Digikey sold me caps that are over 4 years old
  • Cartel
    • Feb 2006
    • 112
    2014...thats pushing it for new prices isn't it?
    And these 2700uf test pretty high...usually new caps test below a bit, old ones test high.
    I dunno, seems a bit odd to me. Am I just being picky?
  • Cartel
    • Feb 2006
    • 112
    Re: Digikey sold me caps that are over 4 years old
    These 450V caps I paid over $60 bucks for these...2014 too.
      • Jul 2011
      • 6040
      I got cap from DigiKey before
      I did not have any problem with them
      I have used these types of capacitor in servo controller power supply with out any problem
      This is my two cents worth
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        They aren't produce or meats from a grocery store....they'll be fine.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          The capacitance is higher because the oxide layer is thinner. Once you put them in use they will reform and be fine.
          Follow the white rabbit.
          • retiredcaps
            • Apr 2010
            • 9271
            I'm not defending digikey, but 2700uF 25V may not be a "popular" value so the turnover for these caps might not be very high? Say compared to 1000uF 16V.
            --- begin sig file ---
            --- end sig file ---
              2902uF is only +8% way within spec. for 2700uF rated cap which has tolerance of +/-20%.
              PW series cap: https://cdn.badcaps-static.com/pdfs/...f05f5c7af5.pdf
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                Read the section "shelf life" in the above PDF.
                If you want to threat them nicely you can read this:
                https://www.badcaps.net/forum/showthread.php?t=50530
                Me? I'd just put them in circuit and be done with it
                • PeteS in CA
                  • Aug 2005
                  • 3581
                  • USA, Unsure of Planet
                  1.) PW series does not use the water-based electrolyte that has caused a shelf-life issue with some vendors and series. And AFAIK, water-based electrolytes have not been used for high voltage electrolytics.
                  2.) As "retiredcaps" said, 2700uF is not a popular value like 2200uF or 3300uF.
                  3.) As budm said, ~2800uF is well within spec. Cheap crap caps tend to be toward the low end of their spec, if not fraudulently low.
                  All in all, I would not think twice about using those parts.
                  PeteS in CA
                  • Cartel
                    • Feb 2006
                    • 112
                    Thanks for the replies.
                    The reason I buy caps at digikey and not aliexpress or ebay is because they are supposed to be fresh stock.
                    It bothers me to see 2014 on a cap I paid $8 a piece for.
                    The 25v caps...I can live with but the 450v ones it doesn't sit well with me.
                    I bought 5000 hour caps so I can enjoy the long life, not digikey's parts shelf.
                    Blowing up a $4000 amplifier would really piss me off.
                    /rant
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      4 Grand? What band is it exaclty?
                        • 31084
                        a modern re-make of something old??
                        • Cartel
                          • Feb 2006
                          • 112
                          160m-6m, its an acom 1000
                          The other thing about these old caps is nichicon gives them a 2 year shelf life.
                          https://cdn.badcaps-static.com/pdfs/...64fb172f94.pdf
                          Then I'm supposed to apply 450v though a 1k resistor for 1 hour (x's 8 caps) and then bleed them with a 1 ohm
                          Connect a 1kΩ resistor in series with the subject capacitor, and apply the DC voltage as high as the Rated Voltage for 1 hour.
                          Discharge the capacitor through a resistor of about 1Ω/Volt after the electrification
                          Seriously? Pay $61 plus shipping then spend a week reforming them, buying a 450v power supply to boot?
                          Like I got all the time and money in the world to do that on my kitchen table right?
                          I just want to unsolder the old ones and replace them with new caps...this is ridiculous I'm sorry.
                          *I just called digikey and they said they would replace them with some rubycons of the same values.
                          They said the rubycons were delivered (to them) in August 2018.
                          That sounds ok.
                          This sure is alot of stress though and it sounds like they want me to pay to ship these back.
                          I spent alot of time (hours) going through data sheets, figuring out lead spacing and heights to reach the decision to buy the nichicons.
                          wasted hours of my life with this and now wasting more.
                          • goontron
                            5000!
                            • Dec 2011
                            • 4108
                            • US
                            That sounds ok.
                            Ah, wideband. No wonder....
                            usually i would say put them in a let the reform on their own, but seeing as how wideband amps are easy to drive into oscillation, i don't blame you for being weary....
                              "They said the rubycons were delivered (to them) in August 2018." but do they they date code for those rubycons?
                              • Cartel
                                • Feb 2006
                                • 112
                                They refunded me for the 450v and the 25v that were 2014 and said to toss them.
                                I'm happy for that and will continue to use digikey.
                                • brethin
                                  • Dec 2008
                                  • 1907
                                  I bet you are, way to scam them., I'm sure they were perfectly fine, it's not bread or milk. Meanwhile our prices go up because of this..
                                  • Cartel
                                    • Feb 2006
                                    • 112
                                    I didn't ask for a refund, I was going to send them back and buy Rubycons.
                                    They just did it and refunded the 2700uf 25v caps on their own, I didn't even mention those to them.
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      So far all the feedback I hear regarding Digikey resolving their mistakes has been positive. That is, they don't question the customer and quickly resolve the problem by shipping out the correct or missing parts within 24 to 48 hours at no additional cost to the customer.
                                      Same for Mouser.
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        i would be much more concerned about the bleeder resistors in that acom rather than a few years old caps.
                                        they drift due to heat.
                                        and when one opens you start hearing snapping as the cap it is across breaks down internally.
                                        i always replace all of them in any hf amp i service.
                                        failure of 1 resistor sets the whole chain of failure rolling.
                                          by momaka
                                          03-12-2025, 03:42 PM
                                        • quickname
                                          Cyberpower 1500AVR UPS repair
                                          by quickname
                                          I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                          Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                                          I decided to verify that the batteries were...
                                          11-12-2023, 09:57 AM
                                        • Paxman_Swede
                                          by Paxman_Swede
                                          Hello!
                                          01-14-2025, 09:51 AM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • Foetuss
                                          Gigabyte GA-6OXT :: caps question
                                          by Foetuss
                                          Good evening
                                          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                          But I was also suprised about the bigger boys, which are 330µF 25V.
                                          Could it be they used 25V caps because they were cheaper / available at that time?...
                                          02-11-2025, 12:22 PM
