I Don't Understand
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    Re: I Don't Understand
    Originally posted by budm
    I would run constant current of 120mA (80% of the max spec.).
    The VF of the LED will vary withe current flwoing through the LED, temperature all affect Vf, that is why you should use constant current source, 30V may be OK it depends on the Vdrops of the Constant current active control element at the needed current and variation of the total Vf of the LED string, you want it to have head room for the Output Voltage to go up and down as needed to maintain constant current.
    See page 12 of the graph which is typical spec provided by the LED manufacturer which I doubt if you have it for your LED. If you have constant current power supply then you do the measurement and see what you get with your LEDs you will be using.
    https://cdn.badcaps-static.com/pdfs/...7f6e02e49a.pdf
    Good caps: I.E. Panasonic FM/FC/FR series, and many other Japanese manufacturer.
    Unless I can somehow modify this circuit so that it puts out 120ma instead of more than double that amount which it does now ... I wont be using it at all ... unless I break that series up into two sets and run them in parallel...
    sigpic
      • Jul 2011
      • 6041
      I have been watching this post to see if you have figured some way to make it work
      I have some LED power supply module that are the same exact way that you have to match the current level but when you try to do this the voltage goes up
      What I found out is that the LEDs that I was trying to use did not match current draw that the LEDs that were in the LED module light
      I have not yet figured out how to overcome this problem yet
      Right now now I do not have time to figure this out
      Maybe the week of Thanksgiving when I am off from work I will have some time to figure this out and some other project problems at this time
      • EasyGoing1
        Shock Therapist
        • Sep 2016
        • 977
        I'm about as stubborn as they get ... I WILL get this working one way or another ... know that! I prefer using the method that is as stable and long term as possible, and the solution that people agree with - who know more than I do ... but if that avenue fails, I've got wire cutters and a pretty decent soldering iron ... bunch of caps and resistors and diodes laying around ... ill spit and duct tape something together eventually ... but for the time being, I sit among the great weevils on the mountain and digest as much knowledge as I can before they get sick of me ... ill let you know what the final solution is when I get there. :-)
        sigpic
          • Jul 2011
          • 6041
          I have the same problem
          M I prefer using the method that is as stable and long term as possible, and the solution that people agree with - who know more than I do ... but if that avenue fails,
          Yes I prefer to do it this way also
          But if all else fails resort to something like this
            Read post 34, I already show you how that 180mA comes about, so to change the LED current setting you just need to change the value of the resistor. It is all in the spec sheet.
              BTW, if you remove one of the two R13 (2R20) resistor, the constant current will drop down in half to 90mA.
              • EasyGoing1
                Shock Therapist
                • Sep 2016
                • 977
                NOPE!
                sigpic
                  Where is the meter connected to? In series with the LED string? Unless that spec sheet diagram does not match what you have, or 5602 is no longer regulating the current.
                  See the calculation and how the 5602 is connected, verify if it matches your board lay out as far as R13 connection is concerned. I see that one end of the resistor is connected to pin 7, 8 for sure, most Chinese manufacturers will just copy the circuit from the IC manufacturer application circuits.
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    [QUOTE=budm;861331]Where is the meter connected to? In series with the LED string?[quote]
                    Yes
                    OK, I'll have a look ... but im thinking if I just use two strings of LEDs connected in parallel it should be fine, unless it isn't bright enough but with 8 or 10 total of these LEDs I think it might be alright.
                    sigpic
                    • EasyGoing1
                      Shock Therapist
                      • Sep 2016
                      • 977
                      So I fixed the lamp ... here's how I did it:
                      I ordered these CV/CC power supplies and I used these LEDs, and I made two serial strings of those LEDs and connected them in parallel... I got an old printer power supply that kicks out 30 volts but as it turns out all the LEDs needed was 16 volts ... and I set the current to 280ma and its working like a champ.
                      sigpic
