back on then with the machine plugged in and switched on with the power button but the start button not pressed, I only get a few volts which is falling between red and white.
                      I've tested resistance and get about 30 ohm's between red and white but get OL between white and black
                      • R_J
                        • 9551
                        I suspect the motor winding could be open, white should be the common, I suspect Red must be the main winding, and Black could be the start winding.
                        Do you read any resistance between Red and Black on the motor?
                        It could be like this diagram (this is from a reversable motor model)
                        • pintglass
                          • Jul 2019
                          • 79
                          • United Kingdom
                          I'm getting a high reading that's jumping around of about 4 Mega ohm's
                          The readings I'm taking are from the wires connected to the motor but are also connected to the control board should i be disconnecting them from the control board.
                          • R_J
                            • 9551
                            I would disconnect it, but the readings for a motor winding are usually very low, One winding will be the main run winding and one should be the start winding and it seems like the start is open.
                            • redwire
                              • 3910
                              Hotpoint TVF770G Aquarius tumble dryer 95687010000, also goes by Indesit, Ariston, Cannon, Creda, Proline etc. I could not find the service manual.
                              But looking at another model, the motor has two windings and the control board seems to have a relay to do the start/run switching.
                              The motor might actually be OK, it's just the rolling load is too high. The belt might be installed wrong or too tight and I would check the support rollers are not worn out or need lube, the dryer is level. Otherwise a new belt will just wear out fast.
                              Check the huge safety recall on it too.
                              • pintglass
                                • Jul 2019
                                • 79
                                • United Kingdom
                                What could cause this to happen could I have damaged it while changing the belt I had to use a lot of force on the shaft to get the belt on.
                                • pintglass
                                  • Jul 2019
                                  • 79
                                  • United Kingdom
                                  The belt did seem tight to get on, but i have been assured its the correct belt for the machine, all it does is raps around the drum and then round the motor shaft.
                                  I'm unsure now what could be the cause of this as @R_J has said i should have low resistance between red and black.
                                  If i remove the belt and start the dryer would this indicate the motor is ok if it starts by itself of would the fact that it has no load mean the start winding is unused.
                                  • redwire
                                    • 3910
                                    You should get continuity, a reading of a few ohms. With the motor unplugged, white-red should be a few ohms and white-black as well. black-red should roughly equal the sum of the two.
                                    If you get open circuit, then you might have tugged on the motor's wires and broken a connection somewhere, have to look hard or take the motor apart to fix.
                                    It needs the start winding to get going with drum and clothes as a load. A motor will start up with no-load, belt off even though no start winding connected.
                                    • pintglass
                                      • Jul 2019
                                      • 79
                                      • United Kingdom
                                      The motor won't start even with the belt removed unless I help to get it going.
                                      • redwire
                                        • 3910
                                        WAIT this motor is reversable?
                                        • tmcw
                                          Tumble Dryer - motor start capacitor
                                          by tmcw
                                          I was looking for a replacement capacitor for a tumble dryer, and I found one on eBay that has the correct values, and even looked similar, but of course, when the capacitor arrived, it didn't look like the cap in the listing picture.
                                          I've attached the old (left) and the replacement (right) caps in a picture. The new one has plastic housing, the old one has a metal housing and is bigger. Am I likely to have any issues with this replacement?
                                          Thanks....
                                          05-09-2022, 09:11 AM
                                        • Per Hansson
                                          Motor run capacitor physical size vs voltage rating & measurements?
                                          by Per Hansson
                                          (TL;DR skip the first paragraph)
                                          I encountered my first dead motor run capacitor at a customer this week.
                                          For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                                          (Unless a servo motor makes more sense that is).
                                          But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                                          The pump would run but sometimes trip the 10A breaker.
                                          I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                                          Then it could...
                                          09-20-2020, 06:32 AM
                                        • notallbad
                                          Heat pump tumble dryer regas
                                          by notallbad
                                          Just wondering if anyone has successfully attempted a re-gas on a heat pump tumble dryer.
                                          The dryer currently in question runs on R134a.
                                          The dryer has been completely stripped down/cleaned/tested and re-assembled however there is no heating/cooling effect so working on the assumption it requires re-gassing. Of course, its likely theres a leak which would require soldering or even the possibility that the compressor has an internal fault even though it is running.
                                          I was thinking of getting a car aircon regas kit or probably easier but slightly dearer an hvac...
                                          07-16-2023, 01:27 PM
                                        • Petros_Z
                                          candy tumble dryer (evoc 981 at-s) Component 738
                                          by Petros_Z
                                          Hello. I have a board of a candy tumble dryer (evoc 981 at-s).
                                          It does not give an error but it keeps drying even without load. It has 3 ntc. Two are for the clothes and one for the compressor. I measure them and they look ok. I went to the board to measure the voltage given to them. It gives about 4v and it is going down as the ntc value going down.
                                          Because I wanted to measure more easily I tried to solder wires on the board. Probably I manage to destroy the component of the title. It looks like as a smd resistor. Hopefully there were other two same components. I disorder them and...
                                          01-04-2025, 02:17 AM
                                        • Prolog
                                          RTX 3080 FE Identifying capacitor
                                          by Prolog
                                          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                                          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                                          I hope these photos make it clear which component I am referring to:
                                          (yes, the soldering is a bit botched from removing the blown one, I know)
                                          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                                          12-01-2024, 08:27 PM
