Issue with LM317 and current draw
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    I'm supplying a LM317 that's configured for 5.0V output with a source voltage of 7 volts. The LM317 is supplying power to a 5 volt sensor. The sensor is drawing 110ma of current, but the LM317 gets really hot and when i check the current draw from the 7V supply to the LM317, the LM317 is drawing a little over 400ma ...
    This means that the LM317 is consuming almost 3 times the energy that it's supplying.
    Is this normal for a LM317?
    sigpic
    Re: Issue with LM317 and current draw
    Can we see you setup, schematic, and the pictures and how amp meter are setup to measure the Output current and the input current?
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      One time I got really wonky behavior with a 3 terminal regulator... when I hooked up the pins incorrectly... it's ADJ-OUT-IN ... or was it OUT-GND-IN?
      Dang 78L05 got me all messed up, it had to be different and all...
      • redwire
        • Dec 2010
        • 3910
        what you are describing is impossible - LM317 has a resistor to GND so extra 300mA is not possible
          Originally posted by redwire
          what you are describing is impossible - lm317 has a resistor to gnd so extra 300ma is not possible
          + 10
          • EasyGoing1
            Shock Therapist
            • Sep 2016
            • 977
            I figured it out ... well ... it could be one of two things:
            1) I am using a two channel digital POT to set the R1 / R2 values, and I just figured out that the POT chip I was using isn't quite working right. The R values from the wiper to terminal B (which is what I was using in both channels) would in fact adjust properly and the R values would read correctly but when i connected them to the LM317, it would exhibit the problem.
            I started thinking maybe the digital POT was somehow malfunctioning so i used standard resistors and the LM317 functioned normally. SOOoo... a little probing on the resistor pins on the chip gave me more odd behavior stuff like infinite resistance between pins A and B when that should have read 50k.
            I swapped the chip out and now that problem is solved.
            I want to say that the second possible cause of the problem is that I was using R values that were too high, but the more I think about it, i don't think that's possible ... I think that bad chip was sourcing current to ground through the digital POTS which was PARTIALLY shorting either pin 1, pin 2 or both to ground, causing the LM317 to draw too much current.
            With the new digital POT, everything works great. the LM317 draws no current even when powered when the sensor is not connected and when the sensor is connected, the LM317 is only drawing 110ma from the 7V supply which is only the current that the sensor is drawing from the LM317, so all is well.
            Thank you ... all of you who took the time to reply.
            sigpic
            • redwire
              • Dec 2010
              • 3910
              Digital potentiometers are limited for working voltage. Most are low voltage parts. The resistance elements with 5V Vcc is about 5V max. so the LM317 could not be dialed too high, maybe 7V max. before the EEPOT shorts.
              Usually an op-amp is used after the EEPOT with a gain of 4 so 0-5V becomes 0-20V control.
              • quickname
                Cyberpower 1500AVR UPS repair
                by quickname
                I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                I decided to verify that the batteries were...
                11-12-2023, 09:57 AM
                Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
                The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
                The bq24745 features dynamic power management...
                10-23-2024, 02:50 AM
              • SolderNewbie
                IPAD 6 (2018) A1893 No power
                by SolderNewbie
                I'm trying to fix an IPAD 6, 2018, A1893 WIFI.
                It does not turn on and does not enter recovery or dfu mode.
                History
                The device was working before, but did intermittently reset.
                I gathered two panic logs:
                "panicString" : "Attempting to forcibly halt cpu 0\ncpu 0 failed to halt with error -5: halt not supported for this configuration
                "panicString" : "panic(cpu 0 caller 0xfffffff020e14724): nvme: "AppleEmbeddedNVMeController. Controller fatal bit set. Write.
                I attempted an IOS update to the newest...
                12-21-2024, 03:50 AM
              • Prott
                Vega 64 - reset issue, 404 W power draw
                by Prott
                Hey,
                I have a problem with Vega 64. Unfortunately there seems to be no schematic, so I am going by what I feel might be the case for those two issues:
                1. On restart the card doesn't seem to clear the VRAM and acts out (the picture stays on the screen followed by a black screen or artifacts till the drivers load). If I turn the computer off and on again the issue is solved and the card works flawlessly. PCI_RESET resistance is around 1.8 MOhm and the resistor between core and the reset pin is 0 ohm, as it should be. Is there anything else that could be causing this issue?...
                09-26-2022, 08:44 AM
              • smile
                SCANGRIP POWERBANK 03.5782 - quiescent current draw 39mA
                by smile
                I got a scangrip I-View 03.5626 "Superior COB LED headlamp with sensor"
                These supposedly are high quality.
                The usual discounted price is 60Eur.
                While the headlamp seems to work OK, it lasts 1.5HRS as per manufacturer spec. The headlamp charges to 1345mA to a integrated battery that suppose to be 1600mA. The manufacturer explained that this is software cut-off and true capacity is higher because battery does not discharge fully.
                Well I did not disasemble the headlamp yet to verify. But the SCANGRIP POWERBANK 03.5782 - quiescent current draw...
                05-05-2023, 11:52 PM
