Capacitor Identification
  • yz250f_spud
    • Mar 2016
    • 10
    I have a Uni-T UT61E multimeter that quit working after checking high current DC connected to the low current probe (facepalm). I've check both fuses (good) and battery (good) but it will not turn on. The screen will not illuminate nor can I get the continuity buzzer to chime when I touch the probes together.
    I checked resistance of all diodes, capacitors, and resistors. The following read OL and I consider suspect.
    C19 - "10 16V RVT" - I think I can find this one
    C39 - "106 16K 621 - I think I can find this one
    C27 - no text
    C41 - ceramic disc capacitor "16" or "6"
    C42 - ceramic disc capacitor "8"
    D2 - LED diode - no text
    I was planning to start with swapping the two ceramic disc capacitors (C41, C42). How do I identify these with only one digit?
    Any ideas how to ID the right part for the LED (D2) and C27?
  • R_J
    • 9535
    Re: Capacitor Identification
    The caps will likely be fine, you can't check them with an ohm meter (unless they show shorted), Do you have the schematic?
    The caps C41,C42 (8pf) will not stop the meter from turning on. The led is for data transfer and C27 (4n7) also will not stop the meter from turning on.
    If you are testing the meter out of the case, the rotory swich needs to be in place to turn it on.
    • yz250f_spud
      • Mar 2016
      • 10
      That's what I was doing with the caps. Just checking if they were shorted. I have not tried to test the meter out of the case but understand your comment about the rotary switch. I did find a schematic. Any suggestions what I could start testing?
        • 31029
        why post a scaled image that cant be read?
        start by checking the voltages at the chip - there is a regulator supplying it.
        • R_J
          • 9535
          What exactly were you checking when the meter quit? was it a high DC voltage? If you were connected to the current inputs you would have blown the fuse (unless someone replaced them with 1/4" bolts)
          • yz250f_spud
            • Mar 2016
            • 10
            R_J - I was checking if a dog shock collar was functioning. Has stock Asia-fuse fuses, 1A and 10A. Both pass continuity and ~0 Ohm.
              • 31029
              it's probably dead, you hit it with several KV atleast.
              • yz250f_spud
                • Mar 2016
                • 10
                VB- to VREF reads 1.24 V. If I need to get voltage at pin 1, I'll have to get creative with jumpering for the rotary switch.
                • R_J
                  • 9535
                  Where is VREF ? If it took a hit from a shock collar it likely damaged the ic, Why would you want to supply voltage to pin1? If the ic is not damaged yet, that would likely kill it. that's not how the circuit works.
                  VB_ is the negative of the 9v battery, The positive VB+ connects to VC+ (via the rotery switch) and connects to W1 regulator, The output of the regulator ▄ connects to pins 2,4,5 ▄. Check the voltage across C35 it should be 3 volts
                  The ic operates from 3 volts not 9 volts
                  • chth96
                    Is it possible to test small ceramic disc capacitor with analogue meter?
                    by chth96
                    I read EBOOK of Testing Electronic Component and found that
                    "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                    Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                    It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                    Is it really possible to test small ceramic disc capacitor with analogue...
                    03-09-2024, 10:03 PM
                  • NuclearSpartan
                    Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
                    by NuclearSpartan
                    I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
                    The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
                    I don't see any other visible damage anywhere else on the board....
                    11-14-2024, 02:32 PM
                  • rictechie
                    smd ceramic capacitor use in iphones
                    by rictechie
                    is there a brand of smd ceramic capacitor use in iphones? or they are generics
                    07-26-2024, 08:28 PM
                  • eastcoastcomputing
                    Capacitor identification
                    by eastcoastcomputing
                    Hi there,
                    Beginner's question, sorry to waste your time...
                    I'm not certain of the values for the capacitor highlighted (on the picture with the tape) as I am seeking a replacement. Am I correct, looking at the schematics) to think it is a 33 pico Farad (pf) 25 Volts? The size seems to be 0201 from what I can assess and when I try to source a replacement, I'm struggling to find one and it doesn't look like something common.
                    Any help or suggestion welcome. This is on an Asus FX506H Quanta NJJ DANJJMB1AA0 Rev 1A...
                    06-04-2025, 05:15 AM
                  • ITF
                    Vizio D55un-E1 burnt ceramic capacitor identification
                    by ITF
                    Hey, I'm extremely new to TV repair. Long story short, TV popped when I turned it on, opened it up, located the burnt ceramic capacitor, but the label with the info on it was burnt out. I don't know much about this stuff, so I was wondering if anyone could give me some info on the capacitor I would need so I could solder in the new one. The nearby capacitors have the labels on them, but they vary. The power supply board part # is: PLTVHU401XABV The board location number of the capacitor is C9100 and it is almost dead center on the board....
                    04-01-2020, 02:44 PM
