HALP! Where to store all of these Capacitors?
  • KeriJane
    Mac Enthusiast
    • Sep 2008
    • 681
    Hello....
    I have a problem that some would envy....
    Too many Capacitors!
    This comes from ordering caps by the 10's at DigiKey. I may need 6, so I order 20. Or maybe 30. And maybe some other ones that I noticed on the way over. Good thing there's no price break at 50!
    Ziplock bags and Shoeboxes are getting awfully full and difficult to sort through.
    So far, I got 3 shoeboxes, one for 16v and under, one for 25v and over and one for polymer capacitors (mostly empty),
    Two of the shoeboxes are bulging and spilling over. Eww. Looks like I need 5 total, and that's just for now.
    Now I've got PLENTY of shoeboxes but there's just gotta be a better way.
    Does anyone have any suggestions for a portable, tidy, well organized storage unit? My sewing boxes seem too small. Maybe some kind of tool box? Should I go to Menards?
    Please don't say that I've got to get some kind of fancy anti-static thing.
    Thanks for any advice,
    Keri
    The More You Learn The Less You Know!
  • linuxguru
    • Apr 2005
    • 1564
    Re: HALP! Where to store all of these Capacitors?
    I use ziplocks of various sizes, which are then stuffed into larger clear bags and shoeboxes. You can use stackable plastic cartons if things get really hairy.
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      I use a small parts rack for mine. The kind with the little plastic slide-out drawers.
      Unfortunately, it's not portable. When I'm doing an on-site recap (which I try to avoid), I just dump them into plastic bags.
      Ludicrous gibs!
      • pwrusr1
        • Aug 2006
        • 11
        /img
        Where did you find that? I think me any everyone else here needs one (or ten depending on how hard core you car )
        • Krankshaft
          • Jan 2007
          • 2328
          I use the same system. Bought the drawers at K-Mart for about 14 bucks each.
          I just organized my stash about 8 months ago. Before then they were in their labeled bags from Mouser and Digikey.
          In a large box when the bags kept falling out onto the floor and I found myself dumping the box over to scavenge for the right value cap.
          I knew something had to be done. Took me about 10 hours to sort and figure out how to categorize them.
          That big brown box is my degaussing coil and the white one is my HV probe for CRT anodes.
          As you can see I only have 2 series of caps Chemicon KMGs for GP and Pana FCs for low ESR. Since I mostly work with PSUs and TVs it's fine for me.
          The first set of drawers without GP on them are Pana FCs and ones with GP are Chemicon KMGs.
          If I ever needed ultra low ESR caps for mobos I'd buy another drawer.
          Since I've done this I can't tell you how easy it is to check my stock and reorder rather than scavenging through a bunch of bags in a box.
          A good tip I wrote on the drawers with a Sharpie but a bit of rubbing alcohol on a towel and it comes right off if I ever need to recategorize.
          It also is good for fuses which are on the right same system SB for slo blo and no SB for fast blow.
          • pwrusr1
            • Aug 2006
            • 11
            Thank you krankshaft for that post. Now I know where to start looking for a good storage solution
            • lucky13
              • Aug 2007
              • 412
              Krankshaft,
              That's a very well organized set up you have there!
              Thanks for sharing with us.
              As soon as I have build up more inventory of caps, I will do something similiar to your set up.
              Maybe I will model after dood's setup as I only have no more than 10 values of low esr caps.
              • bgavin
                • Jan 2007
                • 1355
                What's wrong with shoe boxes?
                I buy in 200pc bags for the price break, and don't stock what I don't use.
                Mine got into the big freezer Ziplock bags and then marked.
                • Richie_asg1
                  • Feb 2009
                  • 21
                  I bought an Apothecary Chest years ago - 42 deep drawers. Still keep things in zip loc bags in there as I'm not at the overflowing stages yet.
                  It just keeps all my other junk out the way - and looks nice in the living room.
                  Sometimes Auction houses sell storage that was used in libraries for microfilm or index cards. These would be ideal for lots of small items I would think.
                  Screwfix sell toolboxes designed to organise screws. Both sides open out - I think you get 25 compartments each side.
                  • MegaOne302
                    • Apr 2009
                    • 94
                    Nothing, that's what I use, picked up three dozen from Lowes for a little over a buck each.
                    They're the clear plastic type by Rubbermaid called (Clear Impressions type S).
                    These Shoe Boxes are good for the larger stuff and see-through ESD Zip Bags are great for organizing the smaller stuff.
                    Does an idiot make a sound if no one’s there to hear them talk?
                    • dragon3x
                      After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                      by dragon3x
                      Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                      power on.
                      Here are some examples :
                      (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                      switching supply area).
                      (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                      than 6.3 V.)
                      1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                      I replaced capacitors with aluminum-polymer.
                      3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                      03-21-2025, 02:46 PM
                    • slybunda
                      AA and AAA battery charger capacitors?
                      by slybunda
                      hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                      it has inside:
                      2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                      2 x 470uf 16v LZ105c branded as G.Luxon
                      not heard of these brands are they any good?
                      iv attached photos of the charger and the board inside for an idea on the type of...
                      12-24-2023, 04:41 AM
                      by sam_sam_sam
                      After all of...
                      07-13-2024, 08:14 PM
                    • Cama
                      Solar Inverter - SMH-II - 2 missing capacitors
                      by Cama
                      I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                      My model is : EASUN SMH-II 7 KW
                      Mother Board : P/N 18947-002401250250
                      Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                      Thank you...
                      09-12-2025, 02:50 AM
                    • Ady2017
                      Are there any datasheets available for Elna RJG capacitors?
                      by Ady2017
                      I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                      05-25-2025, 02:19 PM
