Is this ManYue's X-CON polymer cap?
  • Travis
    • Nov 2007
    • 18
    http://www.pcpop.com/doc/0/397/397507_2.shtml
    http://img5.pcpop.com/ProductImages/.../001208114.jpg
    The leftmost cap with "YF" marking on it.
    The mobo manufacturer Yeston claims it being manufactured by ManYue aka SamXon. Its internal looks like polymer but is it made by ManYue?
    More shots from the same brand, different caps with similar markings.
    http://www.pcpop.com/doc/0/403/403619.shtml
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Re: Is this ManYue's X-CON polymer cap?
    Ya, its samxon.
    • Travis
      • Nov 2007
      • 18
      But I cannot find any info on ManYue's website.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Why not?
        http://www.manyue.com/xcon_series_chart.html
        Mann-Made Global Warming.
        - Dr Seuss
        • Travis
          • Nov 2007
          • 18
          But the ULR series I've seen (on ATI HD4850 reference boards) doesn't look like that. It carries a "ULR" marking.
          • 370forlife
            Large Marge
            • Aug 2008
            • 3113
            BTW, the samxon rep here (bigpope) has a little line advertising them in his signature
            (My SAMXON Capacitors Database HERE!!
            X-CON is a new brand for SAMXON's Polymer Capacitors.)
            From his signature. If you want to contact him, heres his profile
            https://www.badcaps.net/forum/member...tposter&t=6190
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Doesn't look like what?
              The one in the data sheet does have a "ULR" marking.
              - Dr Seuss
              • Travis
                • Nov 2007
                • 18
                Sorry for bumping this old thread out...
                Because the one in the datasheet with a ULR marking doesn't look quite the same as the capacitor on the left in the following picture:
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  When Intel makes motherboards for Dell,
                  they don't look like motherboards Intel makes for Intel.
                  - Dr Seuss
                  • Big Pope
                    Approved Vendor
                    • Dec 2005
                    • 426
                    Yes, it is X-CON ULG or ULR, can't sure. However, i can surely it is X-CON polymers.
                    Why there is no marking "ULR" or "ULG"? The reason is these mainboard factories in mainland China custom requested Man Yue don't print "ULG" or "ULR" markings n caps and request to change the color of "red" a bit different. I don't know real comerical reasons.
                    However, i think that they think X-CON or "ULR" is not famous as Japanese brand. So decide ro remove the marking "ULR" on top of polymers.
                    The letters "YF" or others, is showing which the lot batch produced by which Man Yue branch factory in mainland China.
                    • Travis
                      • Nov 2007
                      • 18
                      So these purple (and sometimes in red) polymers are also X-CONs right?
                      http://diy.yesky.com/cmsimagelist/20...279kdg7h6w.jpg
                      http://www.it.com.cn/f/diy/0710/22/0...mjP35_b_05.jpg
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        That's hard to say.
                        Too many companies making them that use the same markings.
                        The red ones in the second pic are Fujitsu, can just make out their logo.
                        - Dr Seuss
                        • Big Pope
                          Approved Vendor
                          • Dec 2005
                          • 426
                          Yes, the purple polymers are also X-CON from Man Yue. It is because custom made for some hardwares factory.
                          I know the some factories complained that the original "pink" is not stable pink grade for the same pink in the whole lot of polymers, Man Yue said pink is different to control same "pink". By this reason, Man Yue chnage the marking color in some lot of batch in te past.
                          I saw X-CON in pink, red, purple and blue in the past. Most of color is pink, then red....
                          • chth96
                            Should I replace polymer capacitor?
                            by chth96
                            a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                            I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                            Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                            Is this ESR value of polymer capacitor correct?...
                            11-18-2022, 04:22 AM
                          • Perry Babin
                            Derating of polymer electrolytics
                            by Perry Babin
                            There have been suggestions for derating polymer electrolytics to below the rated values. I've seen documents that recommended this and some that indicate that derating isn't required. The documents recommending derating are often old or refer to old documents. Do polymer caps of this type still require derating for reliability?
                            If they require derating, why would the manufacturer give them their rated voltage?
                            This is the basic type of capacitor I'm referring to and included simply to eliminate other caps that use similar names.
                            https://www.mouser.com/datashe...
                            10-24-2025, 11:57 AM
                          • Perry Babin
                            How do organic polymer caps compare to liquid electrolytic for reliability
                            by Perry Babin
                            I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
                            If not organic polymer, what would be the caps that could take the most abuse?
                            08-18-2025, 04:04 PM
                          • chth96
                            Can I replace KME cap with Samxon GF cap?
                            by chth96
                            Hello.
                            I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
                            Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
                            I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...
                            04-17-2024, 07:11 AM
                          • cj_reha
                            Mystery 80s Sanyo cap - perhaps polymer?
                            by cj_reha
                            Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
                            01-06-2023, 09:24 AM
