Help Finding SAMWHA & SamYoung Data Sheets/Info
  • Akashajeep
    • Jun 2017
    • 22
    I have a couple of amplifiers that are around 15+ Y/O and while a few of the alum cans NEED to be replaced, I am just going to replace them all at the same time. However, LoL, I can't seem to find much information besides what's actually on them. I.E. V/uF/Brand/Series/Temps. I don't want to throw $150 in caps at them (esp with all the work required to change them out) and find out that because the ripple current/esr/impedance is now different from what the original design called for, the power supply or audio output side is doing something funky and now the drivers are toast, or there is now induced noise. Which would actually be my luck, all that work and POOF, instant paperweights!!
    Sorry for the rant, I have looked in the "Datasheet Depot" section of the site along with no real results from the manufactures sites nor GooGle. The SAMWHA's in question are HC 85*C (M) 50WV 8200uF, and that's all I can find on those "CE-HC". The other SW's are "BP", and "RX" series. The SamYoungs, are the "SMS", "SXE", "SHL", and "SRF" series caps. THX for any and ALL help!!
    • 31301
    Re: Help Finding SAMWHA & SamYoung Data Sheets/Info
    interestingly, it looks like Samwha dont make electrolytics anymore!
    http://www.samwha.com/capacitor/product/product.aspx
    • Gianni
      • Jul 2008
      • 681
      • Italy
      Samwha website is absurd... you can find aluminum cap not under "Samwha capacitor" but under "Samwha Electric".
      The web catalog is damn slow... 5---10 minutes to load a page
      Here one link http://www.samwha.co.kr/SW_catalogue...um=pt&cpage=18
      I attach here what I found about HC and BP series.
      Ciao
      Gianni
      "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
      H. J. Brown
      • Akashajeep
        • Jun 2017
        • 22
        Much appreciated for the help, however, ....... LoL I don't think that is the right one for the HC's. Unless they have their dimensions listed backwards? According to their legend it's Dia X L, 35mm X 30mm. I just re-measured them and I get ~36mm OD, prolly due to them being a hair swollen and the shrink wrap, and 26mm (L) with a hard plastic top cover and heat shrink on them. @30mm (L)they would come in direct contact with the bottom cover plate of the amplifier. I have taken a couple of pics to hopefully show. In the last pic you can see that the "BP" is almost the same height as the "HC" in question and they are listed as 25mm L.
        • Akashajeep
          • Jun 2017
          • 22
          I somehow stumbled upon this section of the site that loads quick and has a list of the caps per that ElE. type.
          http://www.samwha.com/electric/produ....aspx?f_num=40
          I am going to shoot them an email and hope for some help on the RX and HC versions
          • Behemot
            • 4845
            • CZ
            Could be custom size. Just follow general rules: regarding the big ones, if it's linear power supply (likely it is), than standard are OK, long-life better.
            As for the rest, if it is very small (<=8 mm tall) it's always GP. If it's 85°C, it's pretty much always GP. From some 470 uF above those are likely filtering, you can use long-life or even some low-ESR because of endurance. Smaller stick with GP as well.
            Watch for polarity, if they have no - marking and/or BP on them, they are bipolar.
            • Akashajeep
              • Jun 2017
              • 22
              THX for the knowledge bomb!! "What is second nature for some, is a new beginning for another"!!
                You have switching power supplies in that in that unit..
                • Akashajeep
                  • Jun 2017
                  • 22
                  Well this is what I got from them,
                  "Thanks for your inquiry.
                  My name is from Overseas sales team of Samwha Electric, Seoul Korea.
                  We did internally check with your requested item,
                  and our part no. HC1H828M35025HA100 is matched your request.
                  Plz find attached Samwha Electrics' company profile."
                  I'm at a loss because I have no idea what those numbers are supposed to mean.
                  • Behemot
                    • 4845
                    • CZ
                    Part number of some of their caps. From quick look I'd say series HC, 8200uF, 35 V, 25mm diameter? Check with their ordering info, there should be some spec how the PN is assembled together. Most japanese manufacturers have that in each series datasheet, there's only BS in the HC series spec sheet.
                    • Akashajeep
                      • Jun 2017
                      • 22
                      Ok I see the dims in that reference number, 35 dia X 25L. I agree buncha BS!! The main thing I am really concerned with on these is the ripple current. Amp is "rated" 1200RMS, but most tests put it around 1500.
                      • withalligators
                        Looking for best replacements for Capxons, but can't find data sheets
                        by withalligators
                        Recapping the power supply board for a Samsung 305T monitor, everything is Capxon except 2 Rubycons. I can't find data sheets matching these online, so don't know what ripple numbers, impedence, etc, to look for. There are a few different looking GL series data sheet PDFs, but the listing that matches the capacitance and voltage is a much bigger case size. I've narrowed down selections with lead spacing and case diameter, and what's in stock at Digi-key
                        1 x Capxon 1000uf35v GL C720(is this a part number or batch number, can't find it anywhere) 105c
                        1 x Capxon 1000uf35v...
                        03-25-2022, 02:30 PM
                      • Vesko356
                        by Vesko356
                        08-11-2023, 03:27 AM
                      • danielgerman681
                        ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
                        by danielgerman681
                        Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
                        08-27-2025, 01:17 PM
                      • David Stroe
                        AOC CQ27G2U/BK - in need of data sheets
                        by David Stroe
                        I am trying to repair my monitor that shows image but the backlight is not turning on. I think either the power supply is not working properly or the LED strip is failing, which seems unlikely (the whole strip is off).
                        I really need help in finding the data sheets for this monitor's boards. The data sheets I need are for the following boards:
                        Power Supply: 715GA907-P03-000-001S and 715GA721-P01-000-0H4K
                        Main Board: 715G9500-M0C-B00-005K
                        T-CON Board: 19Y_270_EU3MQ_SR_V02_HF
                        If someone could please provide any of these data sheets, it would be awesome....
                        05-31-2025, 11:12 AM
                      • corrize
                        Where to find a very small fpc connector 0.3mm between 2 pins ?
                        by corrize
                        Hello, I search this connector (oxydated).
                        It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                        I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                        I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                        Do you know how to find this connector please ? What is the exact name for find it ?
                        08-06-2024, 05:25 PM
