Need Help...Mosfet ID
  • jdbird613
    • Jul 2018
    • 35
    Could anyone possibly tell me the difference between mosfet DFP50N06 with 1007 printer above it and mosfet DFP50N06 with 0907 printed above it? These are on the same circuit board, just trying to figure out the difference. THnx in advance for any advice!
    Re: Need Help...Mosfet ID
    Those number can be date code, factory code, etc. not important.
    https://cdn.badcaps-static.com/pdfs/...d2555f2f1d.pdf
    • PeteS in CA
      • Aug 2005
      • 3583
      • USA, Unsure of Planet
      Concur with budm. "0907" and "1007" are probably date codes, either YYWW (most common) or WWYY.
      PeteS in CA
      • Jane
        How do you test MOSFET in laptops ?
        by Jane
        I tried to use this method:
        Testing an N-channel MOSFET:
        Step 1: Discharge the Gate (turn off the MOSFET)
        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
        Step 2: Charge the Gate (turn on the MOSFET)
        Now, place the red probe on the Gate (G) and the black probe on the
        09-27-2024, 03:31 AM
      • re-atari
        Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
        by re-atari
        Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
        Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
        02-03-2025, 06:49 PM
      • Curious808
        Brother HL-2140 laser printer: printer error (solved)
        by Curious808
        SOLVED. I removed the printer in settings, replugged and let it reinstall and it worked this time.
        Windows 10
        Attempt to print and immediately get a Windows pop-up saying "Error printing". The document appears in the printer queue window with Status "Error-printing".
        Turned off printer. Unplugged, waited, replugged. Ran the Windows troubleshooter. Removed and reinserted toner cartridge. Checked for paper jam. No printer error lights. Reinstalled driver. Restarted the Spooler service. Rebooted...
        06-22-2023, 11:11 PM
      • redbaron1007
        Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
        by redbaron1007
        I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
        Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
        09-09-2025, 11:10 AM
      • Artefil
        HP officeJet 8012e ... A printer update will be installed to fix this problem
        by Artefil
        One of the partner I'm mostly working with, brought his Officejet 8012e, facing a problem I'm failing finding a solution.
        On the Officejet 8012e, there's only one USB connector on the back, for connecting the printer to a computer.
        The screen displays the following message :
        "a problem has occured with one of the printer's critical system files. A printer update will be installed to fix this problem"
        But even if the printer is connected through wifi to the network, nothings happen, and the printer stays idle for days.
        Have you ever...
        09-28-2023, 05:11 PM
